Two 10" Kicker Comp R in Custom enclosure
Discussion in 'Audio & Video' started by typerlegend, Apr 21, 2021.
  1. Apr 21, 2021 at 7:29 PM
    typerlegend
    typerlegend [OP] Will work for Mods
    Will
    SoCal, North Orange County
    2020 Super White Tundra SR5 TRD Sport
    Kicker sound system. Kings 2.5 Adjustables Total Chaos UCA Total Chaos 3/4' Rear Shackles 17' Methods 703s KO2 35/12.5/17 Baja Design Amber Squadron Sport Fogs
    If anyone wondered if 2 sealed 10" Kicker Comp R would bump in a Tundra, I'm here to tell you they do. Kicker is usually overlooked by many. One thing is, you need a custom box built. Mine was built and tested by Al and Eds in Huntington Beach, CA.
  2. Apr 21, 2021 at 8:09 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I don’t know why anyone would overlook Kicker...
    Rica25 and typerlegend[OP] like this.
  3. Apr 22, 2021 at 6:22 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Nice did you buy there sub box thru a web site? Also I did not get my tundra pro yet waiting on it. Where did you put the floor Jack that is on the passenger side behind the seat. Just curious to see what guys are doing with adding a double sub. Thanks.
  4. Apr 22, 2021 at 2:21 PM
    typerlegend
    Will
    The floor jack is still there, just had to move the tools. I had it built by Al and Eds Autosound out here in CA. They had to use fiberglass to fit the subs because of the mounting depth
  5. Apr 22, 2021 at 2:57 PM
    RusPro21
    Don
    Pa.
    Thanks for the info!!
  6. Apr 22, 2021 at 3:31 PM
    dhbrown
    dhbrown New Member
    2019 TRD Pro, black
    Did you wire this directly to the stock head unit? Specifically the amp? Or did you have to upgrade the head unit?
  7. Apr 23, 2021 at 11:30 AM
    typerlegend
    Will
  8. Apr 24, 2021 at 11:44 AM
    dhbrown
    dhbrown New Member
    2019 TRD Pro, black
    Gotcha. So there's an output from head unit specificially for the sub amp? Or are you just relying on the high pass filter for the sub and low pass for the doors?
  9. Apr 29, 2021 at 11:46 AM
    typerlegend
    Will
    The stock system had an amp under the passenger seat which made it easy. Only had to buy an adapter and tapped one the front speaker output to the amp. The amp high-level inputs adjust everything else.
