Undercover Ridgelander tonneau
Discussion in 'Tonneau Covers, Caps and Shells' started by Aobraz, Oct 20, 2017.
  1. Oct 20, 2017 at 6:20 PM
    Aobraz
    Aobraz [OP] New Member
    I haven’t seen much information on the undercover Ridgelander cover, but based off what I could find I ended up going with the Ridgelander. I went back and forth between this cover, the diamondback covers and the American roll cover.
    The American Roll covers look nice and has great reviews, but after adding up the cost of the cover and rack system I probably would have spent around $2.5k, which was way more than I wanted to spend. I would also have lost some storage area due to the canister, which I wanted to avoid.
    I really like the Diamondback covers, but I know if I had decided on those I would have rationalized myself into spending the extra $$ on the HD version, which would have been overkill for my use. Even with the SE, I still would have had to buy a rack system to attach to the cover and probably would have spent about 2K.
    The Ridgelander has some similar specs to the Diamondback SE...it is rated to carry about 500lbs on the cover and is priced about the same. The big selling point on the Ridgelander for me was that it comes with a RhinoRack system and the cover has a built t-slot channel system to support the rack cross-bars. The cover also uses something they call the “tango system” so you can install the racks when the cover is off and also acts as bed rails. Again, this is included in the price of the cover.
    I shopped around and ended up buying the cover on Autoanything. I was able to find it cheaper on another site I wasn’t familiar with, but AA price matched and I’ve always had good luck with AUtoAnything. So when it was all said and done I got the cover for about $1,300. Still not cheap, but the best option I could find for what I was looking for.
    I just got the cover today and installed tonight. First impressions is it seems solid and the weather seal looks tight all the way around.
    If anybody is interested I’ll post some better pictures when I have some daylight to work with and will follow up with my impressions after I have it for awhile.
    Anyways, just wanted to put some info out there on this cover, since I couldn’t find much when I was searching.
    What I wanted:
    -Able to carry some weight/cargo (nothing crazy, but needed to be a solid cover)
    - Fairly weather right
    - Ability to use a rack that could carry bikes and/or an RTT
    - easy removal for when I need to carry larger items
    TreeCat, Pudge, Law323 and 6 others like this.
  2. Oct 21, 2017 at 8:12 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    That cover looks BA, very interesting. I’ve never heard of them but I would like to see more pics and I’d also like to hear your review/info you come up with on this thing. Looks solid but I’m sure you’ll tell us.
    dradd, Sunnier and htw_hawaii like this.
  3. Oct 21, 2017 at 10:39 AM
    Zeb8806
    Zeb8806 New Member
    2014 Tundra Crewmax Limited
    That’s a cool tonneau! I really want a bed rack system/tonneau cover. How quick/easy does the cover come off if you want full bed access?
  4. Oct 21, 2017 at 11:09 AM
    Aobraz
    I’ll take some more pictures this afternoon and post them.
    I just installed the cover yesterday, so haven’t had a need to take it off yet, but I can’t imagine it will take more than 5 minutes to remove and re-install now.
    The cover isn’t very heavy, but because of the size it will definitely be easier to take off/put back on with another person helping.
  5. Oct 21, 2017 at 11:27 AM
    htw_hawaii
    htw_hawaii Tundra N00b
    Victor
    Hawaii
    2018 Cement CM 4x4 TRD
    Looking forward to more pictures! Thanks
  6. Oct 21, 2017 at 11:59 AM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    ^^^^^^^^^^^ What he said
  7. Oct 21, 2017 at 1:06 PM
    Aobraz
    Here are a few more pictures. If there are any specific parts you want to see let me know and I’ll take those for you.
    One thing I didn’t realize with the cover is that it comes with an LED light strip as well. Nothing fancy, but convenient when looking in the bed at night.
    Rex Kramer, equin and 4x4_Angel like this.
  8. Oct 21, 2017 at 6:59 PM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    That's a great cover
  9. Jan 19, 2018 at 7:39 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Nice cover @Aobraz
    How’s it so far? Water leaks? Easy to remove?
  10. Jan 24, 2018 at 4:56 PM
    Aobraz
    So far so good. We really haven’t had any measurable rain here in my part of Texas, but I have run it through the car wash a few times. A little water seeps in around the tailgate, but it is nothing significant.
