Ultimate TUNDRA Wiring Diagrams Collection
Discussion in 'Electrical' started by RainMan_PNW, Jan 12, 2021.
  1. Nov 22, 2021 at 3:05 PM
    #91
    Kramegroeg2021
    Kramegroeg2021 New Member
    Mark
    2013 Tundra
    RainMain. I wanted to let you know I used a tap and ran the wire from the head unit to the passenger kick panel. Connected to the blue wire out of the AI2 and it works great! I also ran a cable to the emergency brake location but I struggled to find the correct connector. It would be easier if Toyota labeled these so I can make sure. Anyhow I couldn’t have done it without your help. Thanks again.
  2. Nov 28, 2021 at 7:11 AM
    #92
    Robson
    Robson New Member
    Rob
    2021 Tundra Crew Max Limited
    This information was fantastic! Thank you so much!
    RainMan_PNW[OP] likes this.
  3. Dec 27, 2021 at 4:11 PM
    #93
    WorkSmarterNotHarder
    WorkSmarterNotHarder New Member
    2008 Tundra 4x4
    Hi everyone! I just joined this forum specifically to gain access to these wiring diagrams, I've searched for some time and this is the only place I could find them online. Wow what an awesome resource! There's a ton of info in here!
  4. Dec 27, 2021 at 5:38 PM
    #94
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Yes, this site has more "unofficial" Tundra info than anything else out there!
  5. Dec 27, 2021 at 6:12 PM
    #95
    Trust86
    Trust86 New Member
    2007 DC
  6. Dec 27, 2021 at 6:24 PM
    #96
    RainMan_PNW
    RainMan_PNW [OP] "Oz" SSEM #82 RGBA #4 Unofficial Forum Treasurer Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Welcome.
    Not just in this thread though - the whole site has so much to offer. From creative ways to spend your money to friendly banter about sushi to a crazy group of degenerates that drop everything for the next release of stickers, you’ll find way more here than just wiring diagrams!
    WVI and TRDFerguson like this.
  7. Dec 27, 2021 at 7:21 PM
    #97
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    This reminds me, I have a coffee cup and more stickers waiting for me when I get home from vacation.
  8. Dec 28, 2021 at 2:34 AM
    #98
    2008 Tundra 4x4
    Lol! I know, I've been reading a bunch of different threads since I signed up. It's like a personal Toyota tech in your pocket plus much more.
    I haven't got to the sticker part yet, maybe after I get my truck fixed.....
  9. Jan 15, 2022 at 7:34 PM
    #99
    Buchon915
    Buchon915 New Member
    Angel
    2008 Toyota Tundra Limited
    Your super awesome! Thank you so much for taking the time to do this!
  10. Jan 19, 2022 at 6:22 AM
    #100
    Jkenn6
    Jkenn6 New Member
    NJ
    23 Tundra
    @RainMan_PNW - Can you help me identify the connectors for the rear taillight (lower brake and upper turn signal)
    I want to make a new harness to add something in between these without cutting the factory wires - so I would need male and female versions of both connectors.
    Appreciate any help
  11. Jan 19, 2022 at 8:56 AM
    #101
    RainMan_PNW
    Casey
    Clark County, WA
    Turn signal connectors you can find information on in this post where I built a harness to add resistors in-line for LEDs.
    https://www.tundras.com/threads/caseys-2021-lunar-rock-trd-pro-build.77317/page-8#post-2098553
    I'm digging on the others.
    Edit: The BRAKE light connector is "R4" (RH) and "R5" (LH), which are both Toyota part number 90980-11020.
    https://www.corsa-technic.com/item.php?item_id=900
    The matching connector is https://www.corsa-technic.com/item.php?item_id=1041
    Jkenn6[QUOTED] and TRDFerguson like this.
  12. Jan 19, 2022 at 11:09 AM
    #102
    Jkenn6
    Jkenn6 New Member
    NJ
    23 Tundra
    @RainMan_PNW Thanks so much for this information!
    Any recommendations on the pin/wire size & insulation size for the 3-way connectors?
    This would be my first time building these types of connectors and I saw your recommendation on the wire size/insulation size for the 2-way connectors in that thread you posted.
  13. Jan 19, 2022 at 11:24 AM
    #103
    RainMan_PNW
    Casey
    Clark County, WA
    Depends a little on what you are doing with the harness and what loads you are introducing. 16AWG is probably still a good size. For the insulation size, the "right" way is to measure the outside diameter of the wire you have with insulation. You should likely be in the 2.0mm ballpark.
  14. Jan 19, 2022 at 11:31 AM
    #104
    Jkenn6
    Jkenn6 New Member
    NJ
    23 Tundra
    @RainMan_PNW I may be introducing some extra load since my grand plan is to have the brake light splice into the top light as well. Then add the "turn as tail module" from Diode Dynamics to have the top/bottom work as brake lights and both flash with the blinker on.
