Uca differences
Discussion in 'Suspension' started by Rubberdown, Sep 2, 2019.
  1. Sep 2, 2019 at 8:41 PM
    Rubberdown
    Rubberdown [OP] Spilling my guts here.
    having trouble differentiating Total Chaos vs Camburg vs MCM upper control arms.
    I don’t want opinions on what you think is better. Just need factual data on the difference in where it puts the spindle in relation to the stock arms.
    Also curious about the quality of each of the uniballs. Anyone know the oem part number of the spherical bearing for each so I can look them up?
    Thanks
    831Tun likes this.
  2. Sep 2, 2019 at 9:43 PM
    theraven
    theraven New Member
    Central AZ
    16 DC / KI7LWX
    Icon 2.5 cdc front and rear. MCM UCA's, RXT rear leafs , wheelers bump stops, Icon hydrolic Bump stops, Icon six speed 17x8.5 w/35x12.5R17 Nitto Ridge grapplers, A.R.E. CX,, Smittybilt Gen2 12k synthetic on SSBuilt Front bumper, factor 55 fair lead, factor 55 flat link-E, SSBuilt high clearance rear with S2Pro, BD squadron pro fogs and side lights, BD 40" Onx6 behind the grill on SDHQ mount, BD XL80's on SDHQ a pillar/ hood mounts. Switch pros 9100, SDHQ panel mount and SDHQ under hood mount. Pro Grill, SDHQ ABS guards, P&P Sliders, Full RCI skids. Kenwood TM-V71a, Dual GPS antenna, Rago dash mount, WE Boost inreach
    I recall there being a thread or sticky breaking them all down on here somewhere. I ended up looking at the same 3 when I bought mine. IIRC TC & MCM were very similar in spec as far as what they deliver alignment wise and Camburg had a little higher caster numbers. If I can find the thread I’ll shoot it to you.
    zcarpenter92 and 15whtrd like this.
  3. Sep 3, 2019 at 6:09 AM
    Rubberdown
    Yeah I searched but couldn’t come up with anything. Sure appreciate the help.
  4. Sep 3, 2019 at 6:14 AM
    SilverRider
    SilverRider New Member
    Las Vegas
    2015 Silver Crewmax Limited 4x4 TRD Off Road
  5. Sep 3, 2019 at 6:17 AM
    Rubberdown
    I read that thread but I info on the spherical bearing was spotty on mcm and none of them say what the actual location of balljoint/uniball/whatever is.
  6. Sep 3, 2019 at 6:23 AM
    SilverRider
    Las Vegas
    That's the only thread I remembered
    :notsure:
    zcarpenter92 likes this.
  7. Sep 3, 2019 at 6:44 AM
    Rubberdown
    I was hoping mcm and total chaos would chime in. I know they are active in here.
  8. Sep 3, 2019 at 6:56 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I've run all of the ones mentioned. Study photos of the arms and pay close attention to rear section of the arm. The part that comes out from the truck closest to the cab. You'l see that TC has a slight bend forward. MCM is straight and Camburg is angled slightly back toward the cab. So what this does is increase the caster in the same order I listed 'em. With TC I'm maxing out adjustments to get in the 4* range. MCM was my favorite cause with the cam tabs fairly neutral I had 4* driver and 4.5* pass. With Camburg I was closer to 7*.
    theraven likes this.
  9. Sep 3, 2019 at 8:06 AM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    What are ideal numbers to shoot for using and after market UCA? What are the benefits?
    831Tun[QUOTED] likes this.
  10. Sep 3, 2019 at 8:21 AM
    Rubberdown
    Jesus in heaven Ian.
  11. Sep 3, 2019 at 9:32 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    It's, in part, a matter of personal preference and in part where your wheel sits in the wheel well. With low caster #s turning is easier and less prone to self centering, more for a track car. Higher caster, the wheel wants to return to center and is a little harder to turn (not a big deal cause we have power steering). There are also benefits in the way the shock angle negotiates bumps off road. Too much caster and you're gonna damage your steering rack and rubbing the back of the wheel well. Other things to watch out for are coil hitting tie rod and or sway bar. First thing to do to an off road Tundra is remove the sway bar.
    A lot of the info on this stuff I've gotten from SGU guys, @osidepunker, @papasmurf. They're the guys who've been running the hardest the longest and done more work on their trucks.
    osidepunker and porkitt[QUOTED] like this.
  12. Sep 3, 2019 at 9:44 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Total Chaos uses a FK Rod Ends 1" ID, 2-1/8" OD WSSX16T PTFE Coated Uniball Spherical Bearings F2 Fit
    831Tun likes this.
