Ultimate OEM Toyota Parts Thread for 3rd gens (2022+)
Discussion in 'Toyota of Cool Springs Parts' started by Roman, Feb 16, 2022.
  1. May 11, 2022 at 1:51 PM
    #211
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Hey @Roman part number(s) for the platinum badges?
  2. May 11, 2022 at 2:21 PM
    #212
    Roman
    Roman [OP] Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Black out tape
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-tape-black-out-no-759270c010
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-tape-black-out-no-759280c010
    Lots of variations on the gauge cluster. Also, with the way we have to order them with the mileage already preprogrammed and the vehicle not being able to be driven until the gauge cluster arrives, it's not a part I can sell online.
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-molding-sub-assembly-f-750710c040
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-molding-sub-assembly-f-750720c040
    Aseab808[QUOTED] likes this.
  3. May 11, 2022 at 4:49 PM
    #213
    Tbag1118
    Tbag1118 New Member
    TJ
    2022 tundra limited crewmax
    I don't have a video, but I did mine a couple days ago. I advise you have car panel removal tools...there is a set on Amazon.
    You first pop off the top of the bumper where you'd step. There is a black accent piece above the hitch you pop off as much as you'd need to pull the arms out. From there you'll see some pins under the first plastic piece you popped up. There is one pin and one screw from underneath.
    To remove the pins use a small flat head to pop the center of it up.
    Hope that helps some.
  4. May 12, 2022 at 6:25 PM
    #214
    Aseab808
    Aseab808 New Member
    Andrew
    Oahu, HI
    2022 Tundra Limited TRD OR - Windchill Pearl
    @Roman I have one last request for now. Could you get PN’s for the lights on the trd pro grille (3 amber lights and light bar)? As well as the camera bracket for the pro grille?
  5. May 13, 2022 at 9:36 AM
    #215
    Prohit
    Prohit New Member
    2024 Sequoia Platinum
    @Roman
    what is the difference between
    527130c040
    vs
    527130c900
    These are the lower parts of the mustache. I ordered 527130c900 figured they were the correct ones because they are the cheapest. But looking at the thread you state 527130c040 is the black unpainted one. Biggest question is what color is the 527130c900?
  6. May 13, 2022 at 9:58 AM
    #216
    Roman
    Roman
    Franklin, TN
    No numbers on the Pro lights yet, and the camera bracket comes with the camera itself, as seen here:
    The 0C040 is from the SR, while the 0C900 is from the TRD Pro. I know the SR ones are a gloss black, but I have not seen the TRD Pro ones yet. I'm not sure what finish they come in as a replacement part. They're, of course, painted on the truck itself. If the goal is to paint them, either will work.
    ryanwgregg likes this.
  7. May 13, 2022 at 10:19 AM
    #217
    Prohit
    Prohit New Member
    Awesome thank you. You wouldn’t by chance have any other pro part numbers such as the flares or orange TRD marker lights for the grill do you?
  8. May 13, 2022 at 11:52 AM
    #218
    Roman
    Roman
    Franklin, TN
    No sir, I just checked on both, and neither are showing up.
  9. May 13, 2022 at 12:04 PM
    #219
    Tbag1118
    Tbag1118 New Member
    TJ
    @Roman any idea if the electric harness and plug for the tow mirror and the regular mirror are the same? Also a part number for the mirror cap for the regular mirror? Thanks!
  10. May 13, 2022 at 12:14 PM
    #220
    Roman
    Roman
    Franklin, TN
    According to the EWD in TIS, the connector is the same. Are you wanting the painted mirror caps? If so, I have them listed in the OP.
  11. May 13, 2022 at 12:20 PM
    #221
    Tbag1118
    Tbag1118 New Member
    TJ
    My apologies I just went back to original post and saw them. I have heated,power, bsm tow mirrors and someone wants to swap regular mirrors with me. I was hoping it would just be a plug and play?
  12. May 13, 2022 at 12:22 PM
    #222
    Roman
    Roman
    Franklin, TN
    I am still unsure if it is a plug and play deal. Only one way to find out, though. :D
    If you try it out, make sure to let me know yay or nay.
  13. May 13, 2022 at 12:25 PM
    #223
    Troa
    Troa I blue it again.......
    Nomad
    2022 Blueprint Limited
    I just painted mine a few days ago, it's pretty easy. As stated earlier, a pop clip tool is highly desirable. Harbor Freight sells them for next to nothing.
    1. Remove lower trim between bumper arms (Pop clips and 10mm)
    2. Pop up the horizontal black trim pieces on top of either side of the bumper (Above the arms you're replacing)
    - To do this you'll squeeze some thick black tabs underneath the bumper and push them up and out. I used vice grips for this.
    - Start on the outer edge and work your way in. The farthest inside ones are a huge PITA to reach, I left these ones in and just lifted the outer edge up to pivot/bend the trim piece up. This allowed me to gain access to the 3 pop clips that are underneath
    3. Pop out arms and paint/replace. They will be hooked behind the trim piece just to the inside of them so to remove them you want to pivot them off their inside edge, pulling the outside edge towards yourself
    4. Put arms back in, replace the 3 clips under the bumper step cover, then slap the cover back in place. Replace the center trim and you're done!
