Ultimate OEM Toyota Parts Thread for 3rd gens (2022+)
Discussion in 'Toyota of Cool Springs Parts' started by Roman, Feb 16, 2022.
  1. Jun 4, 2022 at 7:40 PM
    #271
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    I replaced my tailgate garnish which I bought from Roman and it is gloss black (shiny) and if you look at @PapaDave418 's video, you will see at 1:10 it is shiny.
    https://youtu.be/-4BFrKywB14
    PapaDave418 likes this.
  2. Jun 4, 2022 at 7:51 PM
    #272
    jmay86
    jmay86 New Member
    Josh
    Columbus, Ohio
    '22 Lunar Rock LTD DC TRD-OR
    I probably should have worded my question better haha... I'm wondering if any of the black replacement door handles match the gloss black of the tailgate garnish. I know you can get the flat black handles, but I'm wondering if the other black option matches the gloss tailgate.
    PapaDave418 and Maharisc[QUOTED] like this.
  3. Jun 6, 2022 at 1:19 PM
    #273
    Roman
    Roman [OP] Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Not that I know of. There are the black painted handles, but they have the blue metallic flake in them.
    jmay86[QUOTED] likes this.
  4. Jun 6, 2022 at 1:38 PM
    #274
    jmay86
    jmay86 New Member
    Josh
    Columbus, Ohio
    Ok thanks Roman. I'm going to replace the chrome tailgate handle with the gloss black, but since the Lunar Rock door handles aren't available I was hoping to at least get handles that match the tailgate handle haha... Back to the drawing board...
  5. Jun 6, 2022 at 7:16 PM
    #275
    WrapCO
    WrapCO New Member
    Eagle , CO
    2022 Toyota Tundra 6.5’ CM
    Westcott lift, Method 316 17” wheels, 35x12.5x17 Toyo Open Country AT3
    @Roman do you happen to have a part number for a driver’s side headlight. Standard led reflector version.
    THANKS!
  6. Jun 7, 2022 at 12:21 PM
    #276
    Roman
    Roman
    Franklin, TN
    You have the normal turn signal bulb, or is it the LED turn signal? If it is the LED turn signal, does it have the headlamp leveling function? There's three different headlights, well four if you count the Pro.
  7. Jun 7, 2022 at 12:26 PM
    #277
    WrapCO
    WrapCO New Member
    Eagle , CO
    Standard Halogen turn signal, manual leveling.
  8. Jun 7, 2022 at 12:42 PM
    #278
    2bak
    2bak Thanks
    M
    Bellingham WA
    2018 CM
    @Roman
    Is it possible to order the factory power running boards and associated wiring and switch? I’ve got a platinum without the power boards. But sure would like them. Thanks.
  9. Jun 7, 2022 at 1:13 PM
    #279
    Roman
    Roman
    Franklin, TN
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-unit-assembly-headlamp-811600c230
    It's possible, though I do not know what all is involved with the swap. I'm not sure if wiring is there, or if they will need some kind of harness installed. To find the harness, or harnesses, needed would be pretty difficult to come by if there is not a connector already present. It will be a part of a larger harness, and there's no telling what all it would take if that is the case. There is a computer listed for the boards, and a switch in the dash to turn them on or off.
    This is going to be one of those swaps that someone will have to try and see what all it takes.
    ryanwgregg likes this.
  10. Jun 7, 2022 at 8:43 PM
    #280
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
    @Roman - do you have part numbers or pricing for headliner, pillars and pano cover for platinum? Looking to see cost to black out the pro lol
  11. Jun 7, 2022 at 9:12 PM
    #281
    Jshep
    Jshep New Member
    22 Army Green Limited TRDOR 6.5
    Just out of curiosity, what is your upper limit? $1,500? $2,000?
  12. Jun 7, 2022 at 9:42 PM
    #282
    DrZoidberg
    Dave
    SATX
    Tesla MYP
    3k
  13. Jun 8, 2022 at 12:36 PM
    #283
    Roman
    Roman
    Franklin, TN
    Got a VIN? There are pages of options on the headliner. The panoramic roof cover is $345 and all of the pillars are $590.
  14. Jun 8, 2022 at 3:10 PM
    #284
    DrZoidberg
    Dave
    SATX
    Tesla MYP
    Pulled this vin on a used 22 Platinum for sale.
