Undiagnosable Clunking
Discussion in '2.5 Gen Tundras (2014-2021)' started by SR5camper, Mar 1, 2021.
  1. Mar 14, 2021 at 2:32 PM
    #91
    SR5camper
    SR5camper [OP] New Member
    AZ / TX
    2015 SR5
    Forgot to I close that bit of information. Clunk is present on 2wd and 4wd (HI and LO)
    Video is 2wd
  2. Mar 14, 2021 at 3:00 PM
    #92
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Are you positive the clunking was still there when you removed the bumper? I’m only asking because that is exactly what my truck sounded like when my (glass) fenders were hitting my aftermarket bumper. I would try what @mountainpete suggested just to completely knock it off the list. I just shoved a small towel in between them, you don’t have to remove your bumper again. Quick and easy test.
  3. Mar 14, 2021 at 5:20 PM
    #93
    SR5camper
    AZ / TX
    2015 SR5
    Yes absolutely positive. It's extremely noticeable.
  4. Mar 16, 2021 at 12:42 PM
    #94
    cook2kill
    cook2kill PNW
    Portland OR
    2018 CM
    Is it just me or does that sound like a tool or driver bit, left somewhere. Just a thought.
  5. Mar 16, 2021 at 12:48 PM
    #95
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    I still vote for hanging out the side of the bed trying to pinpoint a better area of origin.
  6. Mar 16, 2021 at 1:30 PM
    #96
    TheBeast The Beach
    gotta be a 10mm socket
  7. Mar 16, 2021 at 1:40 PM
    #97
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Find the 10 mm!
  8. Mar 16, 2021 at 2:17 PM
    #98
    brown_subaru
    brown_subaru New Member
    Eastern WA
    2021 Tundra SR5 TRD
    As some others have stated on here, I think that since the problem started after the re-gear and installing the new bumpers, it has to be one of those that's the issue. Bumpers have been ruled out. Not being entirely up to speed on what's involved in a re-gear, I may be off here. But if they modified the gears in the front differential, couldn't the issue be something inside the differential? Maybe a broken or defective spider or side gear? Something like that would make sense to me given that the noise seems worse when turning and the spider and side gears would be rotating in that case. This site has some interesting notes on diagnosing differential noises: https://www.differentials.com/diagnosing-differential-problems/
  9. Mar 16, 2021 at 3:53 PM
    #99
    SR5camper
    AZ / TX
    2015 SR5
    Thought about that, but with the amount of hours I've spent with my head in the engine bay it's unlikely
  10. Mar 16, 2021 at 4:12 PM
    #100
    SR5camper
    AZ / TX
    2015 SR5
    I've sat out the window while driving. All I can do is narrow it down to the front end
  11. Mar 16, 2021 at 4:18 PM
    #101
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    What kind of mounting brackets are your resis using?
    I hear something along the lines of the resi/mount possibly bouncing/ chattering off the frame horn.
  12. Mar 16, 2021 at 4:24 PM
    #102
    mountainpete
    @SR5camper - can you please post pictures of:
    1. Front of truck
    2. Passenger suspension (with wheel on but turned)
    3. Engine bay
    4. Skid plates
  13. Mar 16, 2021 at 4:29 PM
    #103
    mountainpete
    And do you have a diff drop installed?
  14. Mar 16, 2021 at 4:46 PM
    #104
    SR5camper
    AZ / TX
    2015 SR5
    Fox reservoir brackets with sway bar mount chopped off and bolted to the frame, hoses come nowhere near anything when suspension is cycled
  15. Mar 16, 2021 at 4:49 PM
    #105
    SR5camper
    AZ / TX
    2015 SR5
    Out of town this week but I'll snap some when I get back. Factory engine skid was scrapped (awaiting custom skids) and sway bar has been removed. If you're elluding to clearance issues.
    mountainpete[QUOTED] likes this.
  16. Mar 16, 2021 at 4:50 PM
    #106
    SR5camper
    AZ / TX
    2015 SR5
    Yes, installed diff drop a few months ago. Didn't change the clunk.
