Undercarriage Treatment?! Yay or Nay?! Pros & Cons?!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Spyker, Dec 5, 2021.
  1. Dec 16, 2021 at 6:36 AM
    #91
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    Never even heard of such a thing. I have enough trouble keeping the body clean, never mind the frame! :rofl:
  2. Dec 21, 2021 at 5:35 AM
    #92
    jashotze
    jashotze New Member
    2020 Barelona Rd Tundra SR5
    Firestone Ride Rite Rear Bag kit, Leer Bed Camper Shell, Leather Seat upgrade, Truck bed lights, UHF/VHF Ham Radio
    I just treated the entire bottom of my 20 Tundra with the CRC Blue can from Amazon. I bought 6 cans and it was about 90 dollars. Spend the few buck to buy the larger nozzles and one of the handle add on attachments. It saves a mess. Using a straw made it work much better and controlled the spray way better. Without a straw there was a lot of wasted spray. I used 3 cans and got basically everything. I removed the spare tire but didn't remove the skid plate. So far is has held up well and i will be driving to michigan this week for a few weeks and looking forward to seeing how it holds up.
    Spyker[OP] and WILLINH like this.
  3. Dec 22, 2021 at 8:57 AM
    #93
    MeetJoe
    MeetJoe New Member
    Maryland
    2021 CrewMax SX
    OEM TRD Pro Led Headlights OEM LED Fog lights iHacker Harness OEM Tube Step OEM trifold hard tonneau OEM Driverside Grab Handle and Pillar OEM Exhaust tip Wireless CarPlay CarLinkit 3.0 Snack Crumbs
    Crawled under truck to investigate. Treated some surface rust with a rust cleaner (must for rust) and then hit it with rust reformer.
    Saw rust on a plate/axle/wheel mounting bracket? And wanted some insight from you all.
    Any harm hitting it with rust cleaner?
    Any harm hitting it with rust oleum rust reformer?
    Any harm hitting it with CRC?
  4. Dec 23, 2021 at 2:32 PM
    #94
    Spyker
    Spyker [OP] I’m a dude,playin a dude,disguised as another dude
    Do you all remove the engine skid plate and spray the bottom of the engine and the components as well, or is the engine a no-go similar to the brakes and exhaust?
    TheDanimal likes this.
  5. Dec 23, 2021 at 4:04 PM
    #95
    LS3
    LS3 New Member
    2021 TRD Off-road Premium
    I recommend trying to get at all the small fasteners on the pans aside the from body panels and frame/suspension components. Usual caveat to avoid pulleys and belts..
    Depending on the product you use, some act as a dielectric grease and is safe for electrical connections as well.
    Spyker[QUOTED][OP] likes this.
  6. Dec 23, 2021 at 4:22 PM
    #96
    joesTundra
    joesTundra New Member
    Joe
    2018, Toyota Tundra Limited, TRD 4x4 off road
    Don't waste your time and money
  7. Dec 26, 2021 at 3:10 PM
    #97
    Spyker
    Had the opportunity to spray the underside of the truck today with FluidFilm, worked really well with the WoolWax Pro gun (made by Kellsport). Overall very happy I did it, if I ever need to work on anything under there it might be a little messier than it was before, however I'm confident that the rust will be very minimal, if any.
    I did quite a bit of research on everything, so if anyone else has any questions or needs some information, this thread has been super helpful and I'll continue to 'watch' it in case anyone has any questions or needs any assistance.
    Ran the spray gun at 80psi (seem to work very well at that pressure), used the wand extension to get into hard to reach areas, and the 360 degree tipped wand inside the following;
    frame members using the small access holes
    top of the frame & cross members
    all 4 doors by removing the small black covers on the side of the doors
    bed panels after removing taillights
    tailgate after removing the access panel
    under the actual hood there were a few openings large enough for the wand
    the little hidden leaf trap at the bottom of the front quarter panels
    Ambient temp was approximately 68F, which was a little on the 'cooler' side given how 'thick' the gallon of fluid film was. What helped was that as I was prepping the driveway, compressor, spray gun, etc, I had the gallon sitting in a large pot filled with very hot water for about an hour, this helped heat the product, and then vigorously shaking it helped tremendously and I had no issues running it through the gun this way, took about half a gallon doing the entire trucks drivetrain and all the aforementioned areas.
  8. May 14, 2022 at 7:03 PM
    #98
    tundra121
    tundra121 New Member
    BA374676-833A-422E-90AD-7FB3281FC94C.jpg 9508D6E5-BCF2-452B-867D-5C78E7FABDE6.jpg Now that winter is over and salt is finally off the roads I had a look under the truck to see how it is holding up against rust. Considering it’s a 2016 and has been through 6 winters is not doing to bad.
