UltraGauge vs ScanGauge
Discussion in '2.5 Gen Tundras (2014-2021)' started by BlueBottle, Apr 18, 2017.
  1. Aug 12, 2019 at 2:21 PM
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    2018 SR5 TRD Tundra Quicksand
    Transmission Temperature 1 - pan
    TXD: 07E02182
    RXF: 046105820000
    RXD: 2808
    MTH: 00090005FFD8
    NAM: TF1
    Transmission Temperature 2 - Torque Converter output
    TXD: 07E02182
    RXF: 046105820000
    RXD: 3808
    MTH: 00090005FFD8
    NAM: TF2
    Try these, worked on my 2018 SR5 CM with towing package
  2. Aug 12, 2019 at 2:34 PM
    woodywoodward
    woodywoodward New Member
    Josh
    2018 TRD OFF Road Tundra
    bone stock
    Thank you!
  3. Oct 20, 2019 at 9:08 AM
    Eric32444
    Eric32444 "Pick up your balls and load up your cannons..."
    Eric
    Panama City FL, Lynn Haven
    seems to work for my '19 4.6....thanks for posting!
  4. Oct 20, 2019 at 11:09 AM
    Mike19
    Mike19 New Member
    Chi town
    2019 SR5 CM 4X4 TRD Sport
    TRD Exhaust, Bilsteins 6112/5100, CB Shims 2/1, CB +3 Shackles, Air Ride, RCI Engine and Trans Skid Plates, Cooper AT3 XLT 275/65/20
    These works for my 19 5.7 SR5 CM Sport.
  5. Dec 14, 2019 at 12:13 PM
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
    I just purchased a used scangauge2 on eBay for 50 bucks. I got it mainly to read transmission oil temp to ease drain and fills.
  6. Dec 14, 2019 at 1:19 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    That's a good deal.
    I went with the UG due to price but that was 10 years ago when they had the best rebate ever: $10 back on your card if you passed a short exam on the user's manual. I can't upgrade it to the MX (too old, will need to replace) but will do so eventually for the trans temps. It's definitely been a reliable unit.
    I think the best selling point of the UG is the light sensor and auto dimming. When it's set up right it's both unobtrusive at night and more legible than than the factory screen in the daytime.
  7. Dec 14, 2019 at 5:59 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    I want to watch my transmission temps closer, and favor the Ultragauge layout slightly. The Ultragauge displays six values instead of four, and the Ultragauge MX (and Blue, not EM) will provide transmission pan and post-TC temps. I believe I may have to reconfigure the pre-programmed PIDs according to their website (2017). The Ultragauge MX does not have some features of the EM...iirc the MX lacks the performance measurement feature (0-30, 0-60, etc.). Only place I've seen the MX (v1.4) for sale is on their website. Suggested retail price for the MX v1.4 is discounted 17% to $89.95.
    https://ultra-gauge.com/ZC/index.php?main_page=product_info&cPath=1&products_id=224
    PIDs for Toyota Tundra/Tacoma are shown here on bottom of page 3 for 2015+:
    https://www.ultra-gauge.com/ultragauge/support/Ultragauge_MX_1.3.pdf
  8. Dec 14, 2019 at 6:52 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    The newer Ultragauges can do 4, 6, or 8 items per page, with 7 pages that can be populated and flipped through. Older models like mine are limited to 6 per page and 3 pages total.
    Keeping it at 6 per page will keep the open/closed loop indicator in the corner. Not a huge deal as you can always tell when it's open loop on deceleration when the fuel rate goes to 0 and mpg to 999.9, much like when using a scangauge.
  9. Dec 14, 2019 at 7:03 PM
    crolison
    crolison New Member
    Anybody want to trade? I have an ultra gauge in my tundra and wanting a scangauge.
  10. Dec 20, 2019 at 6:36 AM
    db52282
    db52282 New Member
    David
    Georgia
    2017 Silver Tundra Limited
    Okay, so Ultra Gauge is currently priced at $89.95 on their website and Scan Gauge II is $126.36 on Amazon (see screen shots below).
    I only want to capture and read the Transmission Temperature for use in changing my trans fluid.
    Is there a cheaper way to just get this information or is Ultra Gauge the cheapest and best way?
    Thanks!!
    NOTE: I know about the paper clip thing on the ODB2 connector but want to see if there is another way
  11. Dec 20, 2019 at 9:58 AM
    JohnLakeman
    Well, the Ultra-Guage is clearly cheaper than the Scanguage. That $89.95 Ultra-Gauge MX is a discounted sale price (for Christmas?). I'm not sure how long it will last. There is a cheaper alternative in the Ultra-Gauge Blue Adapter ($79.95), but I'm not sure it would make sense for your intended purpose of ATF level setting to save $10.
    This morning, I received the Ultra-Gauge Blue Adapter I ordered and just unpacked it. See pics below. My first impression of the Adapter was "Man, that thing is small." I chose the Ultra-Gauge Blue Adapter not because it was cheaper, but because it offered a wireless means of reading transmission temperatures using an iphone or Android phone.
    You can download gauge pages for the typical parameters, but you will have to add and setup the Toyota transmission temperatures if you buy either the Ultra-Gauge MX or Ultra-Gauge Blue Adapter. You can build a gauge page from scratch if you like, and the presentation can be as attractive as Torque Pro (Android only), and as complicated as you choose. To use the Blue Adapter, you download the Ultra-Gauge Application from the App Store (Apple) or Googleplay (Android). You can download gauge pages that have most of the parameters you'll want to monitor, and you can add the transmission temps for monitoring using either the corded Ultra-Gauge MX or the Blue Adapter.
