Upgrading the Audio - 2015 TRD Pro
Discussion in 'Audio & Video' started by MrTuRDPro, Jan 24, 2015.
  1. Jul 2, 2015 at 6:36 AM
    15max
    15max New Member
    Cole
    15 SR5 TSS 4x
    3/1 lift level, 35" Toyo Trail Grapplers
    subd
  2. Jul 2, 2015 at 9:31 AM
    Flobrandx
    Flobrandx New Member
    Brandon
    2015 TRD PRO
    Working on them now...
    Great write up MrTuRDPro! Thanks and I'm sure this will be helpful to many.
  3. Jul 3, 2015 at 7:38 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    When I was searching for a fix I ran across others with the same problem. They say the factory (maybe not all of them, I don't know) head units put out a dirty signal. The only way to know for sure is try it. You have a base HU or nav? Mine was a base HU, so maybe that makes a difference.
  4. Jul 4, 2015 at 12:17 PM
    TruckyTruck
    Gary
    It's been months since I looked at it. Tundratalk is where I looked. Maybe the entune system will be better. If you do get it, you could always use an audison unit. They are pricy but I've heard they work better than most line converters. I don't know what to tell you, just have to try and see.
  5. Jul 5, 2015 at 5:03 AM
    JustFwed
    JustFwed New Member
    2015 CrewMax Limited
    Thanks again Trucky, I checked out TundraTalk, didn't find anyone complaining about the FHU, I am beginning to think your noise issue is proprietary with only your personal Tundra's FHU .......but you're happy with what you have now.....a good thing
  6. Jul 5, 2015 at 1:13 PM
    TruckyTruck
    Gary
    If I were you, I'd still try too. I like the factory look. What line converter do you plan to use? I used an lc7i. I loved my setup except for the low end white noise. Maybe I should have tried another converter, but after hours of reading and many more hours of trying to get it cleaned up, I just decided to go with an aftermarket. I hope you can get yours to work right.
    Here is a guy on this forum with the same problem. Maybe you could talk with him.
    https://www.tundras.com/threads/sound-system-upgrade.225/page-4#post-30898
    Just a quick google search brought me this link with a guy with white noise.
    http://www.tundratalk.net/forums/tu...oise-through-usb-bluetooth-audio-upgrade.html
  7. Jul 15, 2015 at 8:38 AM
    ChadB
    ChadB New Member
    I have a 2014 Tundra limited with the entune head unit. I had a local shop install all new JL C2 speakers, JL amp and LC7i. They assured me things would sound great using the stock head unit... I am super disappointed, I have the white noise just like others have discussed here. After reading reviews on other forums and product reviews on Amazon it sounds like this is a common problem with the Toyota entune system and there is no way around it. I even called audio control and they basically told me there was nothing I could do other than turn the gain all the way down on the LC7... This does get rid of the noise, but defeats the whole purpose of installing a new system, it sounds like crap with zero gain. Now I am forced to install a new head unit... Exactly what I set out NOT to do. My advice, plan on replacing your head unit or don't upgrade at all.
  8. Jul 15, 2015 at 11:20 AM
    TruckyTruck
    Gary
    It's not just an entune problem... All of these head units, stock, produce a dirty signal. Not a popular statement.
  9. Jul 15, 2015 at 3:43 PM
    Mike Tread lightly.
    south carolina
    Not only that the components inside the factory head units are sub par with the industry.
    TruckyTruck[QUOTED] likes this.
  10. Jul 16, 2015 at 4:13 AM
    scratchex
    scratchex New Member
    2015 Tundra Limited
    3" lift TRD Exhaust 20" Fuel Lethal Wheels Toyo AT Tires Black Flares w/ spikes
    Curious if @MrTuRDPro has any "white noise" w/ his setup? I believe he kept the stock head unit.
  11. Jul 16, 2015 at 12:11 PM
    scratchex
    2015 Tundra Limited
    Love JL Audio. This is similar to the route that I'll be going. Keep us posted. Looking forward to seeing the pics of this build.
    15max likes this.
  12. Jul 16, 2015 at 12:20 PM
    JustFwed
    JustFwed New Member
    Did you understand my sub-woofer box I'm building?
  13. Jul 16, 2015 at 12:30 PM
    15max
    15max New Member
    Cole
    15 SR5 TSS 4x
  14. Jul 16, 2015 at 12:39 PM
    15max
    15max New Member
    Cole
    15 SR5 TSS 4x
    Want any other changes made to it? (I'm extremely bored at work with nothing to do. lol) I'm not sure you will be able to achieve the proper air space you need with this configuration.
