Turbo issue
Discussion in '3rd Gen Tundras (2022+)' started by Lowcountry4x4, Jan 9, 2022.
  1. Jan 20, 2022 at 10:23 AM
    #301
    Dav123
    Dav123 New Member
    David
    You came across as they know what their doing and they have a manual to go by and its no big deal, and that the youtube guys were idiots for complaining that his brand new truck was being taken apart by someone who probably has no experience with this new truck. Thats the way it sounded anyway. I may have misunderstood.
  2. Jan 20, 2022 at 11:21 AM
    #302
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    The YouTube guys are idiots for making drama about torque specs all all that shit. And yes, they hopefully do have a manual to go by. Do you really think they are going to just get on YouTube and pull stuff out of their ass the first time they do the turbo procedure?
    Yes, the turbo is an issue. I said that first post. No I wouldn’t be thrilled if that was my new truck. Yes, the YouTube pontificators are morons.
    Black Wolf, Mattedfred and raylo like this.
  3. Jan 20, 2022 at 11:26 AM
    #303
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield, AMP power boards
    It's just like TV these days where "reality" shows that dispense boatloads of fake drama seem to be the most popular. A real tech analysis would be seen as "boring".
    JLS in WA[QUOTED] likes this.
  4. Jan 20, 2022 at 11:50 AM
    #304
    Quattroa4m
    Quattroa4m New Member
    It's hard to imagine any scenario whereby removing the cab of your "new" 2022 Tundra for a wastegate issue is "okay".
    Failing this soon without knowing why raises the likelihood of other wastegate failures later on. Then there is the issue of removing the cab and disrupting A/C, brake, cooling, and wiring systems. Letting the local dealer do an oil change is one thing, but this is something quite different.
    Then there's the question of what this repair will cost...out of warranty? That could be the kiss of death for the noted long term relationship many owners and their Tundras have had.
  5. Jan 20, 2022 at 11:52 AM
    #305
    stevesgraytundra
    stevesgraytundra New Member
    Stephen
    2021 MGM SR5 CM 4x4
    I got the 8 year/125,000 platinum warranty with $0 deductible for about half of what he paid for his 7/75 warranty.
    TK1979 and Toyota1234[QUOTED] like this.
  6. Jan 20, 2022 at 11:57 AM
    #306
    xc_tc
    xc_tc New Member
    Is it a failure? We don’t even know yet. It could just be a manufacturing defect.
    Hadelson and JLS in WA like this.
  7. Jan 20, 2022 at 12:02 PM
    #307
    raylo
    Frederick, MD
    Exactly, we still know very little. But I've got to say it feels better to just be a prospective Tundra buyer now rather than an owner. I believe Toyota will figure this out and make it right. But no way I'd want to go through that personally.
    Texmech, TK1979 and stevesgraytundra like this.
  8. Jan 20, 2022 at 12:22 PM
    #308
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    I'm with you, I had a bad experience getting my cam tower resealed. Plus techs dislike warranty work because the manufacturer screws them on it. That then increases the odds a tech would rush through it and make a mistake or not take as much care. Not blaming the techs, that's on the manufacturer. They should not be putting them in that predicament.
    Texmech and OnThaLake like this.
  9. Jan 20, 2022 at 12:26 PM
    #309
    Jaxyaks
    Jaxyaks New Member
    There are two ways you can get to the turbo in a 2022 tundra, remove the engine, or take the cab off. Cab off is probably quicker, those that work on their own trucks when they get older and fail, will more than likely have to go the pull the engine route.
  10. Jan 20, 2022 at 12:42 PM
    #310
    Quattroa4m
    To a customer a manufacturing defect...is a failure.
  11. Jan 20, 2022 at 1:11 PM
    #311
    OnThaLake
    OnThaLake New Member
    Difference being.......?
    stevesgraytundra likes this.
  12. Jan 20, 2022 at 1:33 PM
    #312
    xc_tc
    xc_tc New Member
    If this just a defect caused my mishandling or assembly error, then it’s a “time bomb” like most make it out to be. The wastegate actuator isn’t failing and it won’t cause catastrophic damage.
    BY THE WAY, I took a look at my truck to see where the wastegate actuator is located. It’s just behind the upper control arm rear bushing. Easiest to see it from the passenger side. The wastegate actuator is bolted on to the turbo with 10 mm bolts. So let’s say that the wastegate actuators ARE failing in the field, its really easy to replace without removing the cab.
  13. Jan 20, 2022 at 1:36 PM
    #313
    xc_tc
    xc_tc New Member
    That’s for sure, but I don’t feel any anxiety. Toyota tends to be pretty good about fixing potentially catastrophic issues like this.
  14. Jan 20, 2022 at 1:38 PM
    #314
    JLS in WA
    My nephew pulls cabs off Ford diesels all the time. He said it’s no big deal.
    Dagwood, Jpd0144 and TF_CC like this.
  15. Jan 20, 2022 at 4:45 PM
    #315
    J_Westie
    J_Westie New Member
    I had tentatively planned to order a Tundra as my Tacoma lease runs out this spring; no longer. Will roll just continue to roll with the Tacoma until there are some longer-term reviews of this truck and the turbos in particular.