    Using corrosion free for rust protection seams to be working ok.
  9. Sep 22, 2022 at 7:54 AM
    #99
    Spyker
    Just finished applying my 2nd coat, doing it while outside temps are a little warmer definitely made it a little easier with the FF being a little more viscous.
    Hugemoose likes this.
  10. Sep 22, 2022 at 11:14 AM
    #100
    Hugemoose
    Hugemoose New Member
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    Yeah I'm sure that helps. I've seen people put buckets (if you're buying in bulk) on a hot plate, or put the cans in warm water. I do the same for spray paint sometimes too if it's a bit cooler out.
    Glad to see you're keeping up with it. I'm about to go get my 4th Krown treatment and I'm looking forward to it.
  11. Sep 22, 2022 at 1:02 PM
    #101
    FrostyTundra22
    FrostyTundra22 No longer new member
    2020 Toyota Tundra 1794 Crewmax
    What are some areas to avoid? Are we supposed to only do the frame? I just installed the cat shields also but would like to have rust prevention as I am in Minnesota and we have salt on our roads most of winter.
  12. Sep 22, 2022 at 1:16 PM
    #102
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    Are you going to place in York or where?
  13. Sep 22, 2022 at 1:35 PM
    #103
    Spyker
    I try to avoid spraying directly onto braking components; discs, calipers, pads, etc.
    Any hot surfaces like exhaust, engine, transmission, I don’t spray directly, but you’ll get some overspray on it, not a big deal, it’ll burn off or drip off once the FF gets viscous enough
    Other than those areas I really don’t avoid anything else, I don’t spray the driveshaft, but I quite literally spray everything else that’s metal, frame, diff, axle, suspension components (springs, leafs, A-arms, etc), inside the doors, tailgate, frame, cross members, bottom of the bed, bottom of the cab, etc.
  14. Sep 22, 2022 at 1:43 PM
    #104
    Spyker
    I like knowing it’s protected from any road salt/brine that might, or might not, hit the roads in my area, and it’s nice to look under a 3 year old truck (almost) and still looks new.
    When I put my first treatment on a while back I had to put the gallon of FF in hot water since I waited a little too long into fall to get it done, so I decided to do it a little earlier and I’m glad I did.
    Hugemoose[QUOTED] likes this.
  15. Sep 22, 2022 at 2:13 PM
    #105
    SpyderRC
    SpyderRC New Member
    2021 Limited Nightshade
    I had the same problem last fall. This time around I bought a fry daddy to heat it up before I put it in the sprayer. So I’m going to try and hold off for another month or so before I apply.
  16. Sep 23, 2022 at 2:43 AM
    #106
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Just had my undercarriage sprayed with NH oil, last year was fluid film. With the amount of salt they use on New Hampshire roads I get it sprayed almost yearly.
    68 RS/SS, Leo's first and Spyker[OP] like this.
  17. Sep 23, 2022 at 5:14 AM
    #107
    Hugemoose
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    Yup, I've gone to the Line-X shop in York every year. There is a shop closer in NJ now, but I'll still probably go out to York. They've been great every time. I bought the truck used in October 2019 and went immediately there, first application being in November 2019. I've gone once a year, and if I maintain that they will warranty any rust that occurs below the A/B pillars up to $5k.
    I know I could save money if I did it myself with fluid film or something else, but the fact that they get in every body panel (they actually drill holes near the kick panel to gain access to the rocker panels and lower sections of the body. Some people don't like this, but I've seen zero negative effect or rust from these holes), through the engine bay, and even spray inside the boxed section of the frame, I have absolutely no problem spending the $150 it costs per year. I use fluid film on lot of my other vehicles as needed, but I don't care about any of them as much as I do about my truck lol.
  18. Sep 23, 2022 at 6:08 AM
    #108
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    You obviously don't live where it gets snow 6 months a year.
    It's that time again.....getting ready to do my 2nd year of DIY application of CorrosionFree. I'm going to give the underside a good wash with the pressure washer and a new long curved wand first. If I have time, I may wire brush a few areas and give them a quick POR-15 brushing.
    TWJLee and Hugemoose like this.
  19. Sep 23, 2022 at 9:07 AM
    #109
    LS3
    LS3 New Member
    I, like you, live in a spot where there's salt/brine on the roads 6 months a year. Been doing CorrosionFree since I bought my '21. For prep, I found an undercarriage washer / water broom (Ryobi - https://www.homedepot.ca/product/ryobi-water-broom-11-inch-pressure-washer/1001029363) attachment for my pressure washer that does a great job. There's a brass filter/fitting to reduce flow, which I removed and it easily pulls the grit/grime off the frame, body panels, etc.
