UCA Options...
Discussion in 'Suspension' started by TRD PRO 17, Feb 15, 2018.
What UCA option would you choose?
  1. JBA OFFROAD
    36 vote(s)
    48.6%
  2. SPC
    29 vote(s)
    39.2%
  3. OEM
    9 vote(s)
    12.2%
  1. Feb 20, 2018 at 4:43 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    My alignment is spot on. Handles well on and off road. Very stable at highway speeds.
    The ball joint is a standard Moog part and can be found almost anywhere. I am almost positive that JBA's joint is built in-house, but it can be replaced with another 6292 ball joint if you're in a pinch. JBA's ball joint is rebuildable and serviceable as well.
    I researched and weighed my options for 3 months before I chose the JBA's.
    Does anyone know (for fact) the actual degree range of motion on the new Icon Delta Joint or the Uniball UCA's for our trucks?
  2. Feb 20, 2018 at 4:50 AM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    the bright red on the JBA's kills me
    mttjdy and dcsleeper408 like this.
  3. Feb 20, 2018 at 7:13 AM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    It's great if your truck is Radiant Red.
    Ryuu, HBdirtbag[QUOTED] and OBXTundra like this.
  4. Feb 20, 2018 at 7:27 AM
    TRD PRO 17
    TRD PRO 17 [OP] New Member
    Tyler
    2015 Inferno Crewmax TRD PRO
    I kinda dig the red. It will pair nicely with my pro suspension.
  5. Feb 20, 2018 at 7:42 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    He will send them as raw steel upon request. Coat them any color you want with any coating you want.
  6. Feb 20, 2018 at 11:07 AM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    that's interesting, i thought about recoating my TC's. First thing i did was remove stickers
  7. Feb 25, 2018 at 4:27 AM
    JohnH
    JohnH From PA
    Pennsylvania
    2017 Tundra SR-5 4x4 TRD MGM
    ADS 3.0 with clickers ADS bypasses Deaver U748 springs Magnum steps (with Line-X applied) Powdercoated bumper ends Powdercoated TRD wheels Pro grill Husky X-Act
    I'm debating buying a new UCA and was wondering about the amount of maintenance you did on your SPCs? Like you, I live in Pa.
  8. Feb 26, 2018 at 7:32 AM
    chphilo
    chphilo Tundra addict
    Western PA
    SPC UCAs are maintenance-free kit. I have not done anything to them. They got washed whenever I washed my truck.
  9. Aug 27, 2018 at 9:52 AM
    Jermalex
    Jermalex New Member
    Central Idaho
    2011 Tundra 5.7L DC LTD
    Billstien 6112/5160 shocks, EBC Rotors and Pads, lots of little tweeks
    I’m looking at the JBAs as well. But I’m concerned about clearance for snow chains. What kind of distance did you get between tire side wall and UCA? What width tires are you running and did you use a wheel spacer?
  10. Aug 27, 2018 at 1:45 PM
    Mr. Rogers
    Mr. Rogers New Member
    Forsyth, Ga.
    2017 MGM Tundra TRD 4x4 SR5
    Toytec/Eibach 3"coilovers, JBA uca's, 1" rear blocks with bilstein 5100's, Nitto RG's 295/70/18
    im running 295/70/18 nitto ridge grapplers. the inner sidewall is very close to the UCA, but doesnt touch. i had a set of spidertrax 1.25" spacers, but removed them because the tires would slightly rub the inner fender liner. if you use some wheel spacers, i think you would be fine with snow chains.
  11. Jul 21, 2019 at 9:46 PM
    Ob1
    Ob1 New Member
    I've got bilstein 5100's at top settings and JBA UCA's running 20's with +50 offset. Wanted to upgrade to a bigger tire but unsure of fitment. 20190721_101657.jpg 20190721_101617.jpg
    Texas Bandit and Ryuu like this.
  12. Jul 21, 2019 at 11:07 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Me too...:popcorn:
    TheBeast[QUOTED] likes this.
  13. Jul 22, 2019 at 6:23 AM
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    SPC UCA’s here. Grease every oil change, no issues so far and great alignment numbers.
    Texas Bandit and Paul B like this.
