Undercover - Swing Case Review
Discussion in 'Product Reviews' started by csuviper, Dec 26, 2015.
  1. Dec 26, 2015 at 9:05 PM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I just got the Swing Case for Christmas from my wife. Was a much desired item as there isnt any bed storage in the tundra. I needed something that would fit under my tonneau cover and the swing case fit the bill.
    The brackets are nicely powder coated and the quality of the case is very good.
    Install was very easy. Just had to remove one tie down on the side and mount the mounting bracket with self taping screws. All hardware was provided. I did have to adjust the latch but it was easy as the latch has oval holes for adjustment.
    The case does easily lift off so a padlock is definitely recommended. Wish you could get a lock that matches the key for the top of the swing case.
    http://www.undercoverinfo.com/products/swingcase
    https://www.youtube.com/watch?v=PryGmiSxVB0
    4x4_Angel, Sunnier, Law323 and 6 others like this.
  2. Dec 26, 2015 at 9:41 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I second this review, I love mine.
    Tip: Spray a little fluid film or a different quality lubricant (not WD-40) on the latch mechanism under the swing case, also on the verticle hinges.
    I didn't when I installed mine and after a while the latch started sticking. Fluid film solved that. Also lubricant on the verticle hinges will prevent the paint from wearing off from all the swinging.
    NewImprovedRon and JC303 like this.
  3. Dec 27, 2015 at 8:56 PM
    TNTundra08
    TNTundra08 New Member
    Blake
    2008 DC 4x4
    3/1 lift. 20x9 Method standards, machine face. 305/55/20 nitto trail grapplers
    Hmmmmm. I want one, didn't know these were a thing.
  4. Dec 29, 2015 at 7:41 PM
    TruckLife900
    TruckLife900 I'd rather B hunting
    2013 White SR5
    Thanks for the info Brian, I'll get one of these eventually!
  5. Dec 29, 2015 at 8:00 PM
    csuviper
    Broomfield, CO
    I will show what all I can fit in it as soon as I have time.
    JROCK915 likes this.
  6. Dec 30, 2015 at 9:55 AM
    TxTundra
    TxTundra New Member
    2014 CM SR5 TX Edition
    That's what she said!
  7. Dec 30, 2015 at 2:23 PM
    Tufftruck
    Tufftruck New Member
    2015 Bronze 1794
    I thought mine were pretty cool until they started to rattle. If anybody has a solution, I would love to see it. Also, a little pricing research on the internet and you will find deals. I got mine for $250.00+ for the pair. One other thing you shouldn't believe is the installation video that says "matching locks/keys" if you order a pair. Swing Case advised me this is not the case. However, they did make it right after I showed them the video and sent me matching locks. I was very pleased with their customer service. I wouldn't let the latch rattle scare you away. I'm thinking PlastiDip might fix it.
  8. Dec 30, 2015 at 2:37 PM
    AMRE2ME2
    AMRE2ME2 New Member
    2016 DC 4x4 Limited TRD
    Aren't you worried that those self taping screws will come loose eventually? Especially in that sheet metal. I bought one that bolts to the floor. Dee Zee makes it. It's all metal with sliding drawers and a locking front cover if you wanted to lock it.
  9. Dec 30, 2015 at 2:56 PM
    csuviper
    Broomfield, CO
    Not worried about the self taping screws pulling out. Should be plenty strong and last.
  10. Jan 6, 2016 at 12:40 PM
    JC303
    JC303 Same same but different
    Justin
    Aurora, Colorado
    2012 Tundra 5.7
    I would like to get a swing case but do u think I could mount this over the Toyota plastic bed protecter? Thoughts? @csuviper
  11. Jan 6, 2016 at 1:12 PM
    csuviper
    Broomfield, CO
    Yes i believe you could. Should work fine.
    JC303 likes this.
  12. Jan 6, 2016 at 2:18 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    You will just need to trim the bedliner so the brackets can mount properly
  13. Jan 6, 2016 at 8:32 PM
    JROCK915
    JROCK915 Trust noone, and be prepared!
    Jeremy
    Palm Desert, CA.
    2011 Trail ready SR5
    Icon 1.5" leaf pack, w/ Pro Comp 1" block Rear Pro Comp SS shocks ToyTec/Eibach coil overs, on Pro Comp SS shocks, SPC UCA AFE Stage II C.A.I, and throttle body spacer N-Fab nerf bars N-Fab RSP front bumper with Hella Optilux 30" LED bar, and Hella Optilux 4" (2) HID driving lights Federal Couragia 33x12.5x20, wrapped around 20x9 Fuel Boost Fender flares Spyder LED tail lights (smoked out)
    Nicely done sir. I'm just now seeing this. Ordered mine Saturday. Got it yesterday. I completely agree, regarding a lock that matches that key. I may just use a kingpin for now. My bed stays locked.
  14. Jan 6, 2016 at 8:58 PM
    csuviper
    Broomfield, CO
    It locks in place without anything on that lock bracket. No kingpin needed.
  15. Jan 6, 2016 at 9:45 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    I love mine. Yes they do fit over the plastic liner, but does require trimming. These come in both left side and right side, so you can put one on each side. If you buy them both at the same time, be sure and ask for matching lock sets.
