Upgrade to a Powertrac LSD
Discussion in '2.5 Gen Tundras (2014-2021)' started by pursuit2550, Apr 16, 2024.
  1. Apr 16, 2024 at 2:32 PM
    pursuit2550
    pursuit2550 [OP] New Member
    2020 Tundra SR5 Maggie 1900
    I probably know the answer to this but still asking. I will adding a SC soon and was looking to also do a LSD. Now I will be staying the OEM gear ratio and only adding a Powertrac. Since the gears will not change, do I still need to do all the shimming and preload stuff? I had it done a long time ago to a GM rear but I did a LSD and gears, so shimming and preload was a must.
  2. Apr 17, 2024 at 4:05 AM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Toyota 3rds use spanner nuts to adjust preload/backlash. The only shims are for pinion depth.
    pursuit2550[OP] likes this.
  3. Apr 17, 2024 at 5:59 AM
    blenton
    blenton New Member
    It depends but the answer is to plan on it. I installed an Auburn LSD 6 or 7 years ago and my installer was able to reuse everything including the factory shim setup. It is still alive and kicking but I have a Powertrax waiting to go in. I have a feeling my recently installed supercharger may put an end to the Auburn.
    pursuit2550[OP] and snivilous like this.
  4. Apr 18, 2024 at 10:42 AM
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    Tundra rear diff if all you’re doing is replacing the carrier, then just adjust carrier bearing preload and adjust backlash. The lash and preload use shims. Many times you can simply reuse factory shims, but you need to be prepared to make an adjustment. If you reuse oem bearings, then don’t go over 5”#’s of carrier preload. 2-3”#’s would be ideal. Then adjust lash to about 8 thousandths. New bearings, 6-8”#’s is ideal and lash about the same. Only time you would need to adjust pinion depth is if you replace the pinion bearings. Even then, the factory shim will probably be spot on. But you will need to adjust the shimming on the solid collar. Contact ECGS for any shims and bearing help
  5. Apr 18, 2024 at 11:26 AM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    this is true for the 8” diffs, but not 8.4’s or the 10.5’s along with plenty of other Toyota diffs that use shims for carrier preload
    ViktorG likes this.
  6. Apr 18, 2024 at 9:28 PM
    Js18tundra
    this is a 10.5 third member… it has adjusting nuts for carrier preload…
  7. Apr 18, 2024 at 9:36 PM
    Js18tundra
    The 8.4 and the e locked 9.5 diff in the cruisers are the only ones I’m aware of that use shims instead of adjusters, I’m sure there are others
  8. Apr 19, 2024 at 6:24 AM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
  9. Apr 19, 2024 at 6:25 AM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
  10. Apr 19, 2024 at 6:29 AM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
  11. Apr 19, 2024 at 6:30 AM
    ViktorG
    ViktorG Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    Tundra 10.5 uses shims, did mine a couple years ago.
  12. Apr 19, 2024 at 6:30 AM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    that’s not a tundra 10.5 diff. That’s probably an LC diff
  13. Apr 19, 2024 at 6:32 AM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    That Tundra diff is heavy, especially after you put a traction device in it.
    ViktorG[QUOTED] likes this.
  14. Apr 19, 2024 at 6:32 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR / Austin, TX
    Thanks for clarifying, I thought this was the case, but not sure enough to refute the above comment.
  15. Apr 19, 2024 at 6:41 AM
    Js18tundra
    Ahh, you’re right my bad, I wonder if it’s stronger than the spanner nut style
    ViktorG likes this.
  16. Apr 19, 2024 at 11:11 AM
    texoma
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    Yes, I’d say you can get better results from shimming than from the adjusters. The adjusters are easier to set up, but they can still have a chance to move a bit. Not much, but a little bit.