    5TFNA5DB9NX006843
  15. Jun 8, 2022 at 4:19 PM
    #285
    Cnsdj4hire
    Cnsdj4hire New Member
    2025 Tundra SR5 TRD OR
    @Roman I wanted to say thanks for all your posts about part numbers and accessories for our Tundras! This is how I learned about this forum and joined!
    Schak and WrapCO like this.
  16. Jun 8, 2022 at 5:23 PM
    #286
    WrapCO
    WrapCO New Member
    Eagle , CO
    He’s the man, pretty much the only reason we have 90% of these parts.
    Schak and Roman[OP] like this.
  17. Jun 8, 2022 at 5:59 PM
    #287
    TSS Army Green
    TSS Army Green New Member
    @Roman Do you know the part number for an Army Green gas cover?
  18. Jun 8, 2022 at 6:00 PM
    #288
    Jshep
    Jshep New Member
    What happened?
  19. Jun 8, 2022 at 6:10 PM
    #289
    TSS Army Green
    I popped off the gas cap cover so that I can give it to the auto body painter as a sample to color match the chrome grille surround. Well, I got it back with some type of chemical on the gas cover. I tried washing it off with Dawn dish detergent soap and no luck. I will see if it can be buffed out in the next couple of days. If that doesn't work then I might order a new gas cover. I just don't know if it comes painter or not.
  20. Jun 8, 2022 at 6:13 PM
    #290
    Jshep
    Jshep New Member
    Sounds like the paint shop owes you a new/repainted gas cover….good luck
    Also, shouldn’t they be able to just use the paint code?
  21. Jun 8, 2022 at 6:22 PM
    #291
    TSS Army Green
    They got the paint code off of the inside of my driver side door jam but they just wanted to make sure with a sample in hand.
  22. Jun 9, 2022 at 8:41 AM
    #292
    DrZoidberg
    Dave
    SATX
    Tesla MYP
    @Roman do you have the part # for the TRD Pro tail gate inlays?
  23. Jun 9, 2022 at 12:10 PM
    #293
    Roman
    Roman
    Franklin, TN
    Headliner for that is $1813. No way I could ship that, but it gives you an idea on price.
    No problem, good sir. :)
    Unfortunately, those do not come pre-painted when ordering as a replacement part.
    No sir, not yet anyway.
  24. Jun 9, 2022 at 12:16 PM
    #294
    DrZoidberg
    Dave
    SATX
    Tesla MYP
    What's the part # for the headliner for reference. And the pillars and pano cover too.
  25. Jun 9, 2022 at 1:12 PM
    #295
    Roman
    Roman
    Franklin, TN
    63380-0C870-C0
    63306-0C040-C0
    62210-0C080-C2
    62220-0C080-C2
    62410-0C050-C0
    62420-0C050-C0
    62510-0C190-C0
    62520-0C190-C0
  26. Jun 10, 2022 at 10:17 AM
    #296
    Robbsolid
    Robbsolid New Member
    Puyallup, WA
    2022 LTD HV WCP.
    This thread is trouble for the wallet.
    Do you know if it's possible to buy gloss black finished fender flares like the platinum comes with? I hate the grey that comes on the limited, and would rather not spend the time painting them if they're cheap enough.
    Thanks!!
  27. Jun 10, 2022 at 11:54 AM
    #297
    Roman
    Roman
    Franklin, TN
    Looks like Toyota did have separate part number for the Platinum flares, but now they're all superceded to the matte black option. Based on the pricing of the flares plus shipping, you probably would come out cheaper having them painted.
    ryanwgregg and Robbsolid like this.
  28. Jun 10, 2022 at 2:44 PM
    #298
    Jr3volution
    Jr3volution New Member
    Johnnie
    DFW TX
    2022 Tundra Platinum
    Any updates to the Pro Grille 3 markers lights? And fender flares?
    WrapCO, Robbsolid and ryanwgregg like this.
  29. Jun 10, 2022 at 4:20 PM
    #299
    Robbsolid
    Puyallup, WA
    2022 LTD HV WCP.
    Do you have any links to them just in case?
  30. Jun 12, 2022 at 3:18 PM
    #300
    jmay86
    jmay86 New Member
    Josh
    Columbus, Ohio
    Any update to the Lunar Rock or Army Green handles? Thanks!
