@TundraTex's FRAC harness (Front/Rear Anytime Camera) Install/Review
Discussion in 'Audio & Video' started by BlueBottle, Jul 3, 2017.
  1. Jul 19, 2017 at 8:55 AM
    #61
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    No real issue other than what's been suggested. I don't know how anyone else fished the cables through but, I sprayed some WD40 to lubricate the grommet.
    I'll keep everyone updated as I test it out some more. Thanks again!!!
  2. Jul 19, 2017 at 4:23 PM
    #62
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    I cut some slits on the inside after cutting the nipple. I sprayed glass cleaner on the grommet to help with pushing the head through. Glass cleaner libricates but dries quick after you are done. Good trick to know.
    831Tun and Skippy like this.
  3. Jul 23, 2017 at 10:55 AM
    #63
    MikeyMTBs
    MikeyMTBs New Member
    About to jump on this install... did you guys have to cut the RCA cable to route through the firewall? Any other options?
    TundraTex likes this.
  4. Jul 23, 2017 at 11:10 AM
    #64
    PMG
    PMG New Member
    My rca cable is in the cabin. Wire was long enough
  5. Jul 23, 2017 at 11:12 AM
    #65
    BlueBottle
    '16 Platinum 4x4
    See fine print
    No. As long as your hole is big enough. And I used glass cleaner to help lubricate it as it was a tight pull
    MikeyMTBs[QUOTED] likes this.
  6. Jul 23, 2017 at 11:12 AM
    #66
    MikeyMTBs
    Right... but were you able to fit the end of the RCA thru the grommet in the firewall, or did you have to cut it off and reattach once thru the grommet?
  7. Jul 23, 2017 at 11:13 AM
    #67
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I did not cut it. It fit.
    MikeyMTBs likes this.
  8. Jul 23, 2017 at 11:13 AM
    #68
    MikeyMTBs
    10-4. So, did you go thru the nipple in the grommet or slice an X in the grommet to pull it thru?
  9. Jul 23, 2017 at 11:17 AM
    #69
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I went through the nipple and sliced an x on the inside of the cab because the nipple doesn't go all the way through.
    It will make sense once u do it.
  10. Jul 23, 2017 at 12:23 PM
    #70
    MikeyMTBs
    No way I could reach to push the RCA plug thru the nipple. I cut it off and will have to solder it back on.
  11. Jul 23, 2017 at 12:35 PM
    #71
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    I had to do the same thing @MikeyMTBs. just take your time with the solder joint and tape/shrink tube it well.
  12. Jul 23, 2017 at 12:36 PM
    #72
    MikeyMTBs
    Working it now.... damn tiny wires...
  13. Jul 23, 2017 at 12:37 PM
    #73
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    I know... especially difficult for guys like me... with big hands...
  14. Jul 23, 2017 at 1:09 PM
    #74
    MikeyMTBs
    Done... now to find a ring terminal for the ground...
    BlueBottle[OP] likes this.
  15. Jul 23, 2017 at 2:06 PM
    #75
    BlueBottle
    '16 Platinum 4x4
    See fine print
    It was tight but with enough librication and force it does fit
  16. Jul 23, 2017 at 3:24 PM
    #76
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
  17. Jul 23, 2017 at 3:28 PM
    #77
    MikeyMTBs
    Got it wrapped up a bit ago. Took a couple of hours but I'm slow and like to take my time. I soldered and shrink wrapped all connections and everything went together fine and works great.
    Thanks Tex for a great product!
  18. Jul 23, 2017 at 3:33 PM
    #78
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Good job. Always better to take more time and do it right the first time. Which camera did you go with? Looks good tho.
  19. Jul 23, 2017 at 3:33 PM
    #79
    Tundra Fan
    Toby
    What RCA is under the hood? Does the other end of the camera wire have one permanently attached?
    Looking at the camera links at the bottom of this page, it looks like another wire connects to the camera wire. If that's the case wouldn't it be easier to shove the other end of the wire thru the firewall?
    I don't have this (maybe when v3 comes out) so I'm not fully understanding.
  20. Jul 23, 2017 at 3:36 PM
    #80
    MikeyMTBs
    I went with the same one Tex used that fits nicely in the "T" on the grill. $29. I hated to cut the cable and re-solder especially given the almost 28-30g wire. But, it all went back together again no problem.
    Now to figure out what to do with the big wire bundle under the hood.... need some 5-7mm wire loom.
  21. Jul 23, 2017 at 4:02 PM
    #81
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    I'm a little late to the party...I cut the nipple and didn't cut an X inside the grommet which was a mistake (it would have been easier) . I taped the RCA cable to a wire hanger and I sprayed WD40 into nipple cutout. I slowly worked the RCA cable in and pulled the wire hanger from the inside.
  22. Jul 23, 2017 at 7:34 PM
    #82
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Great job @MikeyMTBs! Makes me happy to see another FRAC harness successfully installed!
  23. Jul 23, 2017 at 7:43 PM
    #83
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Since I had to cut my video/power line like you did, I cut a few feet of the extra slack out of the cable when I soldered it back together. I left about a 18-inch service loop just in case. That is easily stowed with a few tie-wraps against existing harnesses in the engine bay.
  24. Jul 23, 2017 at 7:56 PM
    #84
    PMG
    PMG New Member
    My camera had a detachable connection prior to the rca cable. The connection fit through the cut tip nipple without lube, felt pretty good going through.
    Same cam as TundraTex so I'm not sure why you guys had to cut and solder the rca wire... Mine was long enough to be in the cabin.
    Tundra Fan likes this.
  25. Jul 23, 2017 at 7:58 PM
    #85
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    Out of the first ten, has anyone else installed theirs?
  26. Jul 23, 2017 at 8:34 PM
    #86
    Tundra Fan
    Toby
    That's what I was wondering, why the RCA jack would have to get shoved thru......I guess it varies camera to camera. I like the one that fits in the Toyota logo like Tex and Mikey used. Hopefully when v3 comes around I'll have some disposable income. :pray:
  27. Jul 23, 2017 at 9:10 PM
    #87
    Skippy
    Skippy Standing for the Flag
    San Antonio US of A
    2016 Tundra 1794
    Hoping to get mine knocked out this week. Bought some extra clips just in case
  28. Jul 24, 2017 at 3:12 AM
    #88
    MikeyMTBs
    Yes, but to do that you'd have to push it thru from the inside, which would be pretty tough considering how high up on the firewall the rubber boot sits.
    It was no problem to cut/solder the connection. It pushed thru the cut nipple with no drama.
  29. Jul 24, 2017 at 4:46 AM
    #89
    PMG
    PMG New Member
    I detached the wires, ran a hanger through the boot from inside and pulled the wire in. The rca never left the cabin. Maybe yours is shorter?
  30. Jul 24, 2017 at 6:30 AM
    #90
    Skippy
    San Antonio US of A
    2016 Tundra 1794
    @BlueBottle, what size/type of drill bit did you use for your holes?2884912fe661e39a77bda26e3ffa83ce_0380ef60060a43bf05a8c323c86cf1c25c10ae59.jpg