    I've just begun to study how to setup the Blue Adapter and the Application, and it's complicated. I hope I haven't bitten off more than I can chew. That's why I wouldn't recommend the Blue Adapter for only the level setting function; the gauge layout is completely flexible, but it's too complicated for the results-oriented to set up. For only level setting, make it easy on yourself and buy the corded Ultra-Gauge MX. You'll still have to build in the transmission temperatures, but it is far simpler than the Blue Adapter with Application. For constant monitoring of engine parameters and transmission temperatures, the wireless option of using Blue Adapter and UG Application appeals to me.
  12. Dec 20, 2019 at 10:19 AM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    I’m thinking about the UltraGauge max 1.4, how do you enter the transmission codes so you can read trans temp?
  13. Dec 20, 2019 at 10:24 AM
    db52282
    db52282 New Member
    David
    Georgia
    John,
    I looked on their website on this page: http://ultra-gauge.com/blue/obdii-manufacturer-gauges.php
    And found these available codes (see screenshot) after I chose for Toyota.
    I would be interested to know how you like the UG Blue and if it shows the Trans Temp to your liking.
    FYI: I am using an iPhone / iPad
    Please feel free to PM me if you like.
    Thanks,
    David
  14. Dec 20, 2019 at 10:26 AM
    db52282
    db52282 New Member
    David
    Georgia
    Js18tundra[QUOTED] likes this.
  15. Dec 20, 2019 at 10:30 AM
    db52282
    db52282 New Member
    David
    Georgia
    Is that red button an ON/OFF switch so you could leave it plugged into your ODB2 port without fear of it draining your battery?
  16. Dec 20, 2019 at 10:59 AM
    JohnLakeman
    No. It powers itself off after it senses the engine is no longer running.
    The red button is pressed and held (>9secs) to initiate the bluetooth pairing with your phone, (Press ~5secs) instruct the adapter that you've just done a tank fill, (<1 sec) to wake up Adapter from "low power" mode. Waking the adapter is not required in normal operation...when you start the engine, the Adapter wakes up and connects to your phone automatically.
    I've just managed to get the Adapter paired to my iphone, shut it down to confirm power down. Then restarted the engine, and the Adapter powered up and connected to my phone automatically.
  17. Dec 20, 2019 at 12:14 PM
    JohnLakeman
    I am not as familiar with the MX, but I believe their website said that the Toyota codes for the MGauges (manufacturer gauges outside standard OBD2) are the same as those used by ScanGauge, and are probably entered the same way, i.e. select off drop down menus and up/down buttons to enter code. The actual codes for transmission temperatures are given on bottom of Page 3 of this link. You'll have to get to the MGauge section first, then select and code from there. Note that Ultra-Gauges (MX and Blue) come pre-programmed for transmission temperatures, but if I understand correctly, for 2016+ you will need to modify the pre-programming:
    http://ultra-gauge.com/ultragauge/support/UG-MX1.4-Supplement.pdf
    For those that have questions about either the Ultra-Gauge MX, or the Ultra-Gauge Blue Adapter, I recommend downloading the user manual of interest here:
    http://ultra-gauge.com/ultragauge/support/UltraGauge_user_manuals.htm
  18. Dec 20, 2019 at 2:01 PM
    Basscat 1966
    Basscat 1966 New Member
    DFW
    2016 SR5 4X4 5.7 White
    6" Lift
    I have a brand new ultra gague I bought on the group buy that I’ll sell for $50 if someone wants it
  19. Dec 30, 2019 at 12:04 PM
    #49
    Tiamat
    Tiamat New Member
    Just got my scangauge 2 back from getting serviced. The back lit stopped working. They fixed and updated the firmware free. Also made in the USA!
  20. Jun 23, 2020 at 10:41 PM
    #50
    Corr2626
    Corr2626 New Member
    Corey
    2014 Tundra Limited
    Looking for options into being able to monitor my trans temp numbers now that I'm towing in my '14. What's my best options in 2020 yall???
  21. Jun 24, 2020 at 6:45 AM
    #51
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I bought a Scangauge II in about 2006 and have used it to pull codes from several vehicles. I don't know if the firmware can be updated but I wonder if it thoroughly gets all the codes for newer vehicles. Anyone know the answer to this?
  22. Jun 24, 2020 at 6:59 AM
    #52
    HTGreen
    HTGreen New Member
    Halsey
    Central Virginia
    Firm ware is updatable, go to their website, I think its like $25 plus postage.
  23. Jun 24, 2020 at 7:06 AM
    #53
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Thanks!
  24. Jul 29, 2020 at 2:49 PM
    #54
    kkim124
    kkim124 New Member
    Torrance, CA
    2016 Tundra Platunum 4x4
    Has anyone been able to convert the TPMS codes from scangauge to ultragague?
  25. Jul 29, 2020 at 6:58 PM
    #55
    JohnLakeman
    No. I haven't played with it for a long time, but I was never able to get Scangauge TPMS codes to work.
  26. Aug 30, 2021 at 2:19 PM
    #56
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    In case anyone is wondering if they work together with a splitter, seems to run without issue. Ye old ultragauge is starting to show its age in the middle of the screen.
  27. Aug 30, 2021 at 2:25 PM
    #57
    Tiamat
    Tiamat New Member
    They repair or replace free of charge
  28. Aug 30, 2021 at 7:16 PM
    #58
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    Unfortunately the ultragauge warranty expired about 12 years ago. The new SGII has a lot better warranty. Its screen is fine; that's a reflection of my hand I think.
  29. Aug 30, 2021 at 8:01 PM
    #59
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    Old post but any chance this is still for sale?
    Tiamat likes this.
  30. Aug 31, 2021 at 4:41 AM
    #60
    Tiamat
    Tiamat New Member
    I got mine just to do trans drain and fills.