    I overapply in the wheel wells as I did notice the control arms and frame section around the wheels tends to get the most spray/abuse. I tend to try and get my application done late-July or early August while the temps are high enough to promote lots of creep into seams.
    This is my daily (also parked outside) after two winters and three summers:
    68191944157-169-AFA64-9993-4736-A27-F-A5_2b0a3611cc718ebafc67a9581d732192d0a67938.jpg
    68191940844-0-EDFF1-E9-2566-43-E2-BA0-B-_03895e3775c1af0b3e6c7b0ada51d5a17ebe6329.jpg
    68191939097-F34-FE208-B754-4-BC3-B963-9-_06ca76ec7fa015e01a5ba52923c4a8f214dcd91f.jpg
    68170577881-0-F3-D9624-55-EB-4-FAC-BE3-A_cb2a5e41bafa29ab6c21663cc87ebd11a96ea3dd.jpg
  20. Sep 23, 2022 at 12:56 PM
    #110
    Tundra_King1
    Tundra_King1 New Member
    Ryan
    2018 Tundra 4x4 5.7L Crewmax
    2.5" Level with Bilstein 5100s, 275/70R18 Nitto Ridge Grapplers, and JBA UCAs.
    I just spray the underside down often and if any corrosion appears, I wire brush it and coat it with Extreme Chassis Black. I have a 2018 and get complements on how clean it is under there.
    BravoDeltaRomeo likes this.
  21. Sep 23, 2022 at 1:21 PM
    #111
    Fallingblock
    Fallingblock New Member
    Southern MD
    2017 SR5 DC Tundra
    I do the same every fall. Probably coming soon
    WILLINH likes this.
  22. Sep 23, 2022 at 1:36 PM
    #112
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Have zero rust on 19 treated with Noxudol 1600 and 700 in cavities for 3 years now. Besides a few spots touched by ice/rocks/boulders when offroading. Going to apply the same combo on wife's 22 Sequoia.
    WILLINH likes this.
  23. Sep 23, 2022 at 2:02 PM
    #113
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    I live just below York. Could you pm me their info and maybe yours too in case they have a referral program? Send some pics of what yours looks like please.
  24. Sep 23, 2022 at 3:26 PM
    #114
    AGSport
    AGSport New Member
    PA
    21’ AG Sport
    Hugemoose, WILLINH and Bergy24 like this.
  25. Sep 23, 2022 at 3:48 PM
    #115
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    Is the the TRD PRO skid with the valhalla cat shield?
  26. Sep 23, 2022 at 4:47 PM
    #116
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Yes it is Dan!!
  27. Sep 24, 2022 at 4:13 PM
    #117
    Charliebrn
    Charliebrn New Member
    NW Ohio
    2017 DC Limited 4x4 Tundra
    Tyger Folding Tonneau cover Polished stainless running boards LED interior lighting VLED Footwell Kit LED Bed lighting
    I have a 2017… I did an initial thorough hit with FF and touch it up every fall. Heavy rust belt, but not a spot on my truck. Still looks like new underneath.
  28. Sep 24, 2022 at 4:42 PM
    #118
    FrostyTundra22
    I’m in Minnesota. Definitely need to do this.
  29. Sep 26, 2022 at 6:47 AM
    #119
    Hugemoose
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    The other guy beat me to it lol. They don't have any sort of referral program unfortunately. But they do nice work; I would highly recommend them.
    Bergy24[QUOTED] likes this.
  30. Sep 26, 2022 at 12:41 PM
    #120
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Okay, I did it.
    This a 2022 Toyota frame in 2022:
    Toyota apparently utilizes child labor, because the welds are, ugh...
    When I was blowing compressed air through the frame, water sipped through the holes in welds. Used 2 cans of Noxudol 700 - a cavity wax, went into frame channels and onto frame's top in rear, where Raptor Schutz gun could not reach; 2 cans of 1600 as well, which hardens to asphalt consistency in 2-3 years and laughs at gravel and road debris for the next decades.
    But first degrease the frame
    I wasn't particularly careful in avoiding spraying over the TRD shocks, exhaust or rubber boots. Tundra got a much worse overspray 3 years ago, 'cause I've used a bedliner gun, and nothing happened to it :)
    Missed some spots because of tight clearance and very bright sun light, will address it later.
    So, in two decades the car triples its MSRP, because it is:
    - low miles (less than 1,000,000 miles)
    - rust free
    - TRD PRO
    - V8
    - Sequoia
    But I won't sell it :)
