UCA’s
Discussion in 'Suspension' started by evans7, Nov 30, 2019.
  1. Nov 30, 2019 at 9:36 AM
    evans7
    evans7 [OP] New Member
    Cypress, Tx
    2016 2WD Tundra TSS
    Bilstein 6112 front struts and 5100 rear shock absorbers
    I’m trying to decide on what aftermarket UCA’s to install on my tundra. Having a hard time deciding on what to go with since there are so many out there. What’s is everyone running?? Any input will help.
    Thanks
  2. Nov 30, 2019 at 9:55 AM
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Leer 100XL, Bedrug, Go Rhino running boards, LED int/ext lighting, Bilstein 6112/5100 1/2”shims up front, Coachbuilder +3 shackles, CB drop, TRD front/rear sway bar, 275/65/20 Michelin LTX M/S 2, sequoia painted mirror cap/door handles, Rago Fab low pro ditch brackets, Baja Designs S2 sports ditch lights. Baja Designs S2 sport rear flush mount pod
    I’m running JBA control arms, I like everything about them and the price was right. Think they might be doing a Black Friday sale? I see you’re in Cypress, I’m right on the edge of where cypress and Houston meet, zip codes anyways. Good luck with finding what you need BB496745-E249-4ECA-BEF2-01EB9D73C48C.jpg
    georgiey22, zachzap361 and rznhales like this.
  3. Dec 1, 2019 at 5:40 AM
    evans7
    Cypress, Tx
    2016 2WD Tundra TSS
    Thanks for the info. How are you running your Bilstiens?? I see you have coachbuilder shims as well. You you have 2 on the driver side and one on the passenger side? I have mine set at the highest setting and was thinking about adding some to give a 1/2in more lift and to correct the driver side lean.
  4. Dec 1, 2019 at 6:02 AM
    zachzap361
    zachzap361 MEAN GREEN MACHINE
    Zach
    San Antonio
    2010 Green Tundra CrewMax
    Toytec Aluma 2.5 Coilovers and Toytec rear shocks, Method NV 17", Nitto Ridge Grappler 35", RCI Skid Plate, Dirtydeeds Dual Dumped Exhaust, Volant Cold Air Intake and Throttle Body Spacer, SDHQ Ditch Mount Brackets, Rigid Blackout Spot Lights, Stampede Fender Flares, N-Fab Nerf Bars, Morimoto Fog Lights, 55 watt HID's, AJT Design Climate Knobs, Ellis Precision Shift Knob, Coverking Seat Covers, Husky Floor Liner's,Demello Off-road Bumper, Rigid and Baja Designs Lights, Jomax ABS Sensor covers
    That looks really nice @MAGDADDY !!! Do the houston meets go on frequently? That is the one thing I'm looking forward too when I get back in January.
  5. Dec 1, 2019 at 6:59 AM
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    I run them at 2.5” and have 2 shims on drivers side and one on pass. The truck sits just a little nose high, but I like it and it’s pretty damn close. B2C5A898-8EAD-4F32-8805-C1C8A9C12AD3.jpg
  6. Dec 1, 2019 at 7:02 AM
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    You know I seen a few but haven’t had the chance to go. If you get on fb check out the TTC Texas toyota coalition, the also have a page on this forum as well. Obviously they are state wide and some meets aren’t close but there’s been a handful in Houston since the beginning of the year.
    zachzap361[QUOTED] likes this.
  7. Dec 1, 2019 at 8:00 AM
    19TundraPlatinum
    19TundraPlatinum New Member
    Maryland
    2019 Tundra Platinum Magnetic Gray Metallic
    5% Window tint Ceramic coating Weather tech mats Color matched mirror caps and door handles Oem black exhaust tip Blacked out 4x4 badge and added black tundra tailgate insert
  8. Dec 1, 2019 at 8:18 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    What's your lift?
    Camburg builds a lot of caster into their arms, downfall is they don't work well with smaller lifts due to that.
  9. Dec 1, 2019 at 8:29 AM
    gears_call
    gears_call New Member
    Orange County, CA
    2014 SR5
    King 2.5's l Method double standards l 35" BFG KO2 l SS Built front bumper/skid/valence l more to come....
    Camburg, total chaos, Icon. All solid choices
  10. Dec 1, 2019 at 8:33 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Just noticed the OP is 2wd.
    If it not too late, get lift spindles!
    Lift and you won't need UCAs of even new coilovers for that matter.
  11. Dec 1, 2019 at 8:39 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    X2 ^^^
  12. Dec 1, 2019 at 8:44 AM
    Rica25
    Ricardo
    Tulare
  13. Dec 1, 2019 at 8:48 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Some are made with ball joints and some are made with uniballs. The uniballs are stronger but require more maintenance and are known to be noisy.
    You may see more travel out of a uniball arm vs. a ball joint arm but if you're 2wd and not doing heavy off-roading than a BJ will be fine.
    The brands that have already been mentioned (JBA, SPC, Total Chaos, Icon, Camburg, etc..) are all high quality. Pick BJ or Uniball and then pick the color you want. Can't go wrong.
    SK_Tundra and Rica25 like this.
  14. Dec 1, 2019 at 9:51 AM
    Rica25
    Ricardo
    Tulare
    I went with ball joint
