Upgraded head unit that looks stock
Discussion in 'Audio & Video' started by Bradyboyy88, Mar 29, 2022.
  1. Aug 8, 2022 at 8:19 PM
    #121
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    This is the one I used for the front. There are a lot of mounting options available but it’ll depend on your grille
    NOAUKA Waterproof IP68 Night Vision 170 Degree Car Rear View/Reversing/Reverse Camera Universal Color CMOS Imaging Chip Backup Parking HD Front View Camera https://www.amazon.com/dp/B06XNM7GNS
    nhw544 and panicman[QUOTED] like this.
  2. Aug 8, 2022 at 11:05 PM
    #122
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Ordered!!
  3. Aug 11, 2022 at 7:53 AM
    #123
    nhw544
    nhw544 Food fight!
    RVA
    2019 Black Tundra 4x4 Sport
    Where are you guys running the gps antennae to? Just pulled everything out the box and trying to get stuff in the right places.
  4. Aug 11, 2022 at 7:56 AM
    #124
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Do you have a stock GPS antenna? I used the STO2 adapter pack to retain the factory GPS/SXM antennae
    The stock one should be stuck to the underside of the dash towards the front left of the truck. If you don't have one, there should be a spot in that area that will work.
  5. Aug 11, 2022 at 8:02 AM
    #125
    nhw544
    nhw544 Food fight!
    RVA
    I currently have Sirius xm, so would that mean I have a gps antennae? Sorry electronics is not my thing. I’m already overwhelmed but the amount of wires I pulled out of the box.
  6. Aug 11, 2022 at 8:06 AM
    #126
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    You more than likely do. I can't remember what the connector color is, but it's one of the single cables coming down from the top of the dash. I'll see if I can find a pic.
    nhw544[QUOTED] likes this.
  7. Aug 11, 2022 at 8:34 AM
    #127
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Just go slow - there are a lot of wires, but once you find the ones you need for your install, it's not too bad. If you have any questions about it, just snap a pic and post it here and one of us should be able to point you in the right direction.
  8. Aug 11, 2022 at 8:36 AM
    #128
    panicman
    Eric
    Here is what the adapter looks like:
    I’ll try to keep an eye on this thread, so if you run into a jam or get frustrated, circle back here and get help.
    nhw544[QUOTED] and TRDFerguson like this.
  9. Aug 11, 2022 at 9:01 AM
    #129
    nhw544
    nhw544 Food fight!
    RVA
    Appreciate it, fellas. So I noticed you guys got the TO2. Crutchfield de t me the PI01. Hope it’s right.
    Had to go get my daughter from camp so I’m gonna tackle this after lunch. I’ll post if I need some help.
    TRDFerguson and AZBoatHauler like this.
  10. Aug 11, 2022 at 9:12 AM
    #130
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    The sTO1 is just the satellite radio antenna adapter, not the other 2 that @panicman showed. It's not a huge deal, as you can just use your aftermarket GPS antenna instead.
  11. Aug 11, 2022 at 10:36 AM
    #131
    nhw544
    nhw544 Food fight!
    RVA
    What’s the consensus on install; install the unit without the screen or have it all together and install?
  12. Aug 11, 2022 at 12:29 PM
    #132
    nhw544
    nhw544 Food fight!
    RVA
    Also, Crutchfield said to mount the gps antennae and xm antennae on the dash, which I really don’t want to do. Any success with mounting it underneath without any troubles?
  13. Aug 11, 2022 at 4:51 PM
    #133
    nhw544
    nhw544 Food fight!
    RVA
    Alright got everything in. Couple of issues so far. I have no backup camera. My miles to empty in my cluster display shows low fuel even though I just filled up. Any ideas?
  14. Aug 11, 2022 at 4:57 PM
    #134
    AZBoatHauler
    So.Arizona
    Remind me what HU you are installing? Look for a camera interrupt option in the setup menu and make sure it’s selected. You can also look for a camera menu to see if you can manually pull it up and see if your connection is good.
  15. Aug 11, 2022 at 5:00 PM
    #135
    nhw544
    nhw544 Food fight!
    RVA
    It’s the Pioneer 7600NEX. I went through the basic settings and didn’t see anything. The camera input was on.
