Under seat storage lid
Discussion in '3rd Gen Tundras (2022+)' started by Solo707, Jul 26, 2022.
  1. Mar 8, 2023 at 7:17 AM
    TheLordwoulddriveaTundra
    TheLordwoulddriveaTundra New Member
    2022 Tundra Platinum Crewmax 4WD, Mag Grey
    Talons Cat Plate Tuff Skinz Inserts RetraxOne XR Bed Cover Premium Shield PPF Revivify Coating OEM Console Safe WeatherTech Mats
    It looks like the lids don't stay up by themselves. Obviously not a crazy big issue, but I go back and forth frequently to my underseat storage and leaving the seats up is easy. I wouldn't like the first world problem of lifting, holding and closing the lids every couple of minutes. I could be wrong, but none of the pictures show a view of it in the truck with the lids up and not being held by a hand. I don't see any spring mechanisms or gas struts/springs/lifts on it either. Looks like standard hinges. I don't like the price, but there aren't many options.
  2. Mar 8, 2023 at 6:39 PM
    havasubud
    havasubud Owner ESP Truck Accessories Vendor
    Earl
    Corona, California
    2022 Tundra CrewMax Limited TRD OR 4x4
    Factory Tube Steps, TraiFX tri fold tonneau cover
    So the one that is in my truck does not have the gas springs in it. We didn't know it wouldn't stay up until I got it into my truck which was pretty irritating since this is the third prototype. I had my engineer add in the mounting points for the gas springs, so we will have them on there.
    Spickett78 likes this.
  3. Mar 8, 2023 at 6:56 PM
    Good to know, thanks!
  4. Mar 17, 2023 at 4:57 AM
    UCKYUK
    UCKYUK New Member
    Yeah, it’s frustrating to spend $60K+ on a truck, and then have to rig something out of plywood, just to have a flat surface in the back, for a dog crate. This is really my only complaint with the truck, but damn.
    This is one area where the Titan MURDERED the Tundra - they have a locking storage cover, that folds out flat. Done!!!
    Check it out, 35 sec into the vid: https://youtu.be/IsPR4kPJfVw
    Personally, I think that storage area was an afterthought - the high-roller trims will be hybrid, and won’t be an issue, so they just threw in the bins for the ham & egger trims. They don’t care to invest much more than that into making them actually useful, haha
    Boerseun likes this.
  5. Mar 30, 2023 at 4:35 PM
    Datsun72
    Datsun72 New Member
    2023Silver 1794 TRD
    Awaiting arrival
    Sure seems like a bunch of us are looking for a simple fairly inexpensive cover to make this are flat. sure hoping something comes up
  6. Apr 9, 2023 at 7:30 AM
    troutback
    troutback New Member
    2023 Blueprint SR5 CC
    So does the hybrid have a cover? Victory 4x4 makes an under seat molle panel for the hybrid and in the picture you can see a TUNDRA under seat cover. If so I am sure it could be modified to work for our non hybrid models.
    https://www.victory4x4.com/product/VTU22UMP.html
    AND likes this.
  7. Apr 17, 2023 at 3:47 PM
    upsbryant
    upsbryant New Member
    David
    2023 Tundra SR5 Lunar Rock
    I am working on a lid for my storage space under the back seat. The seat belts and anchors are an issue but I think I can make it work. Stay tuned.
    Mattedfred likes this.
  8. Apr 17, 2023 at 3:51 PM
    upsbryant
    David
    Is it possible to make to cut out for seatbelts and anchors? I wish someone would make a lid, I’d buy in a heartbeat.
  9. Apr 17, 2023 at 4:10 PM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    I'm not saying this because I'm blindly loyal to Toyota and pick apart all other makes. Toyota could use a little help in the aesthetics design and creature comforts dept, that's for sure. If I could meld the auto makers together, I'd have Toyota build the the truck, have Ford in charge of interior design and GM in charge of body and wheel design. I rather like Toyota's design from a simplicity, reliability and redundancy point of view.
    That said, that back seat setup in that vid looked like a great concept, but I imagine it's cheaply made, has a lot of moving, rattling parts and probably ends up with broken parts that are expensive to replace. Toyota tends to keep the Tundra rather simple compared to other trucks. I'm actually okay with that.
  10. Apr 18, 2023 at 7:52 AM
    troutback
    Just have to notch around them and maybe make some supports. I need to mock some up in CAD (Cardboard Aided Design) and then make them in 1/4" plywood.
  11. May 14, 2023 at 9:39 AM
    PERRY1060
    PERRY1060 Hammer Down
    Perry
    Indiana
    Blk on Blk 22 Ltd 4x4
    TRD wheels, skid plate, black fender flares, mud flaps and running boards. Pirelli Scorpion 275/70/20 Allterrain Plus tires
    I was thinking the center supports could go in the movable partition slots. Maybe even use the partitions that came with our truck and add shim on top of them to make up height difference if there is gap between cover and partition.
    troutback[QUOTED] and upsbryant like this.
