Turn Signals not Working
Discussion in '2nd Gen Tundras (2007-2013)' started by 650h1, Mar 30, 2014.
  1. Mar 30, 2014 at 12:16 PM
    650h1
    650h1 [OP] New Member
    2013 Rock Warrior C/M
    So... I turned my signals on this morning, and noticed it was hyper flashing. Turned other signal on to check, also hyper flashing. Checked all fuses in the interior and under the hood, they are good, not blown. Weird thing is that my DRL's still work, they just won't flash when I hit the blinkers. Any thoughts?
  2. Mar 30, 2014 at 5:25 PM
    Beer'd_n_yotas
    Beer'd_n_yotas New Member
    2013 Super White Tundra
    Plasti-dipped and lowered!
    Sounds like your flasher might need to be replaced.
  3. Mar 30, 2014 at 5:36 PM
    ThemAster
    ThemAster New Member
    Morpheus
    What he ^^^ said and you probably may have a blown bulb. In the mean time, stick your hand out like the good old days. :wave:
    NewImprovedRon, YeeYeeTundra and Bob like this.
  4. Mar 30, 2014 at 7:22 PM
    650h1
    Hahaha where is the flasher? I couldn't find the fucker all day....
    GNTundra likes this.
  5. Mar 30, 2014 at 7:25 PM
    Beer'd_n_yotas
    I have no clue!
  6. Mar 30, 2014 at 9:08 PM
    650h1
    Hmm.. It's still under warranty, I just don't wanna deal with the ship if I don't have to..
  7. Mar 30, 2014 at 9:15 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Def a bulb out. Could be rear.
  8. Mar 31, 2014 at 8:34 AM
    650h1
    Both rear signals work... They flash fast right now. Neither front signals work is the issue.
  9. Mar 31, 2014 at 10:27 AM
    csuviper
    Broomfield, CO
    look at the front bulbs. Is the filament burned out or gaped for the signals?
  10. Mar 31, 2014 at 4:24 PM
    ThemAster
    Morpheus
    Its not unusual for both bulbs to burn out at the same time. Perhaps a bad batch. Check them out. Also check the connectors to the lights. You flasher could be near/under the steering column or the fuse box. Check the owners manual.
  11. Mar 31, 2014 at 7:49 PM
    650h1
    Bulbs were burned out. They are double filament and I saw that one filament was good, which happened to be the drl use, but blinkers were blown. So I'm good now lol.
  12. Apr 27, 2019 at 6:57 PM
    Bratch
    Bratch New Member
    Jimmy
    OK, so I had the same problem today: both front blinkers went out: rears work: hyper flashing on dash.
    Did both of your front bulbs go out at the same time?
    hard to believe.
  13. Apr 29, 2019 at 11:44 AM
    NWExplorer
    NWExplorer this guy
    Washington
    2010 CM Platinum 4x4
    Really raising the dead here. :) It's not uncommon. Always better to replace them in pairs anyway.
    TXRailRoadBandit73 likes this.
  14. Apr 29, 2019 at 11:47 AM
    Maybe out of Blinker Fluid???:notsure:
    georgiey22, GNTundra and NWExplorer like this.
  15. May 8, 2019 at 1:26 PM
    Bratch
    Bratch New Member
    Jimmy
    Yeah, that must be it!
  16. May 8, 2019 at 1:27 PM
    Bratch
    Bratch New Member
    Jimmy
    Actually: it was both bulbs: burnt out at same time.
    Still find that hard to believe; but new bulbs took care of it.
    Thanks everyone.
    NewImprovedRon and NWExplorer like this.
