Upgraded trans cooler
Discussion in '1st Gen Tundras (2000-2006)' started by Baller, Jun 27, 2019.
  1. Sep 3, 2020 at 5:12 AM
    #181
    Professional Hand Model
    Hand Protectors
    Yesterday, I drove about 45 minutes consecutive.
  2. Sep 3, 2020 at 10:05 AM
    #182
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    When I go up I-70 my trans temps climb to the mid 190's on sections, never gets over 200 though. It would spike on the steep sections then go down to 180, but rarely below 180 climbing out of Denver. Commuting up and down I-25 in stop and go it's usually around 160-170 (summer driving)
    This was on my previous stock 01 and not towing.
    SouthPaw[QUOTED] likes this.
  3. Sep 3, 2020 at 10:10 AM
    #183
    mtndds98
    mtndds98 New Member
    2013 Silver Tundra CrewMax
    6" ProComp Stage 1 lift
    Does anyone know if the 2013 model year Tundra comes with a transmission cooler? Asking for a friend. Haha.
  4. Sep 3, 2020 at 10:15 AM
    #184
    Hand Protectors
  5. Sep 3, 2020 at 10:36 AM
    #185
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    After 2010, if a Tundra has an auxiliary transmission cooler, it is packaged as the top section of the AC condenser. The most obvious tip-off is a wad of transmission fluid hoses behind the passenger side grille that connect to the top of the AC condenser.
  6. Sep 3, 2020 at 10:50 AM
    #186
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
  7. Sep 3, 2020 at 12:11 PM
    #187
    Hand Protectors
  8. Sep 3, 2020 at 12:18 PM
    #188
    Baller
    Baller [OP] New Member
    '05 Tundra SR5 DC
    :amen:
  9. Sep 3, 2020 at 2:41 PM
    #189
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Good to know because that is the highway I am referring to. Up Berthoud pass, it got a little warmer but never broke 200*.
  10. Sep 4, 2020 at 3:38 PM
    #190
    Hand Protectors
    85° and dry heat here today. 40 minutes driving averaging 30-35 MPH in steady driving style. Only a few stops here and there.
    Here is the read out at the end of the drive.
  11. Sep 5, 2020 at 9:36 AM
    #191
    SouthPaw
    2000 Limited 4x4 AC
    I’d like to see the readings after two or more hours of driving. If anyone the OEM setup and can provide some temp readings after a good drive, that would be awesome.
  12. Sep 5, 2020 at 10:21 AM
    #192
    Hand Protectors
    I’ll have a nice long highway drive reading coming up in a few weeks that incorporates towing with weight on mild inclines. This drive will be my deciding factor. I’d love to see others readings to compare like you suggest.
  13. Sep 5, 2020 at 10:48 AM
    #193
    Gmillz85
    Gmillz85 Ski Bum Extraordinaire
    greg
    2004 Salsa Red AC 4x4 Pro Edition
    She's a Pro
    I drove down to Buena Vista last week with the slide in camper. Up Kenosha I saw 209* with 75* air temps once. It only happened towards the last 1/2 mile of the 6 mile climb, once I crested the pass I never saw higher than 185* the rest of the way to BV at 65mph.
  14. Sep 5, 2020 at 10:51 AM
    #194
    Hand Protectors
    You have the OEM Tow Package Original Trans Cooler?
  15. Sep 5, 2020 at 10:51 AM
    #195
    Gmillz85
    greg
    She's a Pro
    Forgot to mention on the reverse route home I only hit 187* on the backside of Kenosha and never saw higher than 170* the rest of the way home with similar air temps.
  16. Sep 5, 2020 at 10:53 AM
    #196
    Gmillz85
    greg
    She's a Pro
    This I do. I'm also due for an AT fluid drain and add. I plan to do three fluid swaps over the next few months before winter rolls in.
  17. Sep 5, 2020 at 11:00 AM
    #197
    Hand Protectors
    Thank you. This is good info from you. Your Kenosha drive is steeper than anything I’ll ever do. I feel real good with the OEM Cooler right now.
    Gmillz85[QUOTED] likes this.
  18. Sep 5, 2020 at 1:46 PM
    #198
    SouthPaw
    2000 Limited 4x4 AC
    This is the info I curious to see. I drive my truck to/from the gym every morning (about 5 miles each way) and to/from work (20 miles each way) and the trans barely starts creeping into the low 50’s and that’s with my current setup blocking off the external cooler. The longer drivers obviously bringer higher temps that’s what I would like to compare to. My current setup will not go above 185* no matter how hard I pushed it. It’s pretty slick now that it’s all dialed in.
    fighthedude and Gmillz85[QUOTED] like this.
  19. Sep 5, 2020 at 3:11 PM
    #199
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I hit 204 in deep sand today. New high score!!
    SouthPaw, Casper421 and Gmillz85 like this.
  20. Sep 5, 2020 at 3:24 PM
    #200
    Gmillz85
    greg
    She's a Pro
    For $50 I'd like to get around to this someday. Maybe before next summer begins.
