UGG New Rims Hub Bore too Small
Discussion in '1st Gen Tundras (2000-2006)' started by JAXABOI, Apr 11, 2021.
  1. Apr 11, 2021 at 3:10 PM
    JAXABOI
    JAXABOI [OP] New Member
    2005 Sr5 Tundra
    Hey all, just bought a set of 18in rims from a guy who took them off his 2021 f150 thinking they would fit but the hub bore is about 3/8 to 1/2 an inch too small. I am trying to sell them without much luck so I was wondering if spacers would be a good option. They just go on the studs so I am thinking I would have to go with like a 1.25 in spacer. Would that be a safe valid option? I trailer my boats occasionaly and it is a work truck but the hardest thing it ever does is trailering those boats (24ft theyre not heavy). What do you think?
  2. Apr 12, 2021 at 7:40 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    If you can find a wheel adapter with Toyota bore on the inside and Ford bore on the outside you should be okay. Most spacers you'll find have the same inside/outside hub size.
  3. Apr 12, 2021 at 8:16 AM
    JAXABOI
    2005 Sr5 Tundra
    Yea ive been looking for some without any luck. Another option I came up was to remove the hub cap there so its the exposed bolt. It shouldnt cause a problem because they are sealed bearings. The only dust cap then would be the ones on the rims.
  4. Apr 12, 2021 at 6:20 PM
    KarmaKannon likes this.
