Upgrades for the Front Differential fill/drain bolt plugs?
Discussion in '2.5 Gen Tundras (2014-2021)' started by MedCityMoto, Nov 25, 2022.
  1. Mar 14, 2024 at 6:26 PM
    MedCityMoto
    MedCityMoto [OP] SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
  2. Mar 14, 2024 at 6:39 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    That one definitely looks a little different than the ones I posted pics of earlier in this thread. Where did you buy them from?
  3. Mar 14, 2024 at 7:43 PM
    MedCityMoto
    Ugh, Scamazon. I should know better by now. The listing and seller is gone now, shocker right? Gotta go right to the source for OEM parts these days.
    TILLY[QUOTED] likes this.
  4. Mar 14, 2024 at 7:49 PM
    TILLY
    Massachusetts
    Live and learn, but thanks for pointing out the fakes out there. :thumbsup:
  5. Sep 3, 2024 at 6:55 AM
    bucketlintels02
    bucketlintels02 Newish Member
    NW Georgia
    2021 Tundra TRD-Pro Crew
    RAS Road-Active Suspension System HD. 2" (estimated) Spacer and Block Lift . S&B CAI - closed VLED Footwell lighting MESO Customs Interior Lighting 285/65/18 KO2 Gator Hard Cover Tri-Fold AJT Designs interior trim CSU 9 - year ceramic coating Rigid Amber Fog Covers Full Tint (70% Windshield) 20% all others.
    Is there not the same concern with replacing the oil pan drain bolt with a Fumoto valve that is non-magnetic?
  6. Apr 17, 2025 at 7:02 PM
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Can someone sum up what the Lexus part numbers are for the drain plugs? Is there a front and rear diff plug? What about the transfers case? Had dealer do this change at 30k. Want to do it myself this time. Thanks.
  7. Apr 28, 2025 at 7:11 AM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Does anyone the thread pitch for the front and rear differential drain and fill plugs? I want to get some gold plugs installed
  8. Apr 28, 2025 at 7:18 AM
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    are the gold plugs better than the factory plugs? Factory plugs are magnetic.
    I wrote this one down a while back. The transfer drain plug is Gold Plug IP-04, since factory plug in TC is not magnetic.
  9. Apr 28, 2025 at 7:38 AM
    Js18tundra
    They are stainless steel and would get rid of the 10mm Allen up front, and they have stronger magnets.
  10. Apr 28, 2025 at 7:44 AM
    Js18tundra
    I know the front drain plug is a different size, but I think the rear drain and fill, and the front fill are the same?
  11. Apr 28, 2025 at 4:49 PM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    I know that they take the same crush washers and the front drain is different size and copper..
