Ultragauge transmission temp setup for 2017 Tundra?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Wintyfresh, May 4, 2018.
  1. May 4, 2018 at 3:09 PM
    Wintyfresh
    Wintyfresh [OP] New Member
    Ramona, CA
    17 Inferno 4x4 DC LB SR5
    I've entered the M Gauge configurations listed for Toyota Tundra/Tacoma with CAN (2016+) as specified in their document and am still seeing Err, anybody mind cluing me in on what I'm doing wrong? Thanks!!
    Mgauge 4 (Torque Converter Temp)
    Mgauge 5 (Transmission Pan Temp)
    Err displayed on page 1 of gauges.
  2. May 4, 2018 at 7:37 PM
    TTund16
    TTund16 New Member
  3. May 5, 2018 at 6:06 AM
    Yota18
    Yota18 Inferno Club
    Upstate New York (the real NY)
    18’ 5.7 TRD Off-Road
    Stock
    I’m having the same issue codes are all correct but displaying error in both
  4. Aug 11, 2019 at 3:47 PM
    Rabidllamas
    Rabidllamas New Member
    Phil
    Kennewick WA
    2019 Cement Crewmax TRD OffRoad
    My build- https://www.tundras.com/threads/rabbidllamas-old-man-build.80802/
    I also having this issue. Even followed the suggestion in the ultrgauge vs scangauge discussion of using the 2012-1015 settings and those did not work either. Keep getting err for the trans temps.
    EDIT - got the 2012-2015 settings to work.
  5. Feb 1, 2020 at 9:52 AM
    Pillguy
    Pillguy New Member
    Andrew
    2019 gris Tundra Limited
    Hi got mine to work in a 2019 tundra crew Max 5.7 leader using the 2012 to 201 programming codes for trans temp and pan temperature 20200201_125154.jpg
    Rabidllamas likes this.
  6. Feb 1, 2020 at 11:50 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    @Wintyfresh appears to left the building, but for any still interested, I suspect the OP was trying to use an UltraGauge EM Plus to read his Tundra ATF temperatures. According to UltraGauge site, transmission temps can only be read with UltraGauge MX v1.4 and UltraGauge Blue.
