Ugh... the lights caused lights
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sctundra14, Oct 27, 2019.
  1. Oct 27, 2019 at 9:05 AM
    Sctundra14
    Sctundra14 [OP] New Member
    Rich
    2014 tundra
    Rocky Ridge Altitude edition
    So I have a 14 tundra sr5 crewmax, put some LED bulbs in the vanity mirror and the dome. Like a knucklehead I touched the pliers to the socket when pulling the dome bulbs, which blew the 7.5 fuse for the dome. After replacing it, my SRS, seatbelt, and slip light are all on. Key fob won’t unlock the truck, nor can I lock all doors with the key. Disconnected the battery, replaced the fuse again and put all the old bulbs back. Reconnected the battery and same thing. Any suggestions? I have a decent code reader and multimeter coming tomorrow. Any help would be awesome!
  2. Oct 27, 2019 at 10:31 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Hello. Welcome to the forum. You're new so I'll play nice. You posted.in the wrong section.
    This is the first gen section for 2000-2006.
    Your truck is a 3rd gen. :monocle:
  3. Oct 27, 2019 at 11:45 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    T-Rex266 likes this.
  4. Oct 27, 2019 at 12:01 PM
    Have you checked all other fuses?
    NewImprovedRon likes this.
  5. Oct 27, 2019 at 5:17 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    I second this question.
    I have read on other threads like these that there is a fuse under the hood AND inside the cab that will blow when swapping lights like this goes awry.
  6. Oct 29, 2019 at 4:21 PM
    Sctundra14
    Rich
    2014 tundra
    I went through the cabin fuses and they all check out. Power door locks the dome fuses are all good. I’m starting to think its the dome relay. I got a blue driver code reader but with the truck on its not working, not sure if its defective. Engine light is off the power outlets radio work so I’m lost. Not even the Chiltons manual has anything.
  7. Oct 29, 2019 at 4:46 PM
    biebs96
    PA
    These posts make me think I like the factory light bulbs over the led upgrades I want.
    Making me nervous
    Randy Morton and BravoDeltaRomeo like this.
  8. Oct 29, 2019 at 5:03 PM
    Did you check the fuses in the engine compartment?
  9. Oct 29, 2019 at 5:05 PM
    Sctundra14
    Rich
    2014 tundra
    Yeah changed one blown 7.5 for the dome
  10. Oct 29, 2019 at 7:19 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Did you try another 7.5A fuse? Just t be sure you don't have a bad replacement fuse? It has happened before.
  11. Oct 29, 2019 at 7:33 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Just me careful and if unsure pull fuse or negative on battery before replacing. LEDs in cab and cargo lights are worth it.
    AZBoatHauler and biebs96[QUOTED] like this.
  12. Nov 10, 2019 at 10:41 AM
    biebs96
    PA
    Ok yes they are!
    I did the swap last weekend.
    BravoDeltaRomeo likes this.
  13. Nov 10, 2019 at 10:45 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    may be that the BCM got messsed up or possibly fried....
  14. Nov 10, 2019 at 10:53 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    When I do mine, I plan on removing the battery power before replacing
    Did the OP ever figure his out? I was looking at these for my some lights, still have to find vanity bulbs up here in Canada
  15. Nov 10, 2019 at 10:54 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    No need to remove the battery or even disconnect it really. Just don't take anything metal to two electric contact points.
  16. Nov 10, 2019 at 11:23 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    same here!
    biebs96[QUOTED] likes this.
  17. Nov 10, 2019 at 12:27 PM
    biebs96
    PA
    I did the upgrade. And it matches my running board and bed LEDs... couldn’t be happier to have them all match.
  18. Nov 10, 2019 at 1:10 PM
    We've seen way too many problems posted here that always involved blown fuses or worse when the battery wasn't disconnected when performing electrical related work on our Tunny's.........always disconnect the battery....
    deepblu89 and BravoDeltaRomeo like this.
  19. Nov 11, 2019 at 5:51 AM
    Overwatch
    Overwatch New Member
    Tampa, FL
  20. Nov 12, 2019 at 9:53 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Lights ordered from Amazon, will install this weekend in the cabin dome area only as they didn't have the vanity light size. I went with the Sirius 10 pk. They may fit the rear plate and bed box, haven't checked yet.
    I'll be disconnecting my battery, can only help and not hurt. I see no reason why I wouldn't take the extra 30 seconds to ensure no power is running to anything while I'm working with electricity.
  21. Nov 12, 2019 at 10:42 AM
    coTony
    Tony
    Montrose, CO
    It should go without saying, to be safe always disconnect the battery
  22. Nov 17, 2019 at 9:52 PM
    ramb74
    ramb74 New Member
    Ricardo
    2018 Toyota Tundra SR5 Crewcab TRD sport
    Correct
  23. Nov 17, 2019 at 10:11 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Then don’t say it :rofl:
