Turbo issue
Discussion in '3rd Gen Tundras (2022+)' started by Lowcountry4x4, Jan 9, 2022.
  1. Jan 21, 2022 at 8:53 AM
    #331
    Quattroa4m
    Quattroa4m New Member
    Then for a lot of people who depend on their truck, this is an issue they're going to have to decide if it's worth putting up with.
    Wastegates fail, it's not a new "thing". Failure is typically annoying, but a repair is relatively easy and usually not crazy expensive.
    Toyota may have just raised the bar.
    Texmech likes this.
  2. Jan 21, 2022 at 9:07 AM
    #332
    Quattroa4m
    Respectfully, you may be missing the point.
    We have just found out that Toyota may have taken what was a simple repair, to a whole new level of complexity. If your expectation is that once there is a "solution", the wastegate will never again be a problem...you may want to review a few Ford forums.
    We might not have known about this repair complexity until much later, if it hadn't been for the early failures. This is a big deal if the current repair methodology stands.
  3. Jan 21, 2022 at 9:35 AM
    #333
    mass-hole
    mass-hole New Member
    Whats wrong with the Ford wastegates? They had a rattle issue, they were not straight up failing to work. AFAIK the rattle is the actuator arm being loose on the wastegate lever.
  4. Jan 21, 2022 at 9:41 AM
    #334
    Quattroa4m
    And they have been replaced...without removing the cab.
  5. Jan 21, 2022 at 9:45 AM
    #335
    mass-hole
    Correct. Probably through the wheel well. I've pulled and reinstalled my turbos on my 2014. Takes about 3 hours with the wheel removed in my garage with harbor freight tools :rofl:
    I can't believe they can't do that with the Tundra unless they made the frame rails so tight so that it could be used as a Land Cruiser and Tacoma frame too.
  6. Jan 21, 2022 at 9:49 AM
    #336
    Quattroa4m
    It doesn't matter if there was a small batch, a medium sized batch, or a large batch of wastegates manufactured upside down, sideways, or inside out. The issue is the complexity of the required repair.
    A failure, today, tomorrow, or 5 years from now, for any reason, would appear to require a costly repair procedure.
    The point is that we would not have known about the apparent repair complexity if it hadn't been for the early failures.
    Anyone considering purchasing a Gen 3 Tundra now has another data point to consider.
  7. Jan 21, 2022 at 9:55 AM
    #337
    mass-hole
    Agree'd, other than apparently the service manual does say to remove the cab or motor. So if they are going "by the book" then they are.
    I am simply arguing that its probably completely unnecessary, without having actually looked at the truck myself of course.
    JLS in WA likes this.
  8. Jan 21, 2022 at 10:05 AM
    #338
    Quattroa4m
    And yet...you're still here...Slick.
    And an apparently costly repair for the customer...out of warranty...which you've yet to grasp the concept of.
    It's pretty obvious who's "not getting it".
  9. Jan 21, 2022 at 10:06 AM
    #339
    Quattroa4m
    A legend in your own mind, are you?
  10. Jan 21, 2022 at 10:11 AM
    #340
    xc_tc
    xc_tc New Member
    There’s the wastegate actuator as seen from passenger side wheel well. You could probably replace the actuator yourself if you could get the parts. It’s not that hard to replace the turbo either from what I can see. Likely in the next few years we’ll hear about people swapping turbos and get more details about the how-to.
  11. Jan 21, 2022 at 10:26 AM
    #341
    stevesgraytundra
    stevesgraytundra New Member
    Stephen
    2021 MGM SR5 CM 4x4
    A brand new truck in the shop for at least a month is usually a major headache.
  12. Jan 21, 2022 at 10:27 AM
    #342
    SnowRunnerTundra
    SnowRunnerTundra New Member
    2022 Hyundai Santa Cruz Limited
    but probably the actuator needs calibration too via TechStream?
    OnThaLake likes this.
  13. Jan 21, 2022 at 10:30 AM
    #343
    Half track
    Half track New Member
    Rob
    Western Nevada
    2020 Silver Tundra SR5 TRD, 38 gal tank
    Tow Mirrors
    Lets talk how great Ford is about fixing problems on there trucks.
    It took Ford 3 years before they had plans to fix the problems with there 6.0 diesel engines, and had to recall every 6.0 truck from 2003-2006.
    Cab off on my 2006 F250 3 times.
    My 2015 Ford F350 had a good engine but they could not fix the electrical problems, after 8 times in the shop. Problems started to happen at after 24 months.
    Toyota will fix this problem in the next month, and you won't have to wait 3 years for a recall.
  14. Jan 21, 2022 at 11:57 AM
    #344
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Well there’s a good chance the frame is identical in that area to the Land Cruiser/LX 600 and probably the upcoming Tacoma and 4Runner.
    That was a requirement of the TNGA-F platform.
  15. Jan 21, 2022 at 11:59 AM
    #345
    RoddersLV
    RoddersLV New Member
    Rodney
    Las Vegas, NV
    2022 Tundra DOA
    The degree of uninformed speculation posited on this matter is almost comedic. If I made business decisions employing the same degree of ignorance as the genesis for the subsequent decision Tree, I’d be of no concern to any competitors.
    And so as to clarify; I’m one of the “wastegate” victims.
  16. Jan 21, 2022 at 1:36 PM
    #346
    stevesgraytundra
    Stephen
    2021 MGM SR5 CM 4x4
    Fake news! Uninformed speculation never happens in online forums. Never.