  12. May 29, 2023 at 10:29 AM
    Datsun72
    Datsun72 New Member
    2023Silver 1794 TRD
    Awaiting arrival
    I had a Black plastic cover made for the cargo storage area on a 2023 1794 CrewMax. I had the OEM braces replaced to level the top. The back clears the belts etc. with no issues with the seats in an up or down position. The top I attached with Velcro for easy removal and access. Hope this information helps. Cost $250 if I consider having more made, might deliver in 250 mile area of Grand Junction, CO
  13. May 29, 2023 at 9:59 PM
    NATE4SURF
    NATE4SURF New Member
    Laguna Hills, CA
    '23 TUNDRA TRD CREW 4X4, was ‘05 TUNDRA TRD CREW 4x4
    I’d buy one I’m in Southern California but I’d probably pay for shipping no problem.
  14. May 29, 2023 at 10:21 PM
    NATE4SURF
    Laguna Hills, CA
    Is this measured in a CAD file or anything? Meaning if I had a cnc plastic shop near me could they make it from a template? Then I’d just pay you for your design? Thanks or I’d buy one regardless.
  15. Jun 19, 2023 at 10:07 AM
    Foxjj
    Foxjj New Member
    JJ
    @Datsun72 what was the thickness of the board you used ?
  16. Jun 19, 2023 at 10:20 AM
    ScottW714
    ScottW714 New Member
    I feel like I saw a picture of the hybrid under the seat and there was a cover.
  17. Jun 19, 2023 at 10:47 AM
    Texan-1794
    Texan-1794 New Member
    2023 Tundra 1794
    2023 Blueprint Tundra 1794 - Stock to the Bone!
    I think the hybrid has no underseat storage. The HV battery there and its covered.
    Hella Krusty and Mattedfred like this.
  18. Jun 20, 2023 at 3:24 PM
    ScottW714
    And it's what? I know there isn't storage, but the access cover might do the trick.
  19. Jul 11, 2023 at 11:18 PM
    #49
    havasubud
    Earl
    Corona, California
    So here is the final product. We are shipping out the first orders tomorrow, and have 7 left of the first batch.
  20. Jul 12, 2023 at 11:24 AM
    #50
    AND
    AND New Member
    Washington, PNW
    Do you have a link to lace an order?
  21. Jul 12, 2023 at 11:34 AM
    #51
    NATE4SURF
    Laguna Hills, CA
    Does this just sit inside the old one?
  22. Jul 12, 2023 at 1:32 PM
    #52
    ScottW714
    What is the cost, do they come with mounting hardware, and how does one go about ordering them ?
    Those are done very well, good job.
  23. Jul 12, 2023 at 1:55 PM
    #53
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    I would take one if you made more.
  24. Jul 12, 2023 at 1:59 PM
    #54
    eddiefromcali
    eddiefromcali New Member
    Eddie
    100% Stock
    $1,000
    https://esptruck.com/products/tundra-2022
  25. Jul 12, 2023 at 2:15 PM
    #55
    Wood-Dro
    Wood-Dro New Member
    Do the seats still go down and be useable?
  26. Jul 12, 2023 at 2:31 PM
    #56
    ScottW714
  27. Jul 12, 2023 at 7:27 PM
    #57
    G3ardnut
    G3ardnut Brushed Chrome is COOL
    Joe
    Canada
    2023 Limited TRD Offroad Crewmax Celestial Silver Metallic
    Your under-seat storage box looks fantastic. There is only one thing I think I would do for future designs and that would be to add one or two removable/adjustable vertical dividers with different slot locations so you can divide up the storage compartments if you want to (like post #44).
  28. Jul 12, 2023 at 8:17 PM
    #58
    havasubud
    Earl
    Corona, California
    So the storage is $915.95 which is our initial pricing on it. It comes with all the mounting hardware which includes tamper proof screws that make it so you need a special bit to remove the mounting screws. Here is the link to purchase: https://esptruck.com/products/tundra-2022
    We also have the install video on YouTube. Here is the link to that: https://youtu.be/v50sxyDN9Vs
    If anyone has questions, just ask here or you can call me at 951-858-3418.
    Mattedfred, troutback and G3ardnut like this.
  29. Jul 19, 2023 at 3:48 PM
    #59
    troutback
    Wow. That came out very nice.
  30. Jul 19, 2023 at 4:19 PM
    #60
    havasubud
    Earl
    Corona, California
    Thank you! The one shown in the video is our prototype. The production units have gas assist springs to hold the lids open.
    G3ardnut likes this.