  15. Jul 16, 2015 at 12:43 PM
    JustFwed
    JustFwed New Member
    Yeah, I need .37cf for each speaker not including the speaker displacement with enough room for my JL amps!!! Design it .....lol actually I have the schematics for Stealthbox , going to copy ...just not willing to pay 1000 bucks for the box alone
  16. Jul 16, 2015 at 12:48 PM
    15max
    15max New Member
    Cole
    15 SR5 TSS 4x
  17. Jul 16, 2015 at 12:53 PM
    scratchex
    2015 Tundra Limited
    I did. I'll be doing something similar for the sub I want to add. Can't decide if I'm going to go w/ (1) JL 8" sub or (1) 10" sub. I'll more than likely go with (1) 8" sub.
  18. Jul 16, 2015 at 12:54 PM
    15max
    15max New Member
    Cole
    15 SR5 TSS 4x
    haha. The box I provided a link to actually lists the subwoofer you picked out as one of the recommended subs. Just make separate panels on the sides for your amps and line converter.
  19. Jul 16, 2015 at 1:10 PM
    #49
    15max
    15max New Member
    Cole
    15 SR5 TSS 4x
    It doesn't specify if that includes the space the speaker takes up or even how much CF the speaker displaces.
    From Sonicelectronix:
    Recommended Enclosure Specifications
    Recommended Enclosure Type:
    Sealed
    Optimum Sealed Box Volume:
    0.50 cubic feet
    Top-Mount Depth:
    3-1/4"
    Cutout Diameter:
    9-5/8"
    Shallow Mount Installation:
    Yes
  20. Jul 20, 2015 at 6:45 AM
    #50
    njccmd2002
    njccmd2002 New Member
    2015 White TRD Pro
    Stock
    im following the steps soon enough. this i need. the radio in the tundra is bad!
  21. Aug 2, 2015 at 10:01 AM
    #51
    TUNDRA757
    TUNDRA757 New Member
    Tundra 2015
    Thanks for sharing... I just bought 2015 Tundra and looking at speaker upgrade. I guess need to upgrade the entire Audio system now,which out my budget for now.
  22. Aug 3, 2015 at 2:51 AM
    #52
    JustFwed
    JustFwed New Member
    2015 Tundra here and I kept my HU, I have zero white noise. One possibility is your installer ran the speaker, amp etc wires all next to each other and did not separate them, this can generate noises.......or maybe I'm just fortunate
  23. Aug 3, 2015 at 5:23 AM
    #53
    TruckyTruck
    Gary
    You are just fortunate
  24. Aug 4, 2015 at 4:21 AM
    #54
    JustFwed
    JustFwed New Member
    or maybe the folks are running the wires 4 ga and speaker wires down same corridor
  25. May 20, 2016 at 6:38 PM
    #55
    jimavery98
    jimavery98 New Member
    2016 Tundra
    Have any of you tried just replacing the factory amp with a decent 4 channel amp and still used the factory speakers?
  26. Jul 10, 2016 at 2:09 PM
    #56
    Blankcheese
    Blankcheese New Member
    Johnny
    '16 SR5 DC 4WD
    I really appreciate this write-up. My truck is brand new and I don't know exactly which direction I'm going with upgraded audio, but this helps a lot. Thank you!
  27. May 23, 2017 at 9:25 AM
    #57
    TundraOnDaCoast
    TundraOnDaCoast New Member
    2021 Midnight Black CrewMax SR5 5.7L Tundra
    Sorry to bump an old post, but I was wandering if the OP solved the over heating issue? I plan on putting my 4 channel under the seat where the factory is and my sub amp under the rear seat. Thanks for the write-up. This post is very helpful!
  28. Jul 29, 2018 at 8:17 AM
    #58
    OneTundra
    OneTundra New Member
    Don
    2014 Tundra
  29. Mar 20, 2019 at 9:57 AM
    #59
    tja1080
    tja1080 New Member
    TJ
    Whidbey Island WA
    2016 Platinum
    Did you use this harness?
    https://autoharnesshouse.com/41112.html
    Will it work for JBL equipped trucks?
  30. Mar 28, 2019 at 6:37 PM
    #60
    MrTuRDPro
    MrTuRDPro [OP] New Member
    2019 Tundra TRD Pro (Voodoo Blue)
    None...yet!
    No, I used a Metra harness at the time and had to cut off One of the sides and reroute a couple of the pins. Wasn’t hard to do, but it did take some time.
    This harness is custom built (wish they had it at the time) but won’t work for a JBL system. I’d contact autoharness house (inquiry@autoharnesshouse.com) and see what they have for JBL systems.
    Good luck man!
