Undiagnosable Clunking
Discussion in '2.5 Gen Tundras (2014-2021)' started by SR5camper, Mar 1, 2021.
  1. May 14, 2021 at 5:56 AM
    #151
    15whtrd
    15whtrd Mr. Blonde
    After reading everything, my money is on some thing wrong inside the front differential. Second in line is a CV. I’m definitely not an expert in either of those areas, but I do hate noises that have no explanation. If I know what it is and it’s not causing any harm, I’m good with it. But if it’s something caused by some type of failure or improper installation, I want it fixed.
    definitely in for the results, whatever this plays out to be.
    texasrho83, JLS in WA and Bikeric like this.
  2. May 14, 2021 at 7:18 AM
    #152
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    Dang, beat me to it. I would remove the hub cover of the CV's to remove the big nut. Bang the CV back deeper into the front diff and make sure you go past the snap ring. Tighten the big nut back up and replace the dust cover. Sounds like your longer travel suspension has caused the CV's to be pulled further out then stock. My 2cents.
    15whtrd[QUOTED] likes this.
  3. May 16, 2021 at 8:22 PM
    #153
    SR5camper
    SR5camper [OP] New Member
    AZ / TX
    2015 SR5
    Chassis ears are on my list of things to get next week if this next shop visit doesn't reveal any issues.
    I've considered getting rid of it a few times, unfortunately it would probably take more time and money to return this thing back to stock before trading it in or selling it than it would to replace/take apart the few remaining items I haven't touched yet.
  4. May 16, 2021 at 8:22 PM
    #154
    SR5camper
    AZ / TX
    2015 SR5
    Not stupid at all. I've heard of it being an issue so I already checked all of those parts.
  5. May 16, 2021 at 8:24 PM
    #155
    SR5camper
    AZ / TX
    2015 SR5
    Interesting. I've never noticed an unusual humming, but these Toyo RT'S aren't exactly quite so I bet it would be hard to pick out anyway.
    I'm gong to have the mechanic working on it this week give me his opinion on the amount of CV slop I have and maybe pull the axle to take a closer look.
  6. May 16, 2021 at 8:32 PM
    #156
    SR5camper
    AZ / TX
    2015 SR5
    I'm beginning to grow suspicious of the diff/CV's so as stated above I'll be having my guy look into it this week.
    Thanks for the suggestion. Tonight I'll compare the gap between the driver/passenger side CV and the diff to see if I notice a difference
  7. May 17, 2021 at 8:20 AM
    #157
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    I would check the gaps between the CV and diff with the wheel at full droop. Jack up the truck from either the frame rail or crossmember and see if a gap shows up when the wheel gets off the ground.
  8. May 17, 2021 at 8:29 AM
    #158
    Joro43
    Joro43 New Member
    2018 TRD Sport 4x4 quicksand crewmax
    1st tundra nautical blue 4x4 5.7l DC TRD had oracle custom color shift halo projector headlights, Fab4 bumper with 12k winch. RBP RX3 Grill Pro Comp stage 1 with bilstein 6112 coil overs SPC UCAs BFG KM3 35x12.5x20 with Moto metal 959s NFab running boards TRD LED DRL pioneer avh 4200nex with Polk speakers and JL 600w amp with JL audio stealth box 196k miles and running strong ready for another 200k until I wrecked it on 2/26/21 Just bought 2018 CM 4x4 5.7l quicksand TRD package upgraded headlights and adaptive CC Trifold bed cover, blacked out badges, KMC wheels BFG KO2 tires, 3/1 pro Comp lift FAB4 front bumper with rigid lights and fab4rear bumper.
  9. May 17, 2021 at 11:54 AM
    #159
    2mchfun
    2mchfun Yeah it'll pull it, just don't expect to stop!
    When I first installed my wheel locks I placed the key inside the console safe and headed to Home Depot for something. Went down the road through several turns and out of nowhere clunk clunk clunk at random. At first I thought the front end came apart on a brand new truck, sure did sound like it was control arm or sway bar. Nope, it was the wheel lock key bumping inside the safe. I assure you, I was dumbfounded for thirty minutes trying to find a loose suspension component in the dark. Don't believe me, throw a deep set socket in there and take off, it's really concerning when you hear the clunks.
    JLS in WA likes this.
  10. May 17, 2021 at 12:24 PM
    #160
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Lol. I had a similar experience in my old Tacoma. I mounted a big Maglight flashlight on my driver seat. The D batteries rattled in the casing on certain roads.
  11. May 19, 2021 at 12:34 PM
    #161
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    How much room between your coil-overs and the LCA at full droop here? Any marks from contact? This LCA has been notched, albeit poorly.
    JLS in WA and mountainpete like this.
