UltraGauge vs ScanGauge
Discussion in '2.5 Gen Tundras (2014-2021)' started by BlueBottle, Apr 18, 2017.
  1. Aug 31, 2021 at 11:24 AM
    #61
    Elroy_unlimited
    Elroy_unlimited New Member
    Eric
    Murfreesboro TN
    2017 limited crew max
    I have a scan gauge and I like it. I had it in my Tacoma before I sold it. I programmed it using the method above to get trans temp. I monitor trans temp, water temp, mpg and volts
  2. Aug 31, 2021 at 11:54 AM
    #62
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I have both. I like the SG better. Overall it is not as sophisticated as UG but it is so much easier to set up and use. I have had an SG in my truck since 2013 and it has never had a problem, cold or hot weather with my truck parked outside.
    SG pros
    Super easy to set up. You set up the gas by filling up and thats it.
    Easy to read
    No annoyances.
    SG cons
    Not sure what some values really are. For example, looking at throttle position it may say 21, but 21 what? I assume it is 21% open but it doesn't say. Any temperatures are easy, volts are easy, but some values aren't self explanatory.
    UG pros
    You can watch more stuff at once
    Has more items that you can view than SG
    Has alarms you can set for things like oil change or gas filling
    UG cons
    It takes a lot of work to properly set up. You have to teach it speed by driving a specified distance for example, without doing that the data is not accurate for a lot of things.
    It has alarms for things like oil changes and gas fillings that are kind of a pain to disarm
    You can watch too much stuff,l at once, to the point that it gets harder to read
    The screen doesn't have the best lighting and can be hard to read jn the daytime
    Biggest problem by far- it can't take the heat. In the Summer if temps go above 90, take it out of your car or the screen will stop working. Really.
    JDR76 likes this.
  3. Aug 31, 2021 at 6:37 PM
    #63
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    My UG has had its internal thermometer read 160-175F entering the vehicle on a hot summer day many many times over many years. Never died, but maybe that's where the little bit of light bleed started. It also keeps the oil change trip meter no matter how long you disconnect the battery unlike the Toyota instrument cluster trips. I'd love to replace it with the newer model but unfortunately it's manufactured in Mordor so I never will.
    SGII can be updated too, and multiple ones daisy chained with ethernet cable.
  4. Mar 12, 2022 at 3:30 PM
    #64
    cavalry bear
    cavalry bear New Member
    Cavalry
    2019 Limited Tundra
    None Yet
    You are the Man!!! Thank you!