    I would be changing the top and bottom bulbs to LED as well, which would lower the load. But not sure if that would affect wire size.
    (any thoughts are welcome as this is just my initial plan in my head until I start ordering the connectors and module)
  15. Jan 19, 2022 at 11:44 AM
    #105
    RainMan_PNW
    Casey
    Clark County, WA
    I'm not an expert. But based on the size of wiring that is already there, 16AWG should be fine. I assume when you say "brake light splice into the top light" you are talking about on a cap or external rack. As long as you go LED, you've got very little load. And "turn as tail" isn't really adding any load, it is just reconfiguring the harness to send signal to different lights. I'm not aware of DD having one for the Tundra (though Hot Shot Offroad has a setup they just released that also includes full VLED replacement...and isn't cheap).
  16. Jan 19, 2022 at 11:54 AM
    #106
    Jkenn6
    Jkenn6 New Member
    NJ
    23 Tundra
    @RainMan_PNW Correct to all the above.
    I reached out to DD and they had no plans to make one for the tundra, but they do sell the DIY module. It requires the positive turn signal wire and a positive brake wire as the input. Then it provides 1 output wire, which I am hoping that 1 positive output wire could support both the top and bottom LED bulb.
    DIY module: https://www.diodedynamics.com/tail-as-turn-module-diy.html
    (Of course I can add the resistors in-line to prevent hyperflash)
  17. Jan 19, 2022 at 12:00 PM
    #107
    RainMan_PNW
    Casey
    Clark County, WA
    Yeah - I'm not seeing this adding any more significant load. Their wiring on that DIY is 18AWG.
  18. Feb 2, 2022 at 6:27 AM
    #108
    Lone Wolf
    Lone Wolf New Member
    Thanks to you all. Kinda like getting a life preserver.
  19. Feb 26, 2022 at 6:33 AM
    #109
    trevorklat
    trevorklat Don't Mess with Texas!
    The Lone Star State
    2018 Super White Platinum Tundra 4WD CM
    Linex bed liner, Retrax roll-top bedcover, Ranch Hand Summit brush guard, SDHC ABS sensor guards, Interior LEDs, Cargo lamp LEDs, Reverse Light LEDs, Rear TRD sway bar, Valhalla's Shield Cat plates, Husky floormats
    Where did you purchase the connector?
  20. Apr 1, 2022 at 9:16 PM
    #110
    MadDaddy
    MadDaddy New Member
    H
    HUGE HELP!!!! Thanks!
  21. Apr 3, 2022 at 5:03 PM
    #111
    Vman
    Vman New Member
    2010 4.6l SR5
    Hey RainMan any chance you could post a diagram like you did for TranTundra showing the plug at bank 2 of the secondary Air Intake System? I downloaded the PDF but man it's in greek!
  22. Apr 3, 2022 at 8:57 PM
    #112
    RainMan_PNW
    Casey
    Clark County, WA
    I’ll see if I can get to it tomorrow
  23. Apr 4, 2022 at 12:47 PM
    #113
    RainMan_PNW
    Casey
    Clark County, WA
    I think this is what you are looking for.
    2010 Tundra, 4.6L V8 (1UR-FE) engine
    AIP Bank 2
    There's also the Air Injection Control and Pump for Bank 2
    Vman[QUOTED] likes this.
  24. Apr 5, 2022 at 10:56 AM
    #114
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Casey, you would make a fine Southern Gentleman. I cannot think of a higher compliment!
  25. Apr 5, 2022 at 11:08 AM
    #115
    RainMan_PNW
    Casey
    Clark County, WA
    :hattip:
    I'd like to think I'd make a fine gentleman anywhere I went.
    My wife might argue that though...
  26. Apr 5, 2022 at 8:44 PM
    #116
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Most of our wives would never want to call us that - they know the parts of us that aren't! :D
  27. Apr 13, 2022 at 11:41 AM
    #117
    Vman
    Vman New Member
    2010 4.6l SR5
    Yessir Rainman - that is it. Thanks!
  28. Apr 14, 2022 at 1:32 PM
    #118
    Vman
    Vman New Member
    2010 4.6l SR5
    Update - SAIS bank 2 replaced and connector rewired. Held my breath - no codes!! Back in business baby! I appreciate this forum - probably saved me several hundred dollars.
  29. Jun 7, 2022 at 10:36 AM
    #119
    Airman
    Airman New Member
    you are a life savor man
    thank you very much for your efforts :yes:
  30. Jul 22, 2022 at 4:15 PM
    #120
    adamtundra201188
    adamtundra201188 New Member
    Rain man thank you for all the great information need to see if you can help me find the diagrams i need to repair this wire harness