  17. Mar 16, 2021 at 6:48 PM
    #107
    14burrito
    2014 SR5 CM 4x4 5.7
    I'm not worried about hoses, I get a clank on harsh washboard from resi brackets themselves rattling off my frame.
    If you go tap with some force on the resis, there is no knocking from contact with the frame then, correct? I can take a pic and or maybe video to better explain if necessary.
  18. Mar 16, 2021 at 6:51 PM
    #108
    SR5camper
    AZ / TX
    2015 SR5
    Oh gotcha, No they're bolted solid.
  19. Mar 19, 2021 at 7:27 PM
    #109
    SR5camper
    AZ / TX
    2015 SR5
    Spent some time running more rubber fuel line and placing foam near possible contact points on the power steering cooler lines. No changes
  20. Mar 29, 2021 at 11:44 PM
    #110
    Wahayes
    Wahayes Older I get the wiser I realize my dad was
    Will
    2017 tundra limited
    325/60r20 falken at3w, 2.25 dobinsons ,20x9 +20 fuel torque wheels, leer xr100, bmc
    Bump , I'm assuming you still never got this sorted. Bumping the topic is all I can contribute at this point lol
  21. Mar 30, 2021 at 1:43 PM
    #111
    SR5camper
    AZ / TX
    2015 SR5
    You assumed correctly. Trying to decide if I want to order new coilovers or not because I've ran out of things to check
  22. Mar 30, 2021 at 2:48 PM
    #112
    Jimes
    Jimes New Member
    Bay Area, California
    2015 toyota tundra trd pro
    Have you tried to see if your inner tie rods need to be replaced? I get a weird clunk/pinging sound randomly when I turn my steering to full lock. I also tightened every bolt possible. But I noticed that my inner tie rods just drop when I let them go. I’m hoping that’s my issue. They are supposed to stay in place and not be all loose like that. I know you checked your outer tie rods, but not your inners. Not sure if that could cause it.
  23. Mar 30, 2021 at 3:14 PM
    #113
    Wahayes
    Will
    2017 tundra limited
    Have you taken it to the dealership or a mechanic, or just all self diagnosis at this point?
  24. Mar 30, 2021 at 3:24 PM
    #114
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    You’re gonna need the mics all over to narrow it down I fear
  25. Mar 30, 2021 at 3:30 PM
    #115
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    Just curious did you swap out your headlights at any time?
  26. Mar 30, 2021 at 5:08 PM
    #116
    Oats87
    Oats87 Dirt Rider
    Sunnyvale, CA
    A Non-Toyota
  27. Mar 30, 2021 at 5:56 PM
    #117
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    chassis ears suggestion was the best so far. You should be able to quickly isolate noise to a small area. My brother had a similar noise, horrible. Someone convinced him it was the guts in the catalytic converter rattling around. Replaced no success. I pushed up and down on car and within seconds he determined the rear shock mount bolt was loose. Holy hell he drove 1K miles with that noise on a trip said he almost abandoned car lol....
    SR5camper[OP] likes this.
  28. Mar 30, 2021 at 8:15 PM
    #118
    Marshal
    Marshal Newd Member
    Marshal
    Petoskey, MI
    2014 SR5 MGM 5.7 4x4
    I had a similar issue with my 2014 Ram 1500. Was similar in the sense that it only happened under specific road conditions, turns, bumps etc, but my noise was more of a squeak than a thumping noise. It turned out to be blown put strut mounts on top of the coilovers due to my leveling kit I had. Now of course it can't be the same thing because you have fox coilovers without those type of mounts. My knee jerk guess would be to check the torque of the coilover where it's mounted to the frame and the LCA. Sounds like it's jiggling around to me. Just a thought...
  29. Mar 30, 2021 at 9:02 PM
    #119
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Have you tried mounting your phone to the any steel spots with a magnet phone case oh vid record? I’ve found shyt like that before. Bummed out for you. Trucks killer.
  30. Mar 30, 2021 at 10:39 PM
    #120
    CallMeD
    CallMeD New Member
    Have you checked the lower ball joints?
