Upgraded trans cooler
Discussion in '1st Gen Tundras (2000-2006)' started by Baller, Jun 27, 2019.
  1. Sep 8, 2020 at 6:50 AM
    #211
    swampshark
    swampshark New Member
    south la
    2020 MGM SR5
    Hmmm....so on a 4hr drive over the weekend, 85 outside temp, 70-75mph...my temps held steady at 217 pan / 219 converter; not towing anything pretty much flat hwy...2020 SR5-TSS package. What should normal temps be or is that normal?
  2. Sep 8, 2020 at 6:53 AM
    #212
    swampshark
    south la
    2020 MGM SR5
    Forgot to mention....drove in "D" with no Tow-Haul
  3. Sep 8, 2020 at 7:55 AM
    #213
    Professional Hand Model
    Hand Protectors
  4. Sep 8, 2020 at 9:03 AM
    #214
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Have you seen the threads about Toyota ditching the transmission coolers starting in 2019? A lot of people on here are pissed at their decision. I would not be happy with my truck consistently running over 200 all the time. That's going to lead to unnecessary wear and tear.
    I would jump over to the 3rd gen section to get more relevant info on your 2020.
    https://www.tundras.com/threads/2019-2020-transmission-cooler-missing.72484/
    https://www.tundras.com/threads/19-20-discussion-on-missing-ambient-cooler.73176/#post-1876176
    Pucks18, bmf4069 and Casper421 like this.
  5. Sep 8, 2020 at 10:58 AM
    #215
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  6. Sep 8, 2020 at 1:14 PM
    #216
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Not sure what the newer gens run temp wise but ideal trans temp is 170* +/- 25*.
    My other truck (2016 2500HD Duramax) on a four hour drive only would get up 140. Obviously a completely different truck setup for towing from the factory but I thought it was interesting anyways.
  7. Sep 8, 2020 at 6:06 PM
    #217
    tvpierce
    tvpierce Formerly New Member
    Maine
    For clarification, I'm going to ditch the overdrive terminology (because the gear ratio of the tallest gear isn't germain to this conversation) and say our trucks have a 4 speed transmission with a locking torque converter.
    When you put the gear selector in "D" with the OD Off not selected, the transmission shifts 1 - 2- 3 - 4, then locks the TC. When you press harder on the accelerator requiring a downshift, the TC unlocks and the transmission shifts from 4th to 3rd. If you remain in 3rd at about 45 mph and depress the OD Off button, the tranny stays in 3rd gear, but the TC locks back up. So the RPM will actually be lower with the OD Off activated than if it was not activated.
    If you start from a stop with OD Off activated, the tranny will shift 1 - 2 - 3, then lock the TC.
    That's why it's benefitial to activate OD Off when towing: it allows the TC to lock in 3rd gear -- which wouldn't happen if OD Off was not activated.
    03SR5 and bmf4069 like this.
  8. Sep 8, 2020 at 6:23 PM
    #218
    Baller
    Baller [OP] New Member
    '05 Tundra SR5 DC
    I’ve got an ‘05 and it is definitely a 5sp auto. Gear ratios are:
    1st - 3.52
    2nd - 2.04
    3rd - 1.40
    4th - 1.00
    5th - 0.72
  9. Sep 8, 2020 at 7:02 PM
    #219
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Does the scenario change if one is gling 65 instead of 04? I can promise you my RPM's are not lower when I press that button at 65.
  10. Sep 9, 2020 at 4:07 AM
    #220
    tvpierce
    Maine
    I would assume it's not the same at 65 mph because the engine and transmission are loaded much differently in that scenario. I don't know the intricacies of this transmission, like the shift points and the electronic logic controls -- for instance, is there an RPM threshold over which the TC won't lock? I'd love to see those specs if they were available. I do understand generally how they operate, and how to recognize what they're doing and when they're doing it.
    FirstGenVol[QUOTED] likes this.
  11. Sep 9, 2020 at 4:09 AM
    #221
    Hand Protectors
    The FSM is pretty good at explaining the shift to RPM ratios (throttle position). There is even a nice chart. I put it up a while back in another thread.
  12. Sep 9, 2020 at 5:12 AM
    #222
    tvpierce
    Maine
    Thanks.
    I’ll have to dig that up.
  13. Sep 26, 2020 at 7:34 AM
    #223
    912
    912 @best_gen_tundra
    Fulltime RV traveler
    2005 DC 4x4
    @SouthPaw and others, when you added the Hayden and Derale, did you bypass and cap off the trans lines to the factory radiator?
