uca suggestions., pricing and other info
Discussion in 'Suspension' started by 16cmt, Aug 30, 2018.
  1. Aug 30, 2018 at 11:54 PM
    16cmt
    16cmt [OP] New Member
    Portland Oregon
    2016 Sr5 Crewmax
    yooo! i ran 3/1 level and 305/70/19 with -12 offset wheels for 2 years now. finally got the icon 2.5” w/resi and 2.0 rear non resi. considering camburg uca’s. do we have vendors for camburg on here? tia
  2. Aug 31, 2018 at 1:49 AM
    TexasTundra27
    TexasTundra27 Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
    Go Total Chaos, the camburgs are known to have alignment issues
  3. Aug 31, 2018 at 3:35 AM
    SPC's are fully adjustable. Made in CO and can be had for around $550. Next step up....Total Chaos would he my choice. ToyTec sells both and there should be a discount of some sort.
    thetwood, 4x4_Angel and GNTundra like this.
  4. Aug 31, 2018 at 7:13 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    With the high offset on your wheels I think you'll be better off with Total Chaos. You're more likely to have rubbing problems if you go with Camburg.
    joonbug likes this.
  5. Aug 31, 2018 at 7:25 AM
    01erionracing
    01erionracing KJ6RKU
    Jimmy
    2000 SR5 4WD 2002 SR5 4wd 2008 CM Limited 4wd
    I am currently running the Camburg UCA on Gen1 and Camburg WILL NOT sell a replacement arm if you need to replace.
    joonbug likes this.
  6. Aug 31, 2018 at 8:01 AM
    TOTAL CHAOS
    TOTAL CHAOS WWW.CHAOSFAB.COM Vendor
    Corona, CA
    If you're open to other options, we'd love to get you setup with TOTAL CHAOS Upper Control Arms!
    We do have a thread for UCA's here
    TOTAL CHAOS - Toyota Tundra UCA
    I noticed you're in Portland, Oregon. Conditions can be harsh in the PNW, especially when you're in an area that salts the roads. TOTAL CHAOS uses 100% Stainless Steel Uniballs for maximum corrosion resistance. This offers much more durability and a longer life expectancy over the other options like chrome plating. This is just one of the benefits of TC UCA's :)
    We are closed for Labor Day Weekend, but feel free to reach out. We are happy to answer any questions once we are back in the shop :thumbsup:
    info@chaosfab.com
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  7. Aug 31, 2018 at 8:11 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
  8. Aug 31, 2018 at 9:02 AM
    15'TeRD
    15'TeRD New Member
    Tony
    San Diego
    15 TRD Double Cab
    Nothing special
    Dirt King
  9. Aug 31, 2018 at 9:22 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Really? They are known to add a lot of caster due to the design, but I wouldnt consider that an "issue" perse. Lot of members have swapped over to Burg from Icon (from what I recall reading) because the Icons were garbage for alignment numbers.
    831Tun likes this.
  10. Sep 1, 2018 at 10:05 AM
    TexasTundra27
    Mark
    When I was looking for new UCAs a few years ago there were a lot of threads about people that were unable to get a good alignment with the burgs, I’ve yet to see a single negative thing about the TC arms. Thru my own stupidity I messed up my original bushings by greasing them wrong, and while I was at the Lonestar Toyota Jamboree @TOTAL CHAOS replaced them for less than I can buy them for. Those 2 things is why I’m sold on TC products, top notch product and customer service to back it up.
  11. Sep 1, 2018 at 10:34 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I can attest to the fact that Icon arms are WRONG. Myself and a friend found that we could not get proper camber and the caster is super minimal at roughly 2*. The Camburg has a little too much caster for my taste but that's just personal preference. (I'd be rubbing the fender, CMC done) The numbers I see with TC arms and their reputation speak for themselves. I went with MCM arms which (caster wise) are in between TC and Camburg and I'm in the area of 4.5* of caster.
  12. Sep 1, 2018 at 7:03 PM
    WestexSBK
    WestexSBK New Member
    2019 SuperWhite CM TRD Sport 4x4
    I vote total chaos!
  13. Sep 1, 2018 at 7:16 PM
    Quebec
    Quebec New Member
    My total chaos UCAs squeak more than an orgasming mouse
  14. Sep 2, 2018 at 12:34 AM
    theraven
    theraven New Member
    Central AZ
    16 DC / KI7LWX
    Icon 2.5 cdc front and rear. MCM UCA's, RXT rear leafs , wheelers bump stops, Icon hydrolic Bump stops, Icon six speed 17x8.5 w/35x12.5R17 Nitto Ridge grapplers, A.R.E. CX,, Smittybilt Gen2 12k synthetic on SSBuilt Front bumper, factor 55 fair lead, factor 55 flat link-E, SSBuilt high clearance rear with S2Pro, BD squadron pro fogs and side lights, BD 40" Onx6 behind the grill on SDHQ mount, BD XL80's on SDHQ a pillar/ hood mounts. Switch pros 9100, SDHQ panel mount and SDHQ under hood mount. Pro Grill, SDHQ ABS guards, P&P Sliders, Full RCI skids. Kenwood TM-V71a, Dual GPS antenna, Rago dash mount, WE Boost inreach
    MCM is a solid option.
    Ace402 and 831Tun like this.
  15. Sep 2, 2018 at 6:03 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    have you talked to them about this? I'm sure they would try to do their best to help figure out why
  16. Sep 2, 2018 at 6:57 AM
    TOTAL CHAOS
    Corona, CA
    @Quebec - please email info@chaosfab.com or send us a PM. It could be a few different things causing the squeak. Happy to help :)
    Note: We are closed until Tuesday for Labor Day Weekend
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