  21. Sep 5, 2020 at 4:39 PM
    #201
    SouthPaw
    2000 Limited 4x4 AC
    I used the excuse that my old one was rock chipped to convince myself to do it. For $100 total (cooler and 13011), I think it’s a fairly cost effective mod. It’s only a few hose clamps and time, so you aren’t out much anyways.
    Now that I understand it a little more, I’m glad I made the switch. I’m sure there were times my temps were above 200* which was not ideal for me. Now it will get warm in the winter months and stay cool in the summer time.
    Jerry311SD and FirstGenVol like this.
  22. Sep 7, 2020 at 1:13 PM
    #202
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I now understand why you should lock out o/d when towing. Why does unlocking the torque converter cause temps to climb so much? I'm riding shotgun while my wife drives the last stretch home. We just hit 204 while climbing a mountain. As soon as I had her turn off o/d the temp dropped 15 degrees.
  23. Sep 7, 2020 at 4:13 PM
    #203
    Baller
    '05 Tundra SR5 DC
    Slippage creates heat.
    On another note, I thought I remember on these Tundras, the “Tow Mode” only doesn’t shift into OD. It has nothing to do with trans lockup. I really think in the lower gear, the engine isn’t working as hard. That’s all it is. In my Cadi, the “Tow Mode” actually changes shifting points and effects lock up. It’s a tougher drive, but it’s WAY better when towing. The “Tow Mode” on these First Gens seems kind of hokey to me.
    FirstGenVol[QUOTED] likes this.
  24. Sep 7, 2020 at 4:30 PM
    #204
    Hand Protectors
    The 2002 does not have a Tow Mode.
    The O/D button on the stalk reduces the RPM in 2nd and 3rd gears. Heat is not a problem in O/D unless the gears start toggling in and out of 3rd/4th gears. This happens when towing/hauling a load going up inclines or with strong head winds. Thats when O/D needs to be turned off.
    The 05 06 Tow Mode eliminates/induces 1st gear when activated/deactivated from readings. I do not know as I do not have one, but yes that does seem hokey.
  25. Sep 7, 2020 at 4:56 PM
    #205
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I don't think that's right. It was previously stated the torque converter will unlock at a certain engine load but it doesn't downshift. I'm sure you've noticed this. So today, going up that incline the t.q was unlocked and creating heat. Once we turned off o/d the truck downshifted to 3rd. So heat absolutely was a problem in o/d.
    Unlock might not be the right word but I know something happens with it. You can hear and feel the change. This is different from it downshifting.
  26. Sep 7, 2020 at 8:26 PM
    #206
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    When the converter is locked the engine is directly connected to the transmission. When the torque converter is unlocked the vanes in the converter are hydraulically transferring the motion of the engine to the transmission hence the head.
    basically lockup the converter is doing nothing.
  27. Sep 8, 2020 at 3:27 AM
    #207
    tvpierce
    tvpierce Formerly New Member
    Maine
    I covered this in a thread a while back.
    https://www.tundras.com/threads/regarding-od-off-and-towing.72459/#post-1861319
    Here's a good experiment you can try: With the transmission in OD (OD Off button not activated) drive at a steady 40-45 mph on flat road and you'll be in 4th gear with the TC locked. When you get to a fairly steep incline, the transmission unlocks the TC, and downshifts from 4th to 3rd. Let that happen while maintaining 40-45 mph. Then push the OD Off button in. What happens is that the TC locks back up, so you'll notice the RPM drop slightly. Push the OD Off button again (deactivating it), the transmission won't shift into 4th because you're still maintaining 40-45 mph, but the TC unlocks, causing the RPM to rise slightly.
    So if the incline is a pretty long one, you can sit there locking and unlocking the TC by toggling between OD-Off and OD-On. If you have the equipment to measure the trans temp, you'll see the temp go up when the TC is unlocked and down when it locks.
  28. Sep 8, 2020 at 5:36 AM
    #208
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Ok. I didn't realize both occured. I didn't realize that by it unlocking it automatically shifted to 3rd gear.
    Thats not what I experience. In that exact situation the RPM jumps and the truck downshifts. I assume going into 2nd which I mistook for 3rd previously.
    Yesterday, going up that long steep grade I felt the T.Q unlock and temps went way up. Once I pushed the o/d button the truck downshifted and maintained a higher RPM so it could maintain speed on that grade.
    That's exactly what happened. Temps went from 204 to 190 then eventually back down to 160.
  29. Sep 8, 2020 at 6:03 AM
    #209
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    So my mistake PHM. Reading your post again it seems like you're trying to say the same thing as TVpierce.
    The only part I disagree with(or haven't experienced) is that hitting the O/D button will reduce RPM's. As soon as I push the button the truck downshifts and RPM's jump because I'm maintaining the same speed but in a lower gear. I don't want to derail this thread any more though. Carry on.
  30. Sep 8, 2020 at 6:39 AM
    #210
    Hand Protectors
    I tried your experiment driving on flat earth at 55mph. My transmission temps did not reflect any changes. No tow or haul. Just regular driving. I also tried the experiment at lower speeds without a noticeable change. Haven’t had the opportunity to try in towing/hauling up inclines, but I’m sure there would be some observational change.