    If you have an trouble, DM me and I'll send you my contact info. We can video chat if needed
  14. May 13, 2022 at 12:29 PM
    #224
    Tbag1118
    Tbag1118 New Member
    TJ
    Ha, he's across the country so that swap ain't happening without a definite answer.
  15. May 13, 2022 at 12:34 PM
    #225
    Roman
    Roman
    Franklin, TN
    Yep, that'd make it a little difficult.
    Tbag1118[QUOTED] likes this.
  16. May 13, 2022 at 12:37 PM
    #226
    Aseab808
    Aseab808 New Member
    Andrew
    Oahu, HI
    @Roman do you know if the digital cluster would work on the limited models if I was to order from my local dealer. I know you said that they have to program the mileage from the factory, so I was wondering if it’ll be plug and play?
  17. May 13, 2022 at 12:44 PM
    #227
    Roman
    Roman
    Franklin, TN
    Connectors show to be the same. But plug and play.... ¯\_(ツ)_/¯
  18. May 13, 2022 at 9:28 PM
    #228
    Yoda21
    Yoda21 New Member
    Hayward ,ca
    2022 limited Trd crew max
    Do u guys know which front clip piece I would need to get for a mgm limited if I wanted to do paint matched
  19. May 15, 2022 at 6:28 PM
    #229
    jdub22
    jdub22 New Member
    @Roman color matched door handles for smoked mesquite? didn't see them in the pull down you linked to in the OP. assuming just not available yet.
    also looking for the paint protection film but found a few options when i put in
    PT90734220
    i know it says door/mirror etc, but where exactly?
    https://parts.toyotaofcoolsprings.com/search?search_str=PT90734220
    thanks.
    j.
  20. May 15, 2022 at 7:43 PM
    #230
    MMTundra
    MMTundra New Member
    2022 Army Green TRD OR Ltd
    If anyones interested in the matte/satin black window moldings for a CrewMax (not the gloss black) I ordered what’s in the attached photo and looks to be on par with measurements I’ve taken - received all parts today. Don’t have the truck here to verify but should be in the next few weeks (was built 5/3). Parts ordered from a local dealer in CO so I could return easily if they were wrong, sorry Roman! I appreciate your help for rear bumper arms, ordered those from cool springs.247B2E96-8166-4707-924A-C305AF344D44.jpg
    Taikowaza and Tbag1118 like this.
  21. May 15, 2022 at 9:20 PM
    #231
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
    @Roman is the platinum power side and bed steps available through parts/
  22. May 16, 2022 at 4:57 AM
    #232
    Tbag1118
    Tbag1118 New Member
    TJ
    This looks significantly cheaper than the gloss.
  23. May 16, 2022 at 6:33 AM
    #233
    Tbag1118
    Tbag1118 New Member
    TJ
    Wheel TRD Forged Aluminum Matte Black 18 Inch - Toyota (PT960-34200-02)
    @Roman will these fit 2022 tundra? If so do you have a price on them?
  24. May 16, 2022 at 6:36 AM
    #234
    Swarley
    Swarley New Member
    Wrong bolt pattern
  25. May 16, 2022 at 7:43 AM
    #235
    Tbag1118
    Tbag1118 New Member
    TJ
    Ahh good point, I should check the obvious before posting. Is there an 18" sema alloy wheel for the 2022 tundra?
  26. May 16, 2022 at 11:15 AM
    #236
    SoCalJose
    SoCalJose New Member
    I'm interested in this. Would you mind posting some pictures?
  27. May 16, 2022 at 12:15 PM
    #237
    MMTundra
    MMTundra New Member
    Dealer called today actually and my truck is here, as soon as I get the truck and put them on I’ll post some photos - I boxed everything back up in the garage yesterday thinking it was going to be a few more weeks :eek:. Hopefully I’ll have them on this weekend.
    jdub22 likes this.
  28. May 17, 2022 at 12:43 PM
    #238
    Roman
    Roman
    Franklin, TN
    Correct. For whatever reason, Toyota has not released all of the part numbers for the handles yet.
    If I'm being honest on the PPF, I would get it done locally. I've ran into several problems with the precut film that Toyota has, and there are no returns on that stuff because it is coming from another manufacturer that ships direct to dealers.
    Yes and no. They are available, but only as replacement parts. They are not sold as a kit. You would have to purchase everything individually, bolts, brackets, motors, boards, everything. Total is around $1500 for everything, and I'm not even sure it's a plug and play sort of deal. Also, we do not ship running boards/tube steps because of the high probability of them being damaged in shipping.
  29. May 17, 2022 at 4:51 PM
    #239
    Jshep
    Jshep New Member
    22 Army Green Limited TRDOR 6.5
    @Roman can you confirm these part numbers for satin black window trim for a crew max?
  30. May 18, 2022 at 10:34 AM
    #240
    SlimSeville
    SlimSeville New Member
    2022 Tundra SR5 XP
    Hi, Roman is Cool Springs able to order the manual bed step parts? My local dealership told me they were unable to order them for me this morning.