    The process to take it off is easy enough, but an extra set of hands definitely helps. It’s not the weight, but the size of the cover that makes it a little cumbersome to remove. This is one thing I like about the idea of the diamondback covers. The three smaller pieces seem like they would be much easier to handle when removing by myself.
    equin, 4x4_Angel and dradd like this.
  11. Mar 30, 2018 at 8:46 PM
    Bws326
    Bws326 New Member
    Silver 2018 Tundra Limited 4wd
    Undercover Ridgelander with Rhino Rack
    I used this forum and other resources to decide on the Undercover Ridgelander, and moved forward with purchasing it. It is a lot of money but well worth it. I have had three trucks in last 10 years, each with different covers and this one is hands down the best. The install was not too bad, but definitely have another set of hands available. It took about 1.5 hrs and overall trouble free other than a little fine tuning to the front bracket placement. It has been 99% waterproof. A few trickles at tailgate in extremely heavy rain. I use a bed mat over a spray liner and the few drops just trickled under the mat. Normal rain, not a single drop. I raise and lower the cover a lot, so I decided to take tge basket off as it is fairly heavy and makes the cover slightly more difficult to lift up. I will only need the basket a few times a year, and it only takes about 10 minutes to put on or off. This cover looks great and works great.
    8C409870-69B6-4C9B-9A54-2C69411E79DE.jpg EB276090-4EC0-4569-B198-8CA77FE8E39B.jpg
    equin, Sunnier, jtwags and 2 others like this.
  12. Mar 30, 2018 at 8:59 PM
    dradd
    dradd Sometimes there is just us
    City of Champyinz
    '17 TRD Pro
    pending...
    Very nice. I have been considering get this cover and input such as this helps me make decisions.
    Bws326[QUOTED] likes this.
  13. May 23, 2018 at 12:44 PM
    dxiong0629
    dxiong0629 New Member
    Dennis
    2017 Tundra TRD PRO
    can you still lift up the cover even if the basket is on top and why did u said it was difficulty to lift due to being heavy?
  14. May 23, 2018 at 12:49 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    nice truck and set up! Go introduce yourself in the new comers section!
  15. May 24, 2018 at 9:16 AM
    Bws326
    Bws326 New Member
    Dxiong0629, the basket weighs about 40lbs. Just an estimate. When you open the cover it has hydraulic arms that raise it up with little to no assist needed. When the basket is on it the hydraulics are not strong enough to do this without you manually pushing it up. They do help a little but the cover weight and the basket weight is pushed up mostly by you. It is not bad just requires a decent push. I am 5’10” and when pushing it up near the top my arms are extended fully. Just a little akward more than anything, but in no way difficult.
    Now that i have had the cover for about 2 months, i can attest it is holding up well 95% watertight. Only place i am getting any drips is corners of cab side. This is not the cover’s fault. It is the two small openings on the truck bed at the top where the bedrails meet the bulkhead. It is minimal and with the bed mat i have, the small amount would roll under that. I have enough confidence in this cover that i leave my gym bag, briefcase, blankets, etc back there with no concern.
    On my last truck i had a simple extang trifold that was great. I was worried that having a cover like this may get in the way if needing to move tall items. It hasn’t bothered me. I have removed it once to haul a large item and as long as you have someone to help you carry it off the bed, it takes no more than 5 minutes to take off, and put back on.
  16. May 24, 2018 at 9:33 AM
    dxiong0629
    Dennis
    2017 Tundra TRD PRO
    awesome - as for the hydraulic arms how will those hold up with rust and will it last down the road?
  17. May 24, 2018 at 9:38 AM
    Bws326
    Bws326 New Member
    They do look like they will. I put a very this coat of silicone lubricant on the metal (i am ocd). Undercovers customer service is great. I have no doubt if they rust or fail they will replace them
  18. May 24, 2018 at 10:05 AM
    dxiong0629
    Dennis
    2017 Tundra TRD PRO
    so they warranty those hydraulic arms?
  19. Aug 17, 2018 at 12:14 PM
    Iceman09
    Iceman09 New Member
    2018 Platinum in Blazing Blue
    Undercover Ridgelander Tonneau cover
    I have a Ridgelander but have had problems with water running in. Not only around the tailgate, but also on the sides and also close to the cab.
    I paid a local place to order and install... which was only $100 more than the best online price I could find. I’m going to start by taking it back to them and see if they can improve things. Anyone else have problems with water coming in on this cover?