    Texmech, TF_CC and Mattedfred like this.
  17. Jan 21, 2022 at 2:47 PM
    #347
    wired
    wired New Member
    David
    2022 Tundra Black SR5
    But the need to find continuing value in your past decisions (even if based on internet suppositions and partial information) is very normal. Congratulations to you!!
    Mattedfred likes this.
  18. Jan 21, 2022 at 3:01 PM
    #348
    xc_tc
    xc_tc New Member
    Could be, we’ll find out at some point.
  19. Jan 21, 2022 at 3:34 PM
    #349
    RavingOx
    RavingOx Member
    WNC
    2022 Tundra Platinum in Black
    Welcome from NC! Glad to see your shift key is working!
    wexttxco and Mattedfred like this.
  20. Jan 21, 2022 at 4:04 PM
    #350
    winchester44
    winchester44 New Member
    2016 1794 4WD
    Cab off maintenance aside, what do ya'll think of thing of dealer telling him his brand new TRUCK is bricked for best case 30 days, but "don't worry here's a Rav4 loaner" ?
    Some of us use these things for work. I just hauled a generator to my job site.
    Do you all think there is more to the story from the dealer?
    Also his points about interest are not wrong. $60K invested at 8% is $400 a month. Dealer got his money, but seems to want to be absolve themselves of as much responsibility as possible.
    Imagine you buy a new home from a builder and HVAC craps out Month 1. You make that warranty call to the builder and he says, afraid air conditioners are on backorder, but don't you worry we will get to you.
    Then walks next door to his jobsite and takes delivery of a brand new HVAC and sticks a For Sale sign in the yard. I know I know, life's not that simple, but man would I be steamed looking at that For Sale sign everyday.
    Mattedfred, wexttxco and RavingOx like this.
  21. Jan 21, 2022 at 4:08 PM
    #351
    winchester44
    2016 1794 4WD
    If I understand correctly you believe the this affects every single new Tundra owner, correct? Has this been determined?
  22. Jan 21, 2022 at 4:10 PM
    #352
    SnowRunnerTundra
    Yeah, it's pretty shitty that dealer gave him a rav4 loaner
    when my Tacoma was in the shop they gave me a Camry.
    I think Toyota should at least match the loaner to the same category of vehicle, if none available, just reimburse the guy and let him rent an F-150 for the duration of the warranty work
  23. Jan 21, 2022 at 4:43 PM
    #353
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
  24. Jan 21, 2022 at 5:50 PM
    #354
    RoddersLV
    Rodney
    Las Vegas, NV
    2022 Tundra DOA
    God bless you
    Texmech likes this.
  25. Jan 21, 2022 at 6:08 PM
    #355
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    Don't know if it's a dealer by dealer thing but when mine was in for warranty work no loaner is offered. I had to fight for one since I am use my truck for work and they eventually had me go to the Enterprise next door and rent a ram on there dime.
  26. Jan 21, 2022 at 8:03 PM
    #356
    Dav123
    Dav123 New Member
    David
  27. Jan 22, 2022 at 3:30 AM
    #357
    vichmr
    vichmr New Member
    Scott
    Suwanee, GA & Highlands, NC
    '25 MGM Platinum TRD OR 6.5 w/ factory lift
    Go Rhino Dominator D6, Diamondback HD
    Agreed! If the reliability drops off, then Toyota becomes an As Run just like the other Big 3. I typically keep my vehicles for 10-15 years; sill own my ‘07 Tundra I bought new. It only has 150k miles and if it was 4WD, I’d seriously consider keeping it until I saw the reliability/longevity of this new design. Heck, I’ve been waiting for a refresh for 10 years, I guess I can wait a few more.
    OnThaLake[QUOTED], wexttxco and raylo like this.
  28. Jan 22, 2022 at 3:37 AM
    #358
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield, AMP power boards
    You sound like me. I am still DD'ing my 2009 Tacoma Sport 4x4 purchased new in Nov 2008. Also like you I have been waiting for a Tundra refresh and a REAL Tacoma refresh for a long time. But mine at 120,000 miles still drives like new, and I have updated the infotainment electronics, added seat heaters, etc. so it is still really nice. I can wait a while for Tundra to sort out... which I don't believe will take very long... and maybe even wait for the next Tacoma. But it will need a much better powertrain than the 3rd gens for me to even consider it.
  29. Jan 22, 2022 at 3:41 AM
    #359
    vichmr
    vichmr New Member
    Scott
    While I agree that I didn’t think about the ‘07 Tundra being a million+ mile vehicle when I purchased it new, I absolutely bought it because of Toyota’s known reliability. It was my 8th Toyota and had reliability diminished in any way, I would have been very disappointed. But, I do agree that it was a game changer at the time, but not sure the new one is just yet. Need to drive one to see. Maybe the hybrid will truly surprise us with power and MPGs, but most of what I’ve read leads me to believe we’ll mainly get the power with a little improvement in MPGs. We’ll soon find out.
  30. Jan 22, 2022 at 3:56 AM
    #360
    vichmr
    vichmr New Member
    Scott
    You seem to relish repeatedly reminding us all of the issues with the turbos, but so far this doesn’t seem to be widespread, so you’re speculating that this problem will happen to everyone. More likely, this is isolated to a specific batch of parts and Toyota will figure it out and get it corrected.
