UPGRADING Audio- tips, suggestions and help!
Discussion in 'Audio & Video' started by zwillz, Mar 11, 2018.
  1. Mar 11, 2018 at 8:18 AM
    zwillz
    zwillz [OP] New Member
    2015 sr5 Crewmax
    Whats up!
    I am goin to be upgrading my 2015 sr5 with a complete JL audio system. I currently have a 10" JLw1 sub, and will be adding front and rear JL c2 650 components.
    Here is the kicker, I'm going to attempt this install myself-maybe help of a friend who knows less than me lol. Im def a beginner on this field! I have all the wires and power wires ran because of my current setup. I also will have a plug in play entune harness(which will save me alot). Im pretty confident on getting the door panels off and seat out, but my only hesitation is mounting and connecting the crossovers and the front and rear tweeters- which I'm mounting the front tweets in pre drilled oem sail panels. Wiring and splicing is NOT my specialty!
    Can anyone provide any info, tips, tricks, and especially pictures to help a brotha out!? I appreciate it! TIA
  2. Mar 12, 2018 at 8:38 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Best thing to do is watch the ********* youtube videos for install help. they go through everything step by step.
    Figuring out where to mount the crossovers is the hardest part. Takes a couple tries.
    do you have a list of everything you are going to install? You'll need speaker adapters for front and rear doors. What amp are you using? Are you going to use a LOC?
    GNTundra likes this.
  3. Mar 12, 2018 at 8:44 AM
    zwillz
    2015 sr5 Crewmax
    Thanks for the reply danimal86! I believe I have everything needed. I ordered everything from tech12volts, James Randy Taylor. That guy in company is awesome. I'm beginning to become a little bit more confident, and I've been watching those videos rigorously. This is a big thing for me and I'm pretty excited to try to attempt it. But, I do have everything including the brackets , wires , adapters , harnesses , everything.... like I said, my only concern was mounting the crossover in the correct spots. Do you have a system, or did you do an install or something like this? I appreciate your help in time!
  4. Mar 12, 2018 at 8:56 AM
    Danimal86
    Daniel
    Sacramento, CA
    James is the man! I bought the majority of my gear from him.
    I did the install myself (see link in my signature):
    JL HD900/5
    JL Fix86
    JL C5-650 (front)
    JL C2-650 (rear)
    JL Stealthbox w/ 2 10tw3
    JL amp kit
    Entune harness, speaker adapters from James.
    Check out my stereo build log, i'm pretty sure i took a picture of the door with the crossover mounted. Look at the back side of the door panel and you will see what room you have to work with. I used a piece of double sided tape until i found a spot that worked, and then used a self tapping screw to secure it.
    The install took a full day (from about 9am to 6pm). It wasn't super difficult, just time consuming.
    BrownBomberTT and Y0TA PR0 like this.
  5. Mar 12, 2018 at 9:24 AM
    zwillz
    2015 sr5 Crewmax
    Yes sir he is! That guy and his communication is on point! I love that because guys like me need all the help we can get. I have all my wires already ran, so I'll just have to do all the components in the doors and then id be done. I currently have a 10 inch sub that he built already hooked up and I love it. I'm doing the C2 650 s in the front and back. So how does your system sound? I can't wait to hear mine, I bet it sounds a thousand % better than the factory crap. I didn't see a link to see your build info can you resend it, or private message me? If you have any pics or anything that would be great. I appreciate it dude!
  6. Mar 12, 2018 at 9:44 AM
    Danimal86
    Daniel
    Sacramento, CA
  7. Mar 12, 2018 at 9:58 AM
    zwillz
    2015 sr5 Crewmax
    Right now I'm running a zapco that he suggested for my sub. But I'm replacing that with a 5 Channel JBL amp. I wanted to go JL amp, but that was way out of my budget LOL. He said his JBL will be just perfect for what I'm wanting to do and run the whole system, I trust him! Yeah man, I'm excited to get this thing Rockin.
  8. Mar 12, 2018 at 10:14 AM
    Danimal86
    Daniel
    Sacramento, CA
  9. Mar 12, 2018 at 10:20 AM
    zwillz
    2015 sr5 Crewmax
  10. Mar 12, 2018 at 10:33 AM
    Danimal86
    Daniel
    Sacramento, CA
    I also went with a set of oem sail panels that have the grills for a clean look.
