Typical transmission temps?
Discussion in '2.5 Gen Tundras (2014-2021)' started by trails-end, Aug 2, 2021.
  1. Nov 11, 2021 at 2:16 PM
    #151
    BCTRD
    BCTRD New Member
    B.C.
    2021 MGM Tundra TRD Sport
    18"BBS Forged wheels, factory running boards, VLED's, Rigid Pro Led mod (D2 SAE), diff breather mod, Husky mats, DIY Cquartz UK 3.0, Husky liners, OCD organizers,
    Thanks. If I see excessive temps towing the boat we'll be looking into a kit.
    Terndrerrr[QUOTED] likes this.
  2. Nov 12, 2021 at 4:25 AM
    #152
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    This was from two days ago. Towing my 2000lb boat in ambient temp of 59 degrees. About a 25 min trip to the lake. I don’t think this is excessive but when its 80-85 degrees outside I’m sure it will look a lot different.
    Henry1jg likes this.
  3. Nov 12, 2021 at 4:47 AM
    #153
    TundraTed
    TundraTed New Member
    2020 SR5 TRD Sport Crewmax 4x4
    In order: Orvis dog cover for rear bench seat, OE gun safe, Husky liners front/rear, Tyger tonneau tri fold, Rough Country seat covers
    After a ~20 min drive (10 local roads/10 highway)... 75 degrees, no hills, load is me and the dog (240lbs total)
    Henry1jg and k0diak8o8 like this.
  4. Nov 12, 2021 at 8:21 AM
    #154
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Towing boat with added cooler. 205 pan/232 TC
  5. Nov 12, 2021 at 8:47 AM
    #155
    FISHN43
    FISHN43 New Member
    Ohio
    What kind of numbers did you have before adding the cooler?
    Oey12 likes this.
  6. Nov 12, 2021 at 8:56 AM
    #156
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    I was thinking the same thing…seems a little high with a cooler…no?
    Cpl_Punishment likes this.
  7. Nov 12, 2021 at 9:08 AM
    #157
    timsp8
    NY
    Depends on the weight of the boat. He’s in 6th gear at 76 mph and it’s only 205. I’d say that isn’t too bad.
    Engine coolant is 205 also.
  8. Nov 12, 2021 at 9:16 AM
    #158
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    I thought so too. Boat and trailer are around 4500lbs. Before the cooler it would run 225-230 in the pan and 240-248 at the TC.
    Texas highways are 75mph and I will go the speed limit when possible. Trailer tires are speed rated for it. I'm comfortable with the temps before the cooler and still comfortable with the temps.
    Just want to make sure peeps don't think the cooler will magically make the temps under 200 towing in D at speed limits.
  9. Nov 12, 2021 at 9:22 AM
    #159
    FISHN43
    FISHN43 New Member
    Ohio
    I just ordered the Setrab kit. If nothing else, for piece of mind. Towing my 2000lb boat to the lake 25 min away will probably not kill my trans. But if I get a bigger boat (someday) or a TT or tow longer distances then it will be ready and I’ll have no worries.
  10. Nov 12, 2021 at 9:23 AM
    #160
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Well your comment would be slightly relevant if you said 205 and 230. But you choose the pan temp after cooler and the TC before the cooler. I think you've provided enough disinformation on the cooler threads.
    hagrid likes this.
  11. Nov 12, 2021 at 10:28 AM
    #161
    Fitzf15E
    Fitzf15E New Member
    2021 Limited DC TRD OR Cement
    In the hills just north of Boise, 60 degree day, 240 at the T/C, pan temp peaked at 220 a few seconds later. Not towing anything, just me in the truck and a new spray-in bedliner in the back. Running the mountain roads a little later at 65mph oftentimes had the T/C in the mid 230s. Not even going to risk running it in Hell's Canyon next summer heading up to hunting camp without a cooler. One of Nick's "ugly" weld kits should be arriving today.
    Jtundra81 likes this.
  12. Nov 12, 2021 at 10:40 AM
    #162
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    What's the 232?
  13. Nov 12, 2021 at 11:54 AM
    #163
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Probably TCC
  14. Nov 12, 2021 at 12:11 PM
    #164
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    torque converter :thumbsup:
    Does rise when unlocked but drops quickly once locked. No S4, just drive and go.
  15. Nov 12, 2021 at 12:29 PM
    #165
    timsp8
    NY
    I assumed the TC, which fluctuates a lot more than the pan temp and drops faster too when not under load, and from what I’ve read will be higher in 6th while towing but I don’t fully understand the TC lock vs unlock.
  16. Nov 12, 2021 at 1:09 PM
    #166
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Soon as it locks it drops. From a different trip...
    k0diak8o8 and timsp8[QUOTED] like this.