  12. Jun 6, 2021 at 7:20 AM
    #162
    LarryDangerfield
    LarryDangerfield Put me in coach! Staff Member
    Tyler
    Northern Wisconsin
    Cement 2020 Trail Limo off-road Tacoma
    Tuxmat floor mats, Bilstein 6112s and 5160s
    @SR5camper Still clunking? We need an update! :D
    tundra_20 likes this.
  13. Jun 6, 2021 at 7:27 AM
    #163
    AL_TUNDY
    AL_TUNDY New Member
    The Land of Nye
    2005 Tundra
    I think he may have clunked out. :notsure:
    tundra_20 and LarryDangerfield like this.
  14. Jun 7, 2021 at 10:30 PM
    #164
    SR5camper
    AZ / TX
    2015 SR5
    Yep, STILL clunking! Going to go the chassis ears route here soon.
  15. Jun 7, 2021 at 10:32 PM
    #165
    SR5camper
    AZ / TX
    2015 SR5
    I've already eliminated the possibility of something inside the truck clunking
    2mchfun[QUOTED] likes this.
  16. Jun 7, 2021 at 10:33 PM
    #166
    SR5camper
    AZ / TX
    2015 SR5
    I've read about the LCA's requiring clearancing but mine are not contacting at full droop and there aren't any marks of them contacting.
    landphil[QUOTED] likes this.
  17. Jun 8, 2021 at 5:22 AM
    #167
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    With the way things are now you could always trade it in at this point for more than you bought it for and get a new one. :notsure:
    AircareTundra and Mad Max like this.
  18. Jun 8, 2021 at 6:00 AM
    #168
    2mchfun
    Is the battery moving around?
  19. Jul 4, 2021 at 8:00 PM
    #169
    excelw
    excelw AfRo Samurai
    WW
    AB, Canada
    2019 Toyota Tundra TRD Pro (Midnight Black)
    leather wrap steering wheel, front window tint, ceramic coating, AMP research power steps, Toyo open country at3 35”x11.5x18, Volk Racing te37xt 18 9.5 0 offset, Rays formula II lug nuts Warn fender flares, Coachbuilder TRD Pro kit +3, Kenwood excelon 996xr stereo +7” speakers Westcott designs front lift, RAS rear leafs, yota leds, NSV Lightbar
    mine is doing same thing and sounds like it’s getting worse IDK.
  20. Jan 9, 2022 at 1:38 PM
    #170
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Was there any solution?
    LarryDangerfield likes this.
  21. Jan 9, 2022 at 3:34 PM
    #171
    LarryDangerfield
    Tyler
    Northern Wisconsin
    Forgot all about this thread!!!
  22. Jan 9, 2022 at 8:39 PM
    #172
    excelw
    excelw AfRo Samurai
    WW
    AB, Canada
    I also had a similar sound like that after i installed a lift and after I had an alignment that sound occurred and I read a couple of other posts about the same issue everyone mentioned the LCA needed to be torqued to somewhere around 200# when I used my torque wrench sure enough it was never torqued and I figured as much because they never removed my TRD skid plate to do so because from what I seen underneath I don’t think there is any way to torque it unless it’s removed. IDK maybe double check and see if they even torqued it to proper spec.
  23. Jan 9, 2022 at 9:10 PM
    #173
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I read that fantastic thread for this...SOAB.
    Bikeric likes this.
  24. Feb 15, 2022 at 2:49 PM
    #174
    LarryDangerfield
    Tyler
    Northern Wisconsin
    Find a resolution yet?!
    ZPhilip likes this.
  25. Oct 23, 2022 at 11:24 AM
    #175
    ZPhilip
    Philip
    West Chester, PA
    Back from death. Still clunking?
  26. Oct 23, 2022 at 11:50 AM
    #176
    ZPhilip
    Philip
    West Chester, PA
    What’s your front suspension setup besides the TRD Fox? I have the same and am thinking my newly reinstalled sway bar is hitting the shock.
    PNWTundra2021 likes this.
  27. Oct 23, 2022 at 4:58 PM
    #177
    excelw
    excelw AfRo Samurai
    WW
    AB, Canada
    I have the westcott lift in front and coachbuilder +3 carrier bearing drop in back with RAS.
  28. Oct 23, 2022 at 5:03 PM
    #178
    Pilotjoe123
    Pilotjoe123 New Member
    Joe
    2019 Tundra Sport red
    did you ever check the differential mounts?
    07DCLimited likes this.
  29. Jan 9, 2023 at 6:01 AM
    #179
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    Alright, read this whole thread… you’ve checked damn near everything, but the one thing you haven’t checked is the front diff, it sounds like there’s slop between the gear set like the backlash wasn’t set properly when the gears where installed. Did a shop install them? Did they paint the gears to check the pattern? Is the race and backlash set properly? You might not have a failure because of it, but it’ll be wearing down the teeth on the gears, how’s the front diff fluid look?
