UCA questions
Discussion in 'Suspension' started by BTBAKER, Jan 6, 2018.
  1. Jan 6, 2018 at 3:25 PM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I need some advice on what I should do. On my 2017 Tundra I put the 6112 set at 1.9 and it drives fine but I really want to put a bigger tire to fill in the wheel well and what I’m looking at will probably lift another 1 inch. At that point would it be nesccsary to replace the UCAs?
    And if I don’t am I stressing out other components?
    Thanks for any feedback.
    Toytec Lifts likes this.
  2. Jan 6, 2018 at 3:42 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Use the search function for more answers, been discussed before. Less than a 3” lift no need for UCA’s unless you can’t get your alignment right for some reason or your offset and tire size rubs the UCA.
    dcsleeper408 and trayday like this.
  3. Jan 6, 2018 at 4:00 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    You'll be fine. Depends on size tire and offset of rims for rubbing. I'm running 3" lift, stock ucas, drives great,no alignment problems. 306 70 18 stt pros
  4. Jan 6, 2018 at 4:03 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Your height shouldn't be an issue as far as UCAs go. A wide tire might cause an issue with clearance between the uca and tire but that's a wheel offset issue.
    BTBAKER[OP] likes this.
  5. Jan 6, 2018 at 4:03 PM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    Thanks. I did search but seem to get mixed opinions. I was wondering more if it puts added stress on any other components up front?
  6. Jan 6, 2018 at 4:05 PM
    Berdine
    Binghamton, NY
    You'll want a diff drop to keep cv angles better.
  7. Jan 6, 2018 at 4:05 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I would think larger tires do add more strain on components as well as engine, tranny, diff, wheel bearings etc. But, these are tough trucks and I wouldn't think twice about it.
  8. Jan 6, 2018 at 4:06 PM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    Sounds good. Thanks
    831Tun[QUOTED] likes this.
  9. Jan 6, 2018 at 7:43 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    If it were me I’d go ahead and add them. It will not hurt, so if you’re gonna constantly be concerned, or hit potholes, the UCA’s are a must
    BTBAKER[QUOTED][OP] likes this.
  10. Jan 6, 2018 at 7:56 PM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    Yep. I’m thinking the same way and will just do it when I get the wheels/tires.
    I was looking at the SPC light racing since they are more in my budget.
    Thanks for the advice.
  11. Jan 6, 2018 at 7:58 PM
    Eclipsed & Floating
    Voluptuous Whitey
    That’s what I have and they have served me well in heavy off road use
  12. Jan 6, 2018 at 7:59 PM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    How was the install?
  13. Jan 6, 2018 at 8:07 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Easy...I didn’t do it
    I got the wheels, tires, lift, and UCAs done all together and paid an arm and a leg in Denver
    joonbug likes this.
  14. Jan 6, 2018 at 8:14 PM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    Yea, I did my Tacoma and it was a pain in the ass. I’m going to make some calls and see what it would cost me.
  15. Jan 6, 2018 at 8:18 PM
    Eclipsed & Floating
    Voluptuous Whitey
    RSG OFFROAD on Colfax does primo work, but they sound like dicks when you call. Not the cheapest but are extremely reliable and do have been really good to me
    They do extremely solid work too
  16. Jan 6, 2018 at 8:21 PM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    Thanks. I’ll check into them. I use 4WP from time to time but they aren’t real close and the the 4 wheel shop here in Castle Rock is a joke with prices.
    It’s not a highly technical job so most shops should be able to handle it.
  17. Jan 6, 2018 at 8:26 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Call RSG and get an estimate. They are just east of Colorado Mills
  18. Jan 10, 2018 at 9:45 AM
    Biff_Elwood
    Biff_Elwood New Member
    Denver
    2014 Platinum
    Im working on it!
    I called them after all the recommendations and they were very helpful and nice on the phone. I will be having them do my install once I get everything bought.
    They also mentioned they stock UCAs just in case you need them as every truck is different apparently.
  19. Jan 10, 2018 at 10:17 AM
    Eclipsed & Floating
    Voluptuous Whitey
    I highly recommend UCAs for numerous reasons but no, not all lifts require them
  20. Jan 10, 2018 at 10:20 AM
    Biff_Elwood
    Denver
    2014 Platinum
    Im working on it!
    What is the best UCA under $500?
  21. Jan 10, 2018 at 10:26 AM
    Eclipsed & Floating
    Voluptuous Whitey
    SPC are fine in my opinion, and they are relatively innexpensive. What kind of lift are you getting?
    Biff_Elwood[QUOTED] likes this.
  22. Jan 10, 2018 at 10:34 AM
    Biff_Elwood
    Denver
    2014 Platinum
    Im working on it!
    6112/5160 top setting, 20x9 wheeel with +20 offset. It seems like most UCAs mentioned here are more than the 6112s, so its nice to know there are some less expensive options.
  23. Jan 10, 2018 at 10:46 AM
    Eclipsed & Floating
    Voluptuous Whitey
    I’m not 100% sure on pricing but there definitely less expensive options if you’re not going to thrash them off road. The guys that go full throttle will spend some money for top shelf gear, but it’s not necessary if you’re not looking to do the tough trails
  24. Jan 10, 2018 at 2:23 PM
    Biff_Elwood
    Denver
    2014 Platinum
    Im working on it!
    Something like this?
  25. Jan 10, 2018 at 2:41 PM
    Eclipsed & Floating
    Voluptuous Whitey
    Huh?
  26. Jan 10, 2018 at 2:43 PM
    Biff_Elwood
    Denver
    2014 Platinum
    Im working on it!
    Well that didn't work.Let me see if I can find the link again.
  27. Jan 10, 2018 at 2:53 PM
    Eclipsed & Floating
    Voluptuous Whitey
  28. Jan 10, 2018 at 2:55 PM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    You should be just fine with the factory uppers honestly, we have seen a lot of people get back into spec just fine with the factory uppers with that amount of lift.
  29. Jan 10, 2018 at 2:58 PM
    Eclipsed & Floating
    Voluptuous Whitey
    David, @Biff_Elwood needs a little nudge too
  30. Jan 10, 2018 at 3:03 PM
    Toytec Lifts
    Denver, CO.
