Undercarriage Treatment?! Yay or Nay?! Pros & Cons?!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Spyker, Dec 5, 2021.
  1. Oct 11, 2022 at 5:55 PM
    #121
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
  2. Oct 11, 2022 at 6:17 PM
    #122
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    1600 is not a rubber.
    Also paint alone will not do anything.
    Hugemoose, LS3 and BravoDeltaRomeo like this.
  3. Oct 4, 2023 at 7:28 AM
    #123
    Spyker
    Spyker [OP] I’m a dude,playin a dude,disguised as another dude
    Might switch from FluidFilm to WoolWax, just to try it and see if it stays in place longer.
    does anyone know if there’s issues applying woolwax over existing FluidFilm? They’re both Lanolin based, so I would think not, but figured I’d ask in case someone knows something I don’t, thanks.
  4. Oct 4, 2023 at 8:03 AM
    #124
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Just spoke to a local guy yesterday that does fluid film and wool wax. He does wool wax on his vehicle but most he said he does is fluid film because of being a little cheaper. But his opinion using both he thinks the wool wax is much better and last longer. I’m probably having him do wool wax on my 23 4runner Pro. He also removes the wheels where most places don’t. He is very thorough.
  5. Oct 4, 2023 at 8:18 AM
    #125
    Hugemoose
    Hugemoose New Member
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    You'd be fine. I used FF on our daily drivers 2 years ago, and last year I switched to 'Blaster Surface Shield. All are lanolin based so it's fine. Surface shield has seemed to hold it quite well except in high contact areas (where water gets splashed on suspension parts), but that's pretty expected for any of these products.
    That said, I go to a Line-X facility and have Krown applied on my Tundra. Next month I'll be going for my 5th application and I couldn't be happier with how it's holding up.
