UPDATE: Icon Tundra Stages Explained
Discussion in 'ICON Vehicle Dynamics' started by Icon_Adrian, Feb 21, 2018.
  1. Feb 22, 2018 at 3:22 PM
    Icon_Adrian
    Icon_Adrian [OP] New Member Vendor
    Adrian
    Riverside CA
    2004 Tacoma Pre-Runner
    LT Front and Rear
    @KevinK know's Icon Products well. Thank you sir.:thumbsup:
    blue16 and KevinK[QUOTED] like this.
  2. Feb 22, 2018 at 3:26 PM
    Icon_Adrian
    Adrian
    Riverside CA
    LT Front and Rear
    Our RXT system sounds like it would be a good fit for your application with the added weight.
    http://iconvehicledynamics.com/shop...ta-tundra-multi-rate-rxt-leaf-spring-kit.html
    An option to consider.
  3. Feb 22, 2018 at 3:33 PM
    TexasTundra27
    TexasTundra27 Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
    It’s one that I’m considering, I like that it has the capability to be played with for the right setup and performance. Currently building up my wife’s FJ or I’d probably already have it...
  4. Feb 22, 2018 at 4:48 PM
    [DELETED]
    [DELETED] New Member
    Jeff
    Thanks.
  5. Feb 22, 2018 at 4:55 PM
    itsdchz
    itsdchz 50statesoverland
    Clovis, CA
    2018 SR5 CM Cement 4x4
    Icon, UCAs, Method, SSO, KB VOODOO, Skids and Sliders
    I’m a little concerned with the feedback from the leaf packs. I specifically got this kit because of the perception imposed that it will undoubtedly keep my bed level when towing my 4500lb trailer. Now, after this thread I’m concerned with applying the Baja truck look, when I was trying to avoid the sag...
  6. Feb 22, 2018 at 5:17 PM
    TexasTundra27
    Mark
    I didn’t sag much, Icon specifically told me (after I bought and installed them) that the expansion packs aren’t made to carry a bunch of weight. To me it rides just like the stock leafs do. I towed this FJ about 4.5hrs, didn’t sag much but hell I live on the overload already. I guess what I’m trying to say is these essentially perform like the stock leafs, and if you don’t carry much weight around at all you will get a bit of lift out of them. But like @Icon_Adrian said earlier, their new RXT leaf pack looks pretty promising and has the capability to be swapped around to your liking and needs.
  7. Feb 22, 2018 at 9:47 PM
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    We did about 3 months of research before deciding on the Icon stuff. We like that you guys are the only manufacturer who makes the shocks, control arms and springs all together as a unified system designed specifically for the Tundra.
    1UPPER, azTony, TheBeast and 2 others like this.
  8. Feb 23, 2018 at 5:26 AM
    Broncobroke
    Broncobroke Super White Power
    Charlie
    Piedmont, NC
    2017 White Tundra 1794
    "one of his greatest bits of advice is 'Plan your build as far as you can foresee. Try to envision your end goal and just keep working towards that."
    "Can’t say I have ever heard “dammit, I purchased to much shock...should have went smaller”, but I have heard “crap, I purchased to small of a shock and need bigger...” a lot."
    Two of the most important things I have read on this forum. And there is a wealth of knowledge and information. Like you I really the idea of a unified system....decisions, decisions. We will not make Sedona this year, but it is definitely and end goal for 2019.
    Thank you for your help and guidance. I am sure they will be more questions.:help:
    KevinK likes this.
  9. Feb 23, 2018 at 5:26 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Just to clarify, at least from my side, I'm only running the enhancement pack not the rxt package. It's not the full replacement Leaf pack it's the three leaf pack that replace is everything except for the main and the overload Leaf if you decide to keep it.
    But with that said it would make me really curious how the rxt package leafs hold up...
  10. Feb 23, 2018 at 6:11 AM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    @KevinK knows them well because he could prolly build them if he had time, and because he has everything ICON makes under each wheel well......except smooth bodies :cool:
  11. Mar 6, 2018 at 6:14 PM
    Theonlyway
    Theonlyway New Member
    User
    What are the big differences between the 2.5 pb and the omega rear?
  12. Mar 6, 2018 at 6:19 PM
    KevinK
    Tundras to Sedona
    The piggyback has a single adjuster that changes the compression damping for the entire stroke of the shock. This is pretty nice.
    The omega is a bypass shock that has compression and rebound adjustment for the ride zone (the middle portion of the stroke, between the black bands). This is awesome.
  13. Mar 6, 2018 at 6:25 PM
    Theonlyway
    User
    So are the 30 settings on one knob or is this 2 knobs?
  14. Mar 6, 2018 at 7:01 PM
    KevinK
    Tundras to Sedona
    The omega has 30 settings on each knob. Basically every half-turn has a detent, so 15 full turns is the full range from fully open to fully closed. I was afraid I wouldn’t be able to tell a difference between open and closed, but there’s a major difference. I can feel the difference even between 2 clicks.
