Upgrading base radio question...
Discussion in 'Audio & Video' started by kwats1928, Jun 26, 2016.
  1. Jun 26, 2016 at 8:44 AM
    kwats1928
    kwats1928 [OP] New Member
    2010 Tundra SR5
    I have a 2010 SR5 with the base low bottom stereo system. I was curious if the wiring is in place where I could upgrade this to the stock JBL or maybe even the version with NAV etc?? I assume no, but thought it worth a shot.
  2. Jun 26, 2016 at 9:25 AM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Most likely the wires and harnesses are there. 99% sure they are.
  3. Jun 26, 2016 at 11:26 AM
    Mike Tread lightly.
    south carolina
    Probably not..
    The jbl has a amp that is in the dash.. so wires go from head unit to amp to speakers.
    Yours goes head unit to speakers..
    I really doubt Toyota rewired it if they did you would get lucky.. if you did get lucky you have to have head unit,amp and amp bracket..
    IMO go aftermarket and be done..
  4. Jun 26, 2016 at 1:29 PM
    TruckyTruck
    Gary
    All the wiring to hook up a factory navigation was in place in my truck... not sure on the amp hook up, because i didn't take apart my console. But the hook up for the factory sub was even there behind the rear seat plastic. It's just like trucks that don't come with the information buttons. The wiring and harnesses for them are already there. I could be wrong, but in my truck, a 2013, these things were in place. The only plugs I didn't find were in the doors for lights at the bottom of the door.
    But I agree, aftermarket is really the way to go. Toyota stereo signal quality, even in the jbl stuff, is pretty bad.
  5. Jun 26, 2016 at 1:32 PM
    kwats1928
    2010 Tundra SR5
    Good to know, I will for sure go aftermarket. I noticed you mentioned the information system, which mine also does not have. If I got the buttons and the instrument cluster with the proper display I wonder if it would work????
  6. Jun 26, 2016 at 5:28 PM
    TruckyTruck
    Gary
    There is always the off chance, it's not wired, but every truck I've seen where people added them, it was pre wired. There's one way to know for sure... just pop the panel out and check. If the wiring and harness is there, it will work.
