UHF/VHF Radio?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Tundra-Canuck, Mar 28, 2020.
  1. Mar 28, 2020 at 2:36 PM
    Tundra-Canuck
    Tundra-Canuck [OP] New Member
    Les
    2014 Crewmax
    Bags, command air, flares, light bars, titan tanks
    Where are folks finding a good spot for these radios? Thanx
    Rica25 likes this.
  2. Mar 28, 2020 at 2:57 PM
    ezdog
    ezdog New Member
    Gateway To The West
    Which radio?
  3. Mar 28, 2020 at 3:00 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
  4. Mar 28, 2020 at 3:19 PM
    ezdog
    ezdog New Member
    Gateway To The West
    An HT like the "Feng" is not as big as iPhone really but somewhat more bulky and heavy too.
    This is a pretty subjective thing and some people like the radio in their face and others do not.
    So many phone holding solutions will also work fine for a handheld.
    I recently played with one of those Weathertech cupholder based holders and it is a lot nicer than you can imagine if you have not held one in your hand yet and that would be one way.
    I use the Scosche now for all phones and they work OK for a Handheld radio as well.
    I was about to take a pic of the HT and phone together but them realized my only easy camera is my phone?
    I would also only suggest not using an HT in a car too unless you are going to stick an external antenna on it outside the car,otherwise can be pretty frustrating for sure.
  5. Mar 28, 2020 at 3:52 PM
    Tundra-Canuck
    Les
    2014 Crewmax
    Kenwood TK-7360H.
  6. Mar 28, 2020 at 3:53 PM
    No Limit
    No Limit New Member
    Alberta
    2020 Tundra TRD PRO 4” Readylift
    I mounted my VHF radio inside the center console against the back. The handset cable fits in the notch so I can still close lid when handset is out when at work, when not at work handset goes back into center console and no one would know it’s there.
    Tundra-Canuck[OP] likes this.
  7. Mar 28, 2020 at 3:55 PM
    Tundra-Canuck
    Les
    2014 Crewmax
  8. Mar 28, 2020 at 4:03 PM
    No Limit
    No Limit New Member
    Alberta
    I have the same one...
    FD068240-5EA7-4100-9156-0E84CAD12362.jpg AAB4F985-B47D-44B3-B6C8-97B9F5240BF2.jpg
  9. Mar 28, 2020 at 4:04 PM
    P-Factor
    P-Factor New Member
  10. Mar 28, 2020 at 4:07 PM
    ezdog
    ezdog New Member
    Gateway To The West
    I would think if a one peice radio that giant honkin' console seems an obvious place whether inside or outside on the passenger side.
    It is not like there is a space shortage inside these trucks really.
    I haven't had time to install anything in mine just yet but it will for sure be a detached head radio when I do so I will only need to find a spot for the tiny control head,there are plenty of choices for the body to go.
  11. Mar 28, 2020 at 4:11 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I mounted my Icom under the driver's seat
  12. Mar 30, 2020 at 11:18 AM
    lonelydriver
    lonelydriver New Member
    i have a ham radio wired in my land cruiser, my friend was running a baofeng hand held with a magnet mount and had just as good range. think i'll be going with that.
