Updated or upgraded brakes for 2002 tundra
Discussion in '1st Gen Tundras (2000-2006)' started by ColoMtnMan, Nov 7, 2017.
  1. Nov 7, 2017 at 10:42 PM
    ColoMtnMan
    ColoMtnMan [OP] New Member
    2002 Tundra Access cab 4x4 Limited
    Greetings, New to the forum but have been a Tundra owner since 2003. I just replaced my 2000 Tundra, v8 access cab 4x4 with 263k miles with a 2002 Limited 4x4 access cab with 92k. My old tundra had the brake update done by Toyota but my new one was never updated. In general it seemed that even the original updated brakes developed hot spots fairly quickly. Does anyone have an aftermarket brake kit that they have put on that they have been happy with that lasts longer and doesn't develop hot spots so readily?
  2. Nov 8, 2017 at 11:54 AM
    Bob
    Bob Member Staff Member
    Bob
    07 Tacoma PreRunner Black
    Bumpo for a late night post
  3. Nov 9, 2017 at 9:15 PM
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
  4. Nov 13, 2017 at 7:04 PM
    Newbie1853
    Newbie1853 New Member
    Carolyn
    I'm kind of looking at a 2000 RWD with 225k miles. This would be my first Tundra. You mentioned Toyota updated the brakes on your 2000. How can I find out if this truck had the update. Was it a recall? Will Toyota still do it at this point?
  5. Nov 19, 2017 at 11:33 PM
    Rkcruza
    Rkcruza New Member
    Bob
    2002 Tundra AC 4WD TRD OR SR5
    De Badged / Decaled, Firestone Ride Rite Air Bags w/ Daystar Cups, 17" Rims, Big Brake kit w/ slotted & drilled rotors, plus lots of work related stuff.
    I have an 02 with the factory update....still ate brakes every 15k miles. Last time around we did slotted / drilled rotors and EBC pads.....30k and still going strong.
    Note: this is a work truck so it is maxed much of the time and I live in the mountains so lots of hills and twisty stuff.
  6. Dec 18, 2017 at 7:33 AM
    AntiArrhythmic
    AntiArrhythmic New Member
    Do the 05-06 front brakes bolt on?