  14. Sep 26, 2020 at 8:52 PM
    #224
    SouthPaw
    2000 Limited 4x4 AC
    Nope, only replaced the external cooler but kept everything else OEM. For anyone considering this, Hayden has recently released a cooler with a built in fluid controller. If I had to do it all over again, this would be the route I’d take.
    https://www.haydenauto.com/en/produ...oil-coolers/patented-internal-by-pass-coolers
  15. Sep 28, 2020 at 11:35 AM
    #225
    Baller
    '05 Tundra SR5 DC
    :cheers:
    I may have just missed it, but I'm not seeing the by-pass temp. Is it 180, like most?
  16. Sep 28, 2020 at 11:37 AM
    #226
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  17. Sep 28, 2020 at 11:56 AM
    #227
    Baller
    '05 Tundra SR5 DC
    By-pass vs thermostat, pretty much the same things. To answer your question, yes.
    SouthPaw likes this.
  18. Sep 28, 2020 at 2:28 PM
    #228
    SouthPaw
    2000 Limited 4x4 AC
    Si.
    I didn't see it but I assume it's at 180*.
  19. Sep 28, 2020 at 5:20 PM
    #229
    Hand Protectors
    So far, I’m coming to the conclusion that a new cooler is not necessary for me in HOT weather so much. Even when towing long distance the temps are not bad. I really like the idea of the cold weather automatic by pass built in (or even the thermostat option) which helps the transmission come up to temp quicker in winter.
    My original doubts were the cooler making things too cool. The bypass/stat option sound like a winner. Better for MPG in winter I bet with the trans fluid getting warm quicker helping with friction.
  20. Oct 12, 2020 at 7:20 PM
    #230
    empty_lord
    Indiana, Chicagoland
    05 rollover special
  21. Oct 12, 2020 at 7:55 PM
    #231
    SouthPaw
    2000 Limited 4x4 AC
    Who is going to be first?
    I’m still extremely happy with mine especially on the cooler mornings. Trans warms up quick and it never hits above 185*. I’ll probably eventually make some mounting brackets for it but it’s been working great.
  22. Oct 12, 2020 at 8:02 PM
    #232
    empty_lord
    05 rollover special
    I might for the hell of it. The rebuilt trans in the f-350 is likely going to get the 30k cooler now that It’s got a $3000 built trans.. lol
  23. Oct 13, 2020 at 9:00 AM
    #233
    Baller
    '05 Tundra SR5 DC
    Kongap likes this.
  24. Oct 13, 2020 at 10:21 AM
    #234
    Kongap
    Kongap New Member
    2004 SR5 DC
    No love for DC* lol
  25. Oct 13, 2020 at 10:23 AM
    #235
    Baller
    '05 Tundra SR5 DC
    :censored:
    Kongap[QUOTED] likes this.
  26. Oct 13, 2020 at 11:22 AM
    #236
    empty_lord
    05 rollover special
    Well since my custom radiator has noticeably dropped trans temps I ordered the factory trans cooler lines and am going to run the stock cooler I picked up cheap. Probably end up ordering the CSF
  27. Jun 1, 2021 at 3:21 PM
    #237
    2006 Tundra AC
    2006 Tundra AC Slowly upgrading my grandfather's old truck
    Andrew
    Cedar Park, Texas
    '06 desert sand 4.0 V6
    Alumas, Alcans, TuRD Pro wheels, 285/70/17 Falken
    Hey guys,
    I know I'm resurrecting an old thread. My truck is a 2006 with 4.0 V6 without a towing package. I went through this thread and I didn't see anyone installing a cooler on a truck that didn't already have the towing package. My question is, Does my transmission already have hookups for a trans cooler? Do I have to install new lines from the trans to the cooler? If so, how do I install those lines?
  28. Jun 1, 2021 at 4:31 PM
    #238
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I'd be surprised if you don't have the lines already running to the radiator. If you have those, you can put a cooler either before or after the radiator. I don't know which is beast.
  29. Jun 1, 2021 at 4:37 PM
    #239
    Baller
    '05 Tundra SR5 DC
    I'd think after the radiator would be best for maximizing getting cool fluid to the trans.
  30. Jun 1, 2021 at 4:58 PM
    #240
    2006 Tundra AC
    Andrew
    Cedar Park, Texas
    Thanks guys,
    I will check for some lines coming out of the trans in the morning. Does the trans need more fluid after I install a cooler?