    Sunnier likes this.
  16. Jan 6, 2016 at 10:18 PM
    cheehab
    cheehab Fan Boy
    Southern Maine
    2015 TRD Pro CrewMax
    I also received one for Christmas, so far so good. I think my dad wanted to help me install it as a father/son bonding experience, but it only took about ten minutes to install so we just drank some beers instead. My only major criticism is that it sticks out from the side wall a little more than I'd like. It actually sticks out a little further than the wheelwell. But it's easily removed if I really need the space. I'll post pics later.
    I still think it's absurd that Toyota would put a $45,000 truck on the market with no real cab storage or bed storage. But I love my truck.
  17. Jan 6, 2016 at 10:26 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    No.... I got that! I meant, in stead of using a lock in that one spot, that "they recommend". I keep my tailgate and tonneau locked. No reason for me to lock it down. I was just gonna put a kingpin in the spot, for s&gs!
  18. Jan 7, 2016 at 5:56 AM
    csuviper
    Broomfield, CO
    Ok s&g works
  19. Jan 7, 2016 at 9:00 AM
    Wilbur
    Wilbur New Member
    Savannah, GA
    2014 MGM
    Glad this thread was made. Always wanted to know if these were worth a shit. I work in the ag industry and have seen metal versions of these, that is what i want.
  20. Jan 7, 2016 at 9:18 AM
    TruckLife900
    2013 White SR5
    I guess I wont be getting one :( Notes say it will not work with my Extang Solid Fold tonneau cover. :mad: - I'll double check with the manufacturer...
  21. Jan 7, 2016 at 12:35 PM
    csuviper
    Broomfield, CO
    Here is the bracket attached to the bed with the self tapping screws.
    Here is the Swing Case in locked/storage position.
    Swing Case fully open position.
  22. Mar 9, 2016 at 8:55 AM
    csuviper
    Broomfield, CO
  23. May 23, 2016 at 11:25 PM
    joshuarat
    joshuarat New Member
    Gotta put this out there - I hope everyone is smarter than me and thought this out, if not...here are a couple of things to think about (prefaced with, these are VERY VERY good quality and I have NO complaints about the actual product - this is a problem with MY use case)
    1- I have a diamondback cover, suspect following is true for ALL hard covers. The case does NOT swing out 180 degrees..more like 165. Due to this and jsut how it mounts, you cannot fully open the top of the case even without opening your cover, it opens about 1/2 way. For me, the whole point was to NOT have to open the cover to get to tools/recovery etc.
    2- if you carry anything in your bed (regardless of cover or not), you have to push it to the front of the bed or remove it completely to swing the case open. shouldnt be a big deal..but they swing through the middle of the bed so there is lots of shuffling. if you are in a lifted truck or are short...its a PITA, trust me.
    I'll be selling mine and going with a "porkchop" box with drawers (few examples, I'm not sure exactly what I want yet)
    4x4_Angel, Sunnier, Lilly and 4 others like this.
  24. Aug 17, 2016 at 4:46 AM
    Krezz
    Krezz Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    @csuviper - dude you're posts are amazing in your build thread. Thanks for the links and write ups. Definitely some great items I plan on adding over the coming months once I am in my Tundra. My wife dislikes you already however and has referred to you as my new source of why I have no money left in my wallet =)
    Thanks for what you do!
    Sunnier and MotoTundra like this.
  25. Aug 17, 2016 at 7:21 AM
    csuviper
    Broomfield, CO
    Lol. No problem, glad to be of assistance to money arguments with the wife.
  26. May 7, 2017 at 6:51 PM
    TJ1794
    TJ1794 New Member
    2017 Tundra Crewmax 1794 TRD Off Road
    Tailgate popabd lock power lock actuator Toyota OEM tri-fold tonneau Bed Rug bed liner AMP Research powersteps Weather Tech floor liners and rain guards TRD Pro grille and color match surround/hood buldge Color match door handles and mirror caps ICON Stage 5 suspension 2.5" resi's with rear leaf pack and 1" front diff drop Fuel Pump 18"x9" rims +20 offset with 295/70R18 Nitto Ridge Grapplers.
    Makes perfect sense, I would want to be able to open boxes without lifting the last 1/3 of hard tonneau, otherwise what's the point of it swinging out unless ur truck is lifted 6"+. I'd rather put that money toward a bed slide as I tend to haul more tools than materials in my truck and those make loading and unloading things a breeze.
  27. Jul 2, 2017 at 5:54 PM
    SilverMetalJacket
    SilverMetalJacket New Member
    2017 Silver Tundra SR5 Offroad
    @csuviper I am looking at putting at least one box in but not sure I have the amount of clearance with my flip cover. There is a locking piece that hangs down from the track. Do you happen to know how many inches is from the top of the case to the top of the bed?
  28. Jul 2, 2017 at 7:03 PM
    csuviper
    Broomfield, CO
    Measured at ~6"
  29. Jul 2, 2017 at 7:05 PM
    csuviper
    Broomfield, CO
  30. Jul 3, 2017 at 2:12 AM
    SilverMetalJacket
    Awesome thanks. I think I might be ok.