  20. Aug 18, 2018 at 3:06 PM
    Iceman09
    Iceman09 New Member
    The local dealer worked on the cover and put some silicone in some areas. I think it is more water resistant, but now it is a pain to close. Guys who have had these, are they a pain to close and as you get some use and things break in, do they ease up?
  21. Aug 28, 2018 at 3:22 PM
    Iceman09
    Iceman09 New Member
    Undercover customer service was responsive to my problems with the cover. They sent me a new hinge and after swapping them out, the cover opens and closes properly. The water problem has improved. I suspect other covers do a better job at keeping water out. Or maybe mine wasn’t put on as perfectly as it could have been? Who knows. It’s pretty good. Would I buy it again? Maybe.... If I had it to do over again, I probably would put a soft fold up or less expensive hard trifold tonneau cover on... live with that for a while and save the extra $$... then see if I actually need a more “high end” cover at a later time. These decisions are very challenging when you first get the truck b/c you want to “outfit” it and get going... but it’s hard to know what you are actually getting till it’s on the truck and you’ve dropped the $$.
    Sunnier likes this.
  22. Aug 28, 2018 at 3:32 PM
    Dswenson3423
    Dswenson3423 New Member
    Derrick
    Loudon, TN
    2018 Quicksand CM SR5
    I’ve been contemplating this cover or a ProZ hard tri fold. The ProZ is around $630. May go that route and save some coin.
  23. Sep 11, 2018 at 4:56 PM
    Iceman09
    Iceman09 New Member
    To those that have the ridgelander, did you get those rubber strips in the rhino rack vortex bars? I did not and from what I’ve read, they recommend using those if you are going to do accessories that clamp to the bar. Also, I’m a little concerned about water getting in the slots during winter, then freezing and expanding.
  24. Oct 25, 2018 at 11:49 AM
    Ilgie
    Ilgie New Member
    British Columbia
    08 DC Limited 5.7 4x4
    @Aobraz it’s been about a year since you picked up the Ridgelander. How has it been holding up? Still have it? Interested in picking up one up myself. I have the Undercover Classic now. Like having a tonneau over a canopy, would still like to be able to carry my RTT...
  25. Oct 29, 2018 at 6:17 PM
    Aobraz
    If I remember correctly, The rubber strips were packaged inside the bars themselves. Just had to pull off the end caps to get to them.
  26. Oct 29, 2018 at 6:31 PM
    Aobraz
    I definitely still have it and love it so far. I did make one or two adjustments to help the weatherseal, but have not had any issues with it at all. I don’t often have a need to take it off, but always seem to find myself carrying stuff that needs the full length of the bed, so I’m glad I didn’t go with the roll top and lose that space.
    As far as wear and tear, the cover looks like the day I got it. I don’t really have any complaints about it so far. The only other cover I was really looking at was the diamondback and after seeing some around town I do like the way those look, but having the built in rack integration was the main selling point for me and it hasn’t let me down yet.
    equin and Ilgie[QUOTED] like this.
  27. Oct 30, 2018 at 2:39 PM
    sbxx312
    sbxx312 New Member
    2018 Tundra, 2012 s/c Tacoma
    Thanks for the follow up. Does the Ridgelander use the factory rails?
  28. Oct 30, 2018 at 2:44 PM
    Ilgie
    Ilgie New Member
    British Columbia
    Thanks. Just what I wanted to hear, unfortunately for me though I emailed them and they do not make the Ridgelander for the 2nd gen Tundra. They said the box dimensions are different and it wouldn’t work with the older style box.
    You or anyone have an idea what the differences are between 2nd and 3rd gens? I’m new to the Tundra game, only had mine about 3 weeks...
  29. Nov 2, 2018 at 2:00 PM
    Ilgie
    Ilgie New Member
    British Columbia
    I wonder if you would be so kind as to measure the actual outside dimensions of the cover itself. A rep for Undercover has told me that the cover won’t work with ‘07 - ‘13 Tundras because of the thickness of the tailgate.
    Other than the tailgate the box dimensions are exactly the same between the two trucks. If the cover is short enough that it won’t hang over the back of my tailgate I might pull the trigger.
  30. Nov 4, 2018 at 3:44 AM
    Iceman09
    Iceman09 New Member
    Interestingly, mine never came with the strips. Undercover correctly said call rhino rack. Rhino rack apologized and mailed me a set for free.
    Not sure how to improve the incoming water. It’s not too bad, but I think it could be better. Anyone have any luck with some easy adjustments?
    equin likes this.