  16. Jan 20, 2022 at 5:08 PM
    #316
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    No doubt taking the cab off opens the door to a lot of problems if done by someone who doesn’t take pride in their work. I found out after purchasing my 40k mile 2017 tundra and experiencing some electrical issues that the cab was removed to fix the cam tower seals. This is not common practice for that repair, most techs don’t remove the cab for that job. My mechanic said he wouldn’t have. Turns out the repairing dealership didn’t drain the lines properly going to the heater core in the dash before removing them. This caused corrosive coolant to drip down into the passenger side kick panel electrical compartment and corrode a bunch of connectors and relays. The truck was starting totally on its own when if I put it in neutral, and stalling shifting from reverse to drive. Check engine lights and codes of course. The dealer I purchased it used from fixed it in the end after a couple visits but I was ready to try and get rid of it. It’s been fine since luckily, point is it opens the door to problems you would have never had.
    TK1979, borla123 and OnThaLake like this.
  17. Jan 20, 2022 at 5:13 PM
    #317
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
  18. Jan 20, 2022 at 6:25 PM
    #318
    Breathing Borla
    AZ
  19. Jan 21, 2022 at 4:58 AM
    #319
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    Remember, back in 2007, when some early 5.7 engines were snapping camshafts.... and the sky was falling?
    Dagwood and Mattedfred like this.
  20. Jan 21, 2022 at 5:21 AM
    #320
  21. Jan 21, 2022 at 5:48 AM
    #321
    UATundra
    UATundra New Member
    I think what a lot of people fail to (or refuse to) realize is that those good old days of Tundra simplicity are gone. I think that we can all agree on.
    This new truck has the complexity of all the others now, so to hang your hat on dependability due to an older model without having time to actually see if that holds true is a little overzealous in my personal opinion.
    I'm not suggesting that they're not as dependable, but the engineer in me thinks that could very well be possible. But it's anyone's guess and only time will tell.
    Honestly, the people who are doom and gloom saying that the 3rd Gen will be a total failure and the fanboys who say "it's a Toyota, it can never fail" are equally as laughable in my opinion.
  22. Jan 21, 2022 at 5:52 AM
    #322
    wexttxco
    wexttxco New Member
    21 SR5 DC 4x4
    Fox 2.5 RR, 35x12.5r18 x3 on method 701, armor, front bumper
    Don't buy first year models from anyone, even toyota.
    sask3m likes this.
  23. Jan 21, 2022 at 6:01 AM
    #323
    Less than 30 07's early on were affected with the crankshaft issue out of over 100,000 built that year. The usually reliable crankshaft supplier notified Toyota the there was a bad batch that didn't meet metallurgical specs. No engines blew up. No crankshafts snapped. Once Toyota was notified it was easy to determine which Tundra's had the faulty shafts. Some engines were swapped out and a few simply got a new Tundra. There was a noisy pulley issue recall. My 07 had it replaced. Later years developed the quite serious AIP snafu. At 12 years old I had to replace a power steering pressure sensor. $20. Not bad. Hopefully this wastegate issue will be similar. Should be easy to determine which Tundra's got the faulty wastegate actuator/harness assemblies. "Should be"...........not off to a great start though. Supply chain issues are not helping either.
  24. Jan 21, 2022 at 7:20 AM
    #324
    Hadelson
    Hadelson New Member
    Allentown - Pennsylvania
    23 Tundra TRD Pro. Fun Ride 2019 RS3 Roush SC Mustang
    I would offer this view as well: Internet news, Electronic Media, and forums like this equate to rapid communication. The messaging rolls exponentially. Another point, belong to the 4Runner group, Mustang Roush Group and new here. The structure and messaging remain the same. General Information, Chat, New Releases, Classified and PROBLEM's. For some, they roll with the issue and work through it communicating on the forum in matter of fact message. Others "The Sky Is Falling". My 2 Cents and opinion. :)
    Mattedfred likes this.
  25. Jan 21, 2022 at 7:39 AM
    #325
    BLACKBEAUTY2021
    BLACKBEAUTY2021 New Member
    Nothing NORMAL about removing the cab of a BRAND NEW truck in any WAY, SHAPE or FORM.
    So happy i decided to go with a 2021 TUNDRA instead of having to go with this MAJOR HEADACHE !!!
    MoneyMan55 likes this.
  26. Jan 21, 2022 at 7:44 AM
    #326
    rideandfly
    rideandfly New Member
    But it sounds pretty good! :)
    RavingOx and Mattedfred[QUOTED] like this.
  27. Jan 21, 2022 at 7:51 AM
    #327
    raylo
    Frederick, MD
    Exactly. And I am pleased that Toyota is taking such a thorough approach, which will benefit all future buyers. But I am sorry for you guys going through this.
    JLS in WA likes this.
  28. Jan 21, 2022 at 8:14 AM
    #328
    Gene5253
    Gene5253 New Member
    Gene
    Boise ID
    2020 Tundra CM Limited
    POSSIBLE major headache
  29. Jan 21, 2022 at 8:30 AM
    #329
    Quattroa4m
    It's one thing if Toyota is going to extremes (like removing the cab) to fully understand the issue.
    It's quite another if the issue does require removing the cab...period. It's a lot of labor for Toyota and of course downtime for the customer, at the very least.
    There there's the concern that it's going to be a very expensive proposition out of warranty.
    Then there's going to be the inevitable comparison to the Ford F150 with their EcoBoost engines and costs associated with a similar repair. It does appear that removing the cab is not required.
    Hopefully this issue won't tip the scale in the favor of Ford (and their numerous other issues), especially for someone who depends on their truck...daily.
  30. Jan 21, 2022 at 8:34 AM
    #330
    Jaxyaks
    Jaxyaks New Member
    The repair requires pulling the motor or removing the cab to access the part....take your pick....Dealers will pull cab (faster) Most DIY'ers will be stuck pulling the motor once the truck is out of warranty in 60K