  16. Aug 11, 2022 at 6:02 PM
    #136
    AZBoatHauler
    So.Arizona
    Assuming you connected the adapter to the factory harness and plugged it into the RCA…
    I’ll pull up that menu on mine in a sec.
  17. Aug 11, 2022 at 6:11 PM
    #137
    AZBoatHauler
    So.Arizona
    When I hit menu then setup I get a camera option. Then I can get to the interruption option.
    Assuming all that checks out - check the purple and white wire on the harness.
    HulkSmurf14 likes this.
  18. Aug 11, 2022 at 6:24 PM
    #138
    nhw544
    nhw544 Food fight!
    RVA
    Ok I’ll check the settings in the morning. I’m done for the night lol.
    I don’t recall plugging in an rca connection, so that could be the issue. I just don’t recall there being a spot for an rca connection, but it was a long, hot day so it’s all fuzzy right now. Thank you for the suggestions, I’ll report back tomorrow. Gotta be at the firehouse tomorrow, so if I get some downtime there I’ll pull it back out.
  19. Aug 11, 2022 at 6:27 PM
    #139
    AZBoatHauler
    So.Arizona
    should be one of the yellow females.
  20. Aug 11, 2022 at 6:30 PM
    #140
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    It’s the brown one I think. One of the yellows can be used for the front cam input.
    AZBoatHauler[QUOTED] likes this.
  21. Aug 11, 2022 at 6:36 PM
    #141
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    What steering wheel control kit did you end up using? I think Crutchfield does the Crux for free, but a lot of us opted to upgrade to the Maestro RR. Either way, there should be an RCA for the rear camera on it
  22. Aug 11, 2022 at 7:09 PM
    #142
    nhw544
    nhw544 Food fight!
    RVA
    Yeah I definitely didn’t plug in an rca, so that’s gotta be it. Thank you guys for the help. So am I plugging in the brown rca to something off the factory harness?
    @TRDFerguson I got the Maestro RR with TO2 harness.
    TRDFerguson[QUOTED] likes this.
  23. Aug 11, 2022 at 7:13 PM
    #143
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    There should be an RCA on the Maestro harness marked rear camera or backup camera that you would plug into the brown rca from the head unit.
    Good call on going with the Maestro. You won’t be missing any features from the stock head unit.
    nhw544[QUOTED] and AZBoatHauler like this.
  24. Aug 11, 2022 at 7:43 PM
    #144
    nhw544
    nhw544 Food fight!
    RVA
    Ok cool. I’ll pull it tomorrow or Saturday and check.
    Would you happen to have any thoughts on why my fuel level shows “low fuel” in my cluster display? I flashed the Maestro before installing. Is there something else I need to do? I can also call their tech support tomorrow if needed.
  25. Aug 11, 2022 at 7:45 PM
    #145
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Try disconnecting your battery for 10-15 mins. I remember something weird happening to my truck like that but it was a couple years ago and removing power for a bit cleared it up.
  26. Aug 11, 2022 at 8:03 PM
    #146
    nhw544
    nhw544 Food fight!
    RVA
    Ok thanks. I’ll try that too!
  27. Aug 12, 2022 at 12:25 PM
    #147
    nhw544
    nhw544 Food fight!
    RVA
    I guess I just needed to drive it. On the way in to work this morning, it reset itself and shows an actual number.
  28. Aug 13, 2022 at 6:25 PM
    #148
    TundyFromDownUndy
    TundyFromDownUndy New Member
    2020 Platinum Tundra
    How much did that run you? And can you watch movies on it?
  29. Aug 14, 2022 at 4:52 PM
    #149
    nhw544
    nhw544 Food fight!
    RVA
    Alright so I pulled it back out and connected the rca connections that were labeled for the backup camera. Still nothing. So I traced the wire back and found this plug not plugged into anything. Does this plug into the white plug with an adaptor? Did I miss a step?
  30. Aug 14, 2022 at 5:37 PM
    #150
    panicman
    Eric
    It is so hard to know from a picture.
    that looks like the small harness that plugs into the Maestro, as in my bench photo of the harness mated to the maestro:
