Upgrading the entire factory system help
Discussion in 'Audio & Video' started by Clarker2000, Jul 16, 2016.
  1. Jul 16, 2016 at 2:33 AM
    Clarker2000
    Clarker2000 [OP] New Member
    2012 Tundra TRD Reg Cab
    3" lift. 35's.
    first post here guys, looking for anyone that has done similar to give advice.
    I just got a 2012 Tundra and am looking to redo the entire stereo. The previous owner installed a sub under rear seats with an amp under drivers seat. The bass has some serious kick but that now makes the entire factory system seem weak.
    Not looking for crazy loud bass thumping system. I want crisp and quality.
    Has anyone here replaced all speakers and factory head unit?
    I am looking in crutch field but still unsure as to exactly what I need speaker wise.
    Cost wise I would like to stay under $2000 for everything if possible. I am also partial to Kenwood but certainly would look at anything if it's quality.
    Appreciate any info you may have. Thanks
  2. Jul 16, 2016 at 2:44 AM
    bandit
    bandit New Member
    2011 Supercharged Mazzulla Long Travel Rock Warrior
    Duh Tundra
    A new member thread would probably be your best start.....
    NewImprovedRon likes this.
  3. Nov 25, 2016 at 11:37 PM
    balou
    balou Texas Tundra
    2016 tundra cewmax 4x4 tss option
    bilstein 5100 adj front shocks led lights for bed
    If you email or call crutchfield. Their customer support will actually put an entire system together for once you tell them what you want. They also provide excellent tech support if you want to diy the install yourself
    SouthBoundSteve likes this.
  4. Nov 25, 2016 at 11:49 PM
    Tundra Fan
    Tundra Fan Paper Member
    Toby
    Nor Cal (Placer Co.)
    2013 Platinum, Silver Sky Metallic
    Your vehicle description says you have a regular cab.?.?
    I want to add bass to mine, but am wondering if it will make the rest of the system weak also.
  5. Nov 26, 2016 at 12:55 AM
    GNTundra
    Gino
    New Mexico
    2013 CrewMax SR5 Louisiana Edition
    Procomp Stage 2 6" 20x12 Fuel Mavericks 35x12.50x20 Nittos
    I added to 10" Jl Audio with a Rockford Fosgate amp!! I added a bass knob to change it up on the fly!! Some songs just have too much bass others lacking!!! Really helps the factory stereos highs and lows!!
    Id keep your amp and subs!! Theres tons of ways to get it done!! Budget will be the number factor!! Toyota made it real easy to tear down the interior and dash!! Simplicity and descent pricing with fair equipment is gonna be Tacotunes.com!! If your capable and willing you can add and match your own preferences as far as equipment!! If your willing to do the research!! The was a guy on here from TX who did a great write up with great explanation on his audio build!! Anyhow at least look at the tacotunes website they got great videos on HOW TO!! Not to mention the chicks are HOT AS HELL!! Good luck!!
  6. Nov 26, 2016 at 12:57 AM
    GNTundra
    Gino
    New Mexico
    Also tacotunes is running a Black Friday Special!! There setups are virtually plug n play :thumbsup:
