Turbo issue
Discussion in '3rd Gen Tundras (2022+)' started by Lowcountry4x4, Jan 9, 2022.
  1. Feb 23, 2022 at 6:07 PM
    #1291
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Sounds like treating the symptom and not the actual issue.
  2. Feb 23, 2022 at 6:38 PM
    #1292
    dstrbdmedic167
    dstrbdmedic167 New Member
    James
    While I don't disagree, if I had to choose this or a cab removal to replace the turbos, I'll take this.
  3. Feb 23, 2022 at 6:44 PM
    #1293
    Jaxyaks
    Jaxyaks New Member
    I know what that means, and if you look at the letter of the law, the dealer changing affixing a vin plate is an actual crime under the code section without prior approval from the DMV. The "Manufacturer" is technically the only one that can affix a new vin. I don't care what the dealer does or doesn't do with the vin, and it was clarified that apparently it was the wrong vin plate and a plate was affixed to match all the other vins on the vehicle to include the hidden VIN.
  4. Feb 23, 2022 at 6:52 PM
    #1294
    Jaxyaks
    Jaxyaks New Member
    So now everyone is paying top dollar for 98% of the the engineered performance out of the truck, how will that affect max tow and other things while working the truck. I'm gonna want a discount if thats the solution....lol
    ryanwgregg likes this.
  5. Feb 23, 2022 at 7:05 PM
    #1295
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
    Cab removal isn’t required
  6. Feb 23, 2022 at 7:12 PM
    #1296
    dstrbdmedic167
    James
    Safe bet that the 2% change wouldn't make any difference in power or towing. Again, I'm just speaking hypothetically and what I think of when it comes to a software fix if a mechanical issue is an actual problem.
    True but my point is if a firmware update can fix it I'll take that over a mechanical repair that requires a lot of time, effort, or teardown.
  7. Feb 23, 2022 at 7:13 PM
    #1297
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    theres no reason to remove the cab.
  8. Feb 23, 2022 at 7:39 PM
    #1298
    OnThaLake
    OnThaLake New Member
    Make the software way more lenient on wastegate errors.
    Mattedfred likes this.
  9. Feb 23, 2022 at 8:10 PM
    #1299
    brown_subaru
    brown_subaru New Member
    Eastern WA
    2021 Tundra SR5 TRD
    Maybe there are two separate issues with the turbos. One software and one hardware. Some trucks have the software issue, some the hardware. Maybe some have both. Models can have more than one issue at a time, especially first year redesigns.
    Acedude likes this.
  10. Feb 23, 2022 at 9:46 PM
    #1300
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Uhhhh dude, 98% open for the wastegate is dumping exhaust gas flow through the wastegate into the exhaust around the turbine. Wastegate open = making less or no boost. Now I can’t tell you the difference in turbine speed at 100% open vs 98% open, and I admit it’s not ideal because it’s not operating as designed; but effectively either size opening is more than enough to avoid over speeding the turbine or causing excessive boost.
    Now if the wastegate were unable to open at all or were unable to fully close and seat, you have a major problem. Not opening will result in over speeding the turbine/impeller at high load. Since most modern computer controlled turbos use wastegates on the exhaust side to control boost instead of blow off valves on the charge air side, you can easily damage the engine or turbo or both. In such a situation over boost at full throttle is a very real problem, and could result in detonation/knock bad enough to melt or destroy one or more pistons if the ECU doesn’t go into limp mode. There is also the not so nice problem of boosted intake air hitting a closed throttle if you suddenly let off the gas, this can create extra resistance at the impeller and damage your turbo. A functioning wastegate mitigates these issues by opening and diverting exhaust gas to slow down the turbine/impeller to stop building boost. The engine will have a bypass valve to dump compressed air back into the turbo before compressor the inlet since it is a MAF metered engine. Still having a stuck closed wastegate will not be a good thing.
    Not fully seating will rob you of peak torque because the turbo will either not make full boost or will take longer to hit full boost.
    Acedude, Mattedfred and winchester44 like this.
  11. Feb 24, 2022 at 6:22 AM
    #1301
    Terndrerrr
    Music City
    6UR-FE
    This would be like taking your truck to the dealer because your rear window gets stuck when it’s rolled all the way down. The service manager comes back and says, “We realigned your window on its track to prevent it from being rolled down all the way. There will still be a bit of window sticking up when the track is bottomed out, but it no longer gets stuck, so the issue is fixed!”
    Now imagine that rear window is inside your turbo…o_O
    You’re right—who knows? If it’s not a mechanical issue, I think that would a huge relief for everyone.
  12. Feb 24, 2022 at 6:55 AM
    #1302
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    A Toyota tech had reported the mechanical wastegate bind. He had used Techstream to test the wastegate and it wouldn't move. He then applied 12V directly to the wastegate actuator and got it to move. The ECM uses duty circle to move the wastegate actuator to the desired position. Applying 12V to the actuator from the battery is 100% duty cycle and fully open. It seems that the commanded duty cycle percentage isn't enough to overcome the resistance in the wastegate (bind).
