Uniball LBJ conversion
Discussion in '1st Gen Tundras (2000-2006)' started by Baller, Apr 6, 2023.
  1. May 12, 2023 at 3:46 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    Uniball is a slang term that's become synonymous with suspension/steering components which incorporate a spherical bearing (heim joint) as a pivot point.
    alb1k[QUOTED] likes this.
  2. May 12, 2023 at 8:41 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    That makes sense. I imagine the slang came from differences in build and materials, maybe size and application as well. I'll take whatever TC will put in there over the OEM known to fail joint.
    tvpierce[QUOTED] likes this.
  3. May 17, 2023 at 11:31 AM
    TOTAL CHAOS
    TOTAL CHAOS WWW.CHAOSFAB.COM Vendor
    Corona, CA
    It's in the works but we don't have a timeline as of now.
    G_unit3000, digitalferg and alb1k like this.
  4. May 17, 2023 at 1:55 PM
    digitalferg
    digitalferg New Member
    Wandering the Wild West
    2006 Tundra DC TRD 4x4
    We 2005-2006 Tundra owners:
  5. Oct 22, 2023 at 12:10 AM
    flyfisher
    flyfisher Member
    David
    Firestone, CO
    2005 Tundra SR5 Double Cab 4x4
    Mike, any update on these?
  6. Oct 24, 2023 at 9:02 AM
    TOTAL CHAOS
    Corona, CA
    Nothing new as of yet but still working on it
    G_unit3000 likes this.
  7. Oct 25, 2023 at 7:13 AM
    Mike A
    Mike A New Member
    Mixhael
    First Gen Tacoma
    A lot
    The first sets should be done by the end of the year and they should be available for purchase early 2024.
    G_unit3000 and TOTAL CHAOS like this.
  8. Jun 19, 2024 at 11:41 PM
    Lundy
    Lundy New Member
    San Diego
    2004 Dual Cab V8, Automatic, 4x4, SR5 w/tow pkg
    Shifty, thanks for posting the you tube video for these. Has any one this forum installed them yet?
    I am doing the stock width solo m.s. lower control arms, OEM lower ball joints, tie rod ends and steering rack bushings and a shock rebuild, end of July and might consider them instead of oem ball joints.
    Thanks in advance ......if anyone can review them. :thumbsup:
  9. Jun 20, 2024 at 5:41 AM
    shifty` Inside his chest they found ten thousand pencils
    Reposting said video here.
  10. Jun 20, 2024 at 8:40 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  11. Jun 20, 2024 at 10:12 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I wonder what sort of maintenance they require.
  12. Jun 20, 2024 at 10:28 AM
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Following for more real life info and use of these lbj's. I would pay $1k+ for peace of mind if they're actually better but the maintenance factor is a tough one ever since I lost the time I used to have for home-wrenching. I second FirstGenVol's comment.
  13. Jun 20, 2024 at 10:40 AM
    tvpierce
    Maine
    Unless you're rock crawling or heavy duty off roading, is the extra strength really worth it?
    The initial cost is $1K, requires constant cleaning, and will need to be rebuilt every few years. Each rebuild will cost the same amount of money as a new set of OEM ball joints.
    Why not just go with OEM ball joints and plan to replace them every 100k miles?
    G_unit3000, bfunke and FirstGenVol like this.
  14. Jun 20, 2024 at 11:00 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    For the uppers I just hose them off, let dry and then spray with triflow.
    Lowers might get a little more grit and grime but probably the same process
  15. Jun 20, 2024 at 2:36 PM
    The adjusted angles and reduced wear and tear (thus less peripheral part wear/replacement) could make it more-worthwhile for some. It looks like it truly corrects some suspension angles, reducing stress.
  16. Jun 20, 2024 at 2:48 PM
    tvpierce
    Maine
    Fair enough.
    I live in the Northeast where roads are sanded and salted in the winter. I wouldn't expect these uniballs to last more than one winter.
    shifty`[QUOTED] likes this.
  17. Jan 24, 2025 at 12:07 PM
    Anima
    Anima New Member
    2000 TRD Tundra V8 4x4
    This is great information. Thanks Mike!
    These might be stupid questions, but does this design ride more rough than the OEM LBJ? Also, would this setup be recommended for a 2000 Tundra that is used for snowboard trips to Mammoth and surf trips to the beach (sandy conditions and cold winter conditions)?
    Thanks
