Up travel (assumed) clearance issue
Discussion in 'Suspension' started by KuhlKreations, Sep 15, 2020.
  1. Sep 15, 2020 at 3:36 PM
    KuhlKreations
    KuhlKreations [OP] Part time professional, full time idiot.
    OC, California
    2020 Trd Sport 4x4
    What’s up folks;
    Prelude-
    recently slapped extended travel kings and camburg kinetik Uca’s with 315’s on the truck. Additionally, I removed the sway bar.
    issue-
    Took a left handed u turn and rubbed so hard it pulled a little of the fender well cover off. Bmc and bumper shims have been installed. Not sure how many additional parts need to be removed at this point and about the cab side of the fender well needing MORE chopping.
    Any idea’s/thoughts will be helpful.
    thanks
    Edit: I’ll add some pictures after work
    Sunnier likes this.
  2. Sep 15, 2020 at 3:43 PM
    What's your wheel offset?
    Flyinryank likes this.
  3. Sep 15, 2020 at 3:53 PM
    KuhlKreations
    OC, California
    2020 Trd Sport 4x4
    Method says 0” offset/4.75” spacing. They’re the method 311 vex wheels. 17”x8.5
  4. Sep 15, 2020 at 4:14 PM
    Wheel offset is the usual culprit, but you have the BMC and shims. Let's see if a member chimes in with a similar setup.
  5. Sep 15, 2020 at 4:15 PM
    Forgive my ignorance...what are extended Travel Kings? Have pics of your setup?
  6. Sep 15, 2020 at 4:21 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Basically an internal stop is removed making them droop more.
    Lot of mfg make extended versions, they require uniball (possibly BJ) uppers to be used to accommodate the additional down travel.
    Sunnier and Black Wolf[QUOTED] like this.
  7. Sep 15, 2020 at 4:22 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    assuming your rubbing is back side, adding caster will help clear the back contact issues.
  8. Sep 15, 2020 at 4:30 PM
    Makes sense. Shouldn't something like Super Bump Stops be used to compensate?
  9. Sep 15, 2020 at 4:32 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Extended travel alters down, not up travel. Unless things have changed...
  10. Sep 15, 2020 at 4:34 PM
    Nope. Makes sense!
    831Tun likes this.
  11. Sep 15, 2020 at 4:37 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Talked with Fox a lot about this some time ago. Kore had a custom Fox coilover they were selling and advertising something like 13" of wheel travel or something like that (with a uniball upper).
    Reached out to Fox due to Kore no longer selling it. Basically an out of the box coilover with internal stops removed.
    Sunnier likes this.
  12. Sep 15, 2020 at 5:10 PM
    KuhlKreations
    OC, California
    2020 Trd Sport 4x4
    Ok, I’ll check that out. Thank you.
    4BCC25FA-9142-407E-8D83-469B19D63981.jpg[/QUOTE]
  13. Sep 15, 2020 at 5:16 PM
    Sunnier
    Sunny
    San Diego, CA
    More caster is always better :cool:, but OP didn’t describe rubbing the body mount in reverse (caster is the fix for that), but in a tight left turn. Obviously pics would help, so we understand exactly what ‘fender well cover’ got damaged. If it’s on the outside of the tire, changing wheels (offset) or adding wide fenders may be the fix.
    Black Wolf likes this.
  14. Sep 15, 2020 at 5:23 PM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    fender well cover... LOL that's cute... just remove the plastic and let it self-clearance problem solved
    831Tun, Sunnier and 14burrito like this.
  15. Sep 15, 2020 at 5:45 PM
    .....but the AIP inlets will be exposed so either do a bypass or install the SDHQ AIP inlet relocation kit.
  16. Sep 15, 2020 at 9:08 PM
    KuhlKreations
    OC, California
    2020 Trd Sport 4x4
    when I get off shift I’ll grab a pic or two for the post. Had forced ot today :annoyed:
  17. Sep 15, 2020 at 11:21 PM
    KuhlKreations
    OC, California
    2020 Trd Sport 4x4
    Pics of contact sites
    D98E3953-4F5E-4D4D-BEA2-44D748CD497B.jpg AE657F2E-0691-4DF9-906E-E69D6532A0FB.jpg [
    831Tun likes this.
  18. Sep 15, 2020 at 11:41 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    So its rubbing in the rear..I'd cut the inner liner where it rubs and be done with it...
    KuhlKreations[OP] likes this.
  19. Sep 15, 2020 at 11:44 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    :rofl::rofl::rofl: Been there, done that. Self clearancing complete.
    Not to worry OP, I'm referring to an LT setup.
  20. Sep 15, 2020 at 11:48 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    What's your caster #? Shove that wheel forward and cut the liner a little more if necessary. Mud leaves and crap build up at the bottom of the fender behind the liner. Might as well make it easy to clean out. :101010:
  21. Sep 15, 2020 at 11:57 PM
    KuhlKreations
    OC, California
    2020 Trd Sport 4x4
    alright, that seems like a common suggestion. I don’t know the caster #, unfortunately I trusted I’d be one and done with the install company. I’ll do a little trimming this weekend.
  22. Sep 16, 2020 at 5:38 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    have an alignment shop push your caster to 3.5+ (keep toe and camber at the factory #'s) the truck will feel just ever so slightly slower on steering input from factory #'s on the road, but more stable in the dirt, and it will clear that rubbing issue.
    equin and Sunnier like this.
  23. Nov 29, 2020 at 8:46 AM
    KuhlKreations
    OC, California
    2020 Trd Sport 4x4
    ALRIGHT. Since I finally fixed the issue, I figured I’d let all those who posted on this thread know. Took it in to get the bmc double checked, right? Bmc had been done a little too shallow, so they cut a little more off and cleaned up the weld. Pretty stoked and I have a much cleaner and clearer ROM with my truck. Thanks to all for the input.
    papasmurf, Sunnier and equin like this.