    A line out converter brings the signal coming from the head unit and converts it to an rca connection for the amp.
    Some amps have speaker level inputs that take the signal directly from the headunit, amplify it, and output to the door speakers. I'm guessing you will be using the speaker level inputs if James didn't set you up with a Loc.
  11. Mar 12, 2018 at 10:35 AM
    zwillz
    2015 sr5 Crewmax
    Gotcha! He may have already had, on the first time I installed my sub. I will not have to get behind the head unit on this install either, so we'll see. We'll probably get a chance to install it Sunday. The goodies arrived on Thursday.
  12. Mar 12, 2018 at 10:49 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Why C2 in the rear and not the C5?
  13. Mar 12, 2018 at 10:52 AM
    Danimal86
    Daniel
    Sacramento, CA
    c2's - $150
    c5's - $500
    Thats why.
    and you want to put your best speakers up front.
  14. Mar 12, 2018 at 10:54 AM
    zwillz
    2015 sr5 Crewmax
    Not sure, he just suggested using those and a lot of other members do the same and it works in sounds good. Like I said he's a straight-up honest guy, and I trust his judgment.
  15. Mar 12, 2018 at 10:54 AM
    fisherman951
    Tony
    2017 crewmax 4x4
    Got it.
  16. Mar 12, 2018 at 10:56 AM
    zwillz
    2015 sr5 Crewmax
    That might be it! LOL I don't need a show quality system, just a good system that sounds good that's got to be better than the stock shit!
  17. Mar 12, 2018 at 11:05 AM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    It really sucks that the third gen Tundras have such lousy JBL systems. My 08 and the three Siennas before all had 6 disc JBL systems and I thought they sounded great or fantastic for stock with cds. Are 2018 still considered third gen? And did their systems get any better or do they suck just as much? Peace. D
  18. Mar 12, 2018 at 11:06 AM
    Danimal86
    Daniel
    Sacramento, CA
    18's are still third gen.
    I cant speak from personal experience because i dont have the jbl, but the consensus is it sucks.
    zwillz[OP] likes this.
  19. Mar 26, 2018 at 7:41 PM
    Heatonrx
    Heatonrx New Member
    2018 JBL sucks. No volume after up about half way.
  20. Mar 27, 2018 at 3:23 AM
    zwillz
    2015 sr5 Crewmax
    Well it' bad all around, JBL or not. Maybe on the next redesign they step there game up. Sad for a 40k+ truck the sound system blows lol. Got my little upgrade all done and it sounds amazing. Just what I was wanting. Few pics....
  21. Mar 27, 2018 at 4:40 AM
    Heatonrx
    Heatonrx New Member
    Looks good.
  22. Jun 9, 2018 at 3:03 PM
    lawcdav1
    lawcdav1 New Member
    Tundra 4x4
    are those two 10s? Where did you get the box?
  23. Jun 10, 2018 at 5:24 AM
    Beerdude77
    Beerdude77 New Member
    2018 Silver Sky Tundra Limited TRD CM
    Linex bed, "Toyota" Console Safe
    lawcdav1[QUOTED] likes this.
  24. Aug 6, 2019 at 11:09 AM
    madphill
    madphill New Member
    I'm looking for a video guide for the James Randy Taylor audio kit install. Anyone made one?
  25. Aug 10, 2019 at 12:08 PM
    Russ389
    Russ389 New Member
    I would just like to say to the snobby audio files at stereo stores and dedicated Toyota stereo shops that they are all full of shit everyone says there’s no way you can do anything to a JBL system except change it you can’t add a sub you can’t do this you can’t do that let me Telya I went and got a kicker amplified sub snipped the blue and white wire that feed the stupid stock sub why are the amplified kicker subwoofer right into that Ran power wire to the battery and grounded it and it sounds great I don’t plan on going to any audio contest or jerking off while listening to classical music and for my purposes it’s more than enough so quit letting these guys tell you there’s nothing you can do about it
    Kwikfish and BrownBomberTT like this.