  15. May 19, 2018 at 8:12 PM
    newguy209
    newguy209 New Member
    Central CA
    Okay here comes a noob question. I just purchased the stage 4 with the uca tube delta joint thing as an extra. I know you can adjust the fronts to 3.0", but can I leave it at 2.5" and add a 1.5-2" spacer in front and like a 1.5-2" block with the leaf making it a total of about 4-4.5" or will my truck explode?
    Thanks in advance. @Icon_Adrian
    Icon_Adrian[OP] likes this.
  16. May 19, 2018 at 8:34 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
  17. May 19, 2018 at 10:01 PM
    TexasTundra27
    Mark
    I ran 2 of @Coachbuilder1 shims on top of my Icons for a while set at 2.5”, but it ended up maxing out my toe on the passenger side and I wasn’t able to get it properly aligned without either removing the shims on the passenger side or buying Heim joint upper control arms. I removed the passenger side shims and left the driver side as is and my truck sits level side to side now and my alignment is perfect. Just my experience, you might be able to run 1 shim which is good for 1/2”.
    newguy209[QUOTED] likes this.
  18. May 19, 2018 at 10:08 PM
    DecalsByDesign
    DecalsByDesign Vinyl Connoisseur
    Eagle, CO
    2019 Quicksand Limited Double Cab
    Toytec Performance Aluma 2.5 Kit Nitto G2 295/70-18 Method MR306 18x9 +18 Kenwood DDX6906s Carven TR Muffler w/ Y-Pipe
    I don’t see a smooth body anywhere....???
    BlueBottle[QUOTED] likes this.
  19. May 19, 2018 at 11:15 PM
    #49
    newguy209
    Central CA
    Thank you sir!
    TexasTundra27[QUOTED] likes this.
  20. May 21, 2018 at 8:35 AM
    #50
    KevinK
    Tundras to Sedona
    Also as you get above about 3" lift you need to look at dropping the front dif to reduce the CV angle closer to stock.
    A general rule of thumb is if you want 0-3" of lift, go with coilovers.
    If you want 4+ inches of lift, go bracket.
    Full disclosure: coilovers are generally more capable off road than bracket lifts. I'm sure plenty of guys will flame me and say they wheel their brackets and I'm full of shit, but I'm just making a general statement. I do know, and have wheeled with, guys on bracket lifts who run hard, but even they will tell you they can't run as hard at full speed as a suspension (coilover) lift.
    Flame on... :bananadead:
  21. May 21, 2018 at 12:45 PM
    #51
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Smooth body or smooth booty?
    :rolleyes:
    Watt maker likes this.
  22. May 21, 2018 at 7:34 PM
    #52
    DecalsByDesign
    Eagle, CO
    smoooooth ba-donk-uh-donkkkkkkkkkkkkk.
  23. May 21, 2018 at 10:33 PM
    #53
    newguy209
    Central CA
    Thx
  24. May 23, 2018 at 2:17 PM
    #54
    Icon_Adrian
    Adrian
    Riverside CA
    LT Front and Rear
    @newguy209
    You should never combine Icon Vehicle Dynamics coilovers with additional spacers. The Icon suspension components are designed to maximize performance of your vehicle without compromising or damaging you vehicle. The being said the 07+ Tundra Coilovers will grant you the maximum allowable travel possible within the boundaries of the stock tie rods and CV's. By adding a spacer above the Icon unit will over extend the suspension at full droop and can cause damage. I strongly advise against adding a spacer.
  25. May 23, 2018 at 2:42 PM
    #55
    Icon_Adrian
    Adrian
    Riverside CA
    LT Front and Rear
    :thumbsup: @KevinK knows his stuff.
    papasmurf and KevinK[QUOTED] like this.
  26. Oct 12, 2018 at 10:23 AM
    #56
    Icon_Adrian
    Adrian
    Riverside CA
    LT Front and Rear
    Update! Added stage 8-10 to the chart. Enjoy!
  27. Oct 12, 2018 at 12:18 PM
    #57
    KevinK
    Tundras to Sedona
    They still don't go high enough. :rofl:
    :bananadead:
  28. Nov 27, 2018 at 10:02 AM
    #58
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    @Icon_Adrian
    Do the all stages allow for extended travel?
  29. Nov 29, 2018 at 3:09 PM
    #59
    Icon_Adrian
    Adrian
    Riverside CA
    LT Front and Rear
    Yes sir.
    The smaller trucks like Tacoma, 4Runner & FJ's need aftermarket UCA's in order to take advantage of an extended travel shock. The 07+ Tundra platform is neat because you have an Extended travel shock designed into all shock configurations we manufacture. Due to it's size we are able to add travel even with a stock UCA. :thumbsup:
    Mwray8909[QUOTED] and Watt maker like this.
  30. Nov 29, 2018 at 3:36 PM
    #60
    Mwray8909
    Chino Valley
    Do you happen to know how much more travel the 2.0s allow in the rear over stock?