  13. Feb 24, 2022 at 11:11 AM
    #1303
    winchester44
    winchester44 New Member
    2016 1794 4WD
    Good luck hearing from him again. @Jaxyaks continues to accuse that guy’s employer of a criminal act. Many on this thread appear to want focus the conversation on any matter so long as it is unrelated to the turbo issue…
  14. Feb 24, 2022 at 11:20 AM
    #1304
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    There’s a turbo issue ?
    Ruggybuggy, Outbound and Mattedfred like this.
  15. Feb 24, 2022 at 11:32 AM
    #1305
    Jaxyaks
    Jaxyaks New Member
    ...lol....your wrong but thats ok...
    Retired...finally and Ruggybuggy like this.
  16. Feb 24, 2022 at 11:52 AM
    #1306
    winchester44
    2016 1794 4WD
    Here is the quote.
    Mattedfred and raylo like this.
  17. Feb 24, 2022 at 12:01 PM
    #1307
    winchester44
    2016 1794 4WD
    Any idea if the electronic actuator a solenoid or a motor? The teach refers to it as a motor.
    Would you have any concern that if 1 Amp was normal and it would not move, but something between that 3 Amps was enough to overcome the binding.
    Curious if that would be concern for premature wear of the actuator or not. Maybe not and even so, pretty simple part if it could be replaced by itself.
  18. Feb 24, 2022 at 12:18 PM
    #1308
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Since your back maybe you would like to help out on the thread "Ask the Mechanic"? I'm actually suppose to be retired. :anonymous:
  19. Feb 24, 2022 at 12:25 PM
    #1309
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I alll comes down to duty cycle. Basically the switch on and off time to control the operation of an actuator. Duty cycle is used on many actuators to control it's operation by a module. A good example would be a fuel pump.
  20. Feb 24, 2022 at 12:25 PM
    #1310
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield, AMP power boards
    Maybe by applying power directly the higher duty cycle and higher amps enough to force it beyond the binding whereas normally the computer would sense a fault and stop the attempt.
  21. Feb 24, 2022 at 12:32 PM
    #1311
    raylo
    Frederick, MD
    I would hope that is not the solution... pushing more power than the part was designed for is not a formula for durability. They need to fix the physical electro-mechanical issue.
  22. Feb 24, 2022 at 12:50 PM
    #1312
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    What exactly do you mean by more power? The wastegate is variably actuated using duty cycle to keep it in a desired position. If the actuator doesn't achieve the position it is suppose to because of a mechanical bind then a code would be set.
    Texmech and damnfingers like this.
  23. Feb 24, 2022 at 1:58 PM
    #1313
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    SMH. The shit you people argue about.
  24. Feb 24, 2022 at 3:44 PM
    #1314
    winchester44
    2016 1794 4WD
    If I understand his quote correctly, Computer normally commands 1 Amp to the actuator when commanding the duty cycle movement, but that was not enough amps due to some part of the assembly mechanical binding. He hooked the battery directly to the actuator bypassing computer control at 3 Amps and that was enough to overcome the binding. So somewhere between the spec 1 Amps and 3 Amps direct from the battery appears to be enough to force the actuator to overcome the mechanical binding. As others have brought up we are curious what the implications are in terms of commanding more amps being a solution vs. additional wear on the actuator vs. whatever else that might entail.
  25. Feb 24, 2022 at 3:47 PM
    #1315
    winchester44
    2016 1794 4WD
  26. Feb 24, 2022 at 3:51 PM
    #1316
    Terndrerrr
    Music City
    6UR-FE
    Agreed.
    I didn’t see this post originally. So at this point at least, no one is actually entertaining leaving a mechanically faulty part in there with a software fix. Whew!! :rofl:
  27. Feb 24, 2022 at 3:57 PM
    #1317
    damnfingers
    damnfingers New Member
    Gene
    He also said that after hitting the actuator with 3 amps he could still hear the actuator binding and scraping when controlled by the computer. “Essentially I forced the motor to work 100% to move the wastegate, now after clearing the codes it no longer sets the wastegate stuck code right away but I can hear the bank 1 wastegate scraping and squeaking when being controlled by the computer, meaning I esentially freed it up, but obviously it still needs to be replaced before it can be sold.” So that’s obviously not a solution, simply a proof of the problem.
  28. Feb 24, 2022 at 4:46 PM
    #1318
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Thanks for the correction. I didn''t see the amp spec. It will certainly be interesting if they could push more amps through existing circuit that's spec'd to 1amp.
  29. Feb 24, 2022 at 5:26 PM
    #1319
    Tibetan Nomad
    Tibetan Nomad New Member
  30. Feb 24, 2022 at 6:01 PM
    #1320
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I'm not sure why he keeps referring to the driver's side turbo as the issue when the passenger side is being changed. Lots of fluff and then he pirates Dave's video from Automotive Press.
