Turd tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by Freonjohn, May 29, 2021.
  1. May 29, 2021 at 7:43 PM
    Freonjohn
    Freonjohn [OP] New Member
    2019 dc 6500 miles
    Switched to 4hi today to exercise 4wd. Constantly flashing and could not get solid light. If I leave in 4hi and turn ignition off and back on it will stay lit.
    Just a little pissed that I’m gonna have to schedule and sit at dealership
    Between noisy ac compressor and now 4wd issues just disappointed in my tundra.
    Should have kept my 97 Silverado
  2. May 29, 2021 at 7:55 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Were you already driving when you switched to 4-Hi?
    Cpl_Punishment likes this.
  3. May 29, 2021 at 8:04 PM
    Freonjohn
    Tried it in drive, not moving and it didn’t work(which it normally does)
    Drove around for 15 miles and tried switching to 4hi a dozen times,same thing
  4. May 29, 2021 at 8:11 PM
    TILLY
    Massachusetts
    Still a little confused, did you drive it for 15 miles, and then try it a dozen times while you were still stopped?
  5. May 29, 2021 at 8:17 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Sell it and buy a 97 Silverado.
    Problem solved.
  6. May 29, 2021 at 8:19 PM
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    Sorry for your issues but I just had to post this. Hang in there. I had some aggravating issues too. Good luck.
  7. May 29, 2021 at 8:31 PM
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
    Let off the throttle for a few when engaging at speed.. and push back on it. Let the ecu and transfer case catch up. I do it all the time in winter back and fourth around 20 - 60 mph. It takes some fineness, learn the truck
  8. May 29, 2021 at 8:41 PM
    TILLY
    Massachusetts
    He still hasn't explained his operation of engaging the 4WD. I do the same as you, sometimes it will be stubborn to go from 4Hi to 2WD if you switch over while still on the gas. I consider it just another Tundra quirk you have to learn to manage.
    BravoDeltaRomeo likes this.