  17. Nov 12, 2021 at 1:15 PM
    #167
    14burrito
    2014 SR5 CM 4x4 5.7
    Because the clutch is no longer slipping (which is what generates heat). Crank and input are at a 1:1.
  18. Jan 15, 2022 at 6:18 PM
    #168
    Captain papa
    Captain papa New Member
    Vehicle:2021 Tundra crew max. Running around town with ambient 50-70 degrees and transmission in D, driving 0-45 mph roads, transmission pan temperature is 200-204 degrees range. At 70 mph 204-206 degrees range.
    Towing: 8 foot wide, 11.5 foot high, and 8500 lb. travel trailer.
    Ambient 50-60 degrees. Cruise rolling hills on interstate at 65 mph with transmission in S4 per manual, the transmission pan temperature is between 204 to 209 degrees. Now if you put the transmission in D the pan temperature increases to 221 to 224 degrees. The engine will go to 5th and 6th on level ground but drops to 4th on hills. However trying to run in D with this heavy load has zero advantages as the gas mileage is not any better, the transmission is constantly shifting, and the transmission temp is significantly higher. Conclusion is run a heavy load in S4 per the manual for best performance.
    Henry1jg, JDR76, BCTRD and 7 others like this.
  19. Jan 15, 2022 at 7:39 PM
    #169
    2WD
    2WD New Member
    21 Army Green CM SR5 TRD Off Road
    Good data thanks for posting! How many miles were you pulling this trailer? That is gotta be getting to (reasonable) max weight travel trailer territory for half tons.
  20. Jan 16, 2022 at 5:59 AM
    #170
    blanchard7684
    blanchard7684 New Member
    At first glance yes it does.
    But assuming he has an unpinned thermostat, the temps won't go much higher than that by more than 5 degrees.
  21. Jan 16, 2022 at 7:11 AM
    #171
    Captain papa
    I have towed my trailer about 3000 miles total. It tows much more stable then my previous F150 with the aluminum body. That 4.30 rear end gives it a lot of guts for towing. Get about 8.2 mpg.
  22. Jan 16, 2022 at 7:18 AM
    #172
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    manaul only says to tow in S4 when going downhill. Reason being keep rpm up for alternator to ensure enough power for trailer brakes. If you towed at 65 mph on I-10 you would be ticketed for inhibiting traffic. Most go 80-85 mph.
  23. Jan 16, 2022 at 7:21 AM
    #173
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Go ahead and do that if you want. Just don't come here and complain about your fuel economy or transmission temperature afterwards.
  24. Jan 16, 2022 at 7:51 AM
    #174
    Oey12
    Oey12 New Member
    Joey
    New York
    In all honesty the manual and Toyota (when I reached out to corporate) are very vague AT best in regards to S4…
  25. Jan 16, 2022 at 7:56 AM
    #175
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Trailer tires for the most part are rated at 65 mph, people that tow at 80 are only asking for trouble.
  26. Jan 16, 2022 at 8:36 AM
    #176
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    I think Toyota even mentions not towing over 60 or 65 in the manual
    Cpl_Punishment and Oey12 like this.
  27. Jan 16, 2022 at 10:37 AM
    #177
    Captain papa
    Per above, a lot of trailer tires are rated 65 mpg max. Anybody, regardless of tow vehicle are irresponsible towing a 8000 lb. trailer at 85 mph. Stopping and emergency maneuvers are the issue. Regarding the I-10 comment about getting ticketed for embedding traffic at 65mph; I am assuming that Mad Max is being dramatic for emphasis. I have traveled I10 many times towing at 65mph including yesterday morning returning from Carrabelle beach and never been pulled over. Must have passed three state patrol. Every tow vehicle I have ever had recommended locking out overdrive for towing heavy loads. And per my earlier description what is the point in running in overdrive if you get no improvement in gas mileage and only heat up the transmission.
  28. Jan 16, 2022 at 2:24 PM
    #178
    BCTRD
    BCTRD New Member
    B.C.
    What app you running? I'd need a large tablet to have that many gauges and still retain a decent size for viewing.
    Running OBD link and torque.
    Being able share gauge setup would be a bonus as it can be time consuming to setup these screens.
  29. Jan 16, 2022 at 2:41 PM
    #179
    Retired...finally
    They are. In my experience towing ~6,000 lbs in Drive w/tow-haul is a dumpster fire. Right under the transmission pan.
    hagrid, JDR76 and Oey12[QUOTED] like this.
  30. Jan 16, 2022 at 2:58 PM
    #180
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2025 RAM 3500 6.7L Cummins
    This. Towing my TT in D is annoying. It shifts to S6 and feels like a slug. S5 is the sweet spot for me in mostly level terrain.
    JDR76 likes this.
