@TundraTex's FRAC harness (Front/Rear Anytime Camera) Install/Review
Discussion in 'Audio & Video' started by BlueBottle, Jul 3, 2017.
  1. Jul 4, 2017 at 6:08 PM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    This install deserves a nice camera. Don't go cheep to save money, get something nice that will last.
  2. Jul 4, 2017 at 8:16 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    I considered dropping some switches in the same location you did for this install but went with another solution. I love this mod and might put it on my list... Thanks for the detailed write up!
    BlueBottle[OP] likes this.
  3. Jul 4, 2017 at 10:29 PM
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    Can you send some recommendations with a similar mounting solution? There were so many I didn't know which to get so I just got this one to get it going. I can always change it later.
    Did you just replace the head unit? I was about to replace my head unit that can do front camera but the FRAC harness came out and it was too good of a deal to pass. Glad I got it, I am very satisfied with it.
  4. Jul 5, 2017 at 3:25 PM
    Tracker
    Tracker New Member
    Shane
    I am still searching, so many choices lol
  5. Jul 5, 2017 at 3:39 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    See now you see my dilemma! Please share with us when you find some. I found a nice Kenwood that can do different angles but it has an extra cable for the control unit that I'm not too find of. Check it out. Critchfield has it.
  6. Jul 5, 2017 at 5:33 PM
    Tracker
    Tracker New Member
    Shane
    I have found a few with a switch for the grid if you want it on or off. Im trying to get the best night vision option with it.
  7. Jul 9, 2017 at 7:56 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
  8. Jul 9, 2017 at 10:26 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Got to test out the front camera head in parking w a pillar.
    bulldog93 and 040Tundra like this.
  9. Jul 9, 2017 at 10:34 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Excellent! Can't do that nice of a parking job without a front cam.
  10. Jul 9, 2017 at 10:50 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Without hitting your bumper anyway lol.
    Also to note my front parking sensor started to go off at this distance. But I don't trust the front sensors because they are only on the sides.
  11. Jul 9, 2017 at 11:00 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    True, but the Braille parking method gets expensive!
  12. Jul 9, 2017 at 1:17 PM
    PMG
    PMG New Member
    Installed mine this morning.. Pro tip: install the harness bundle underneath all the wires in the back of the head unit. When you flip the head unit to go back in the bundle will be easier to push up into the crevice. Don't do what is pictured.
    Also, @TundraTex it would be helpful if you increase the length of the vim wires about 5". I had to remove and rearrange the wires/head unit 2x to get the wires to reach the bottom trim.. In the process I lost both yellow top clips c4bf65e58196fa6478a67b342b4e271d_02229477bc34d50ff31cc7d026a5d32b410a3c43.jpg
  13. Jul 9, 2017 at 1:28 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    good job @PMG
    which cam did you go w? lets see some pics of cam and how it looks on the screen.
    PMG likes this.
  14. Jul 9, 2017 at 2:00 PM
    PMG
    PMG New Member
    Went smoothly thanks to your tips. I went with the same cam TT bought.
    TundraTex likes this.
  15. Jul 9, 2017 at 2:00 PM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    NICE WORK @PMG!! Thanks for the feedback on wire length. @BlueBottle had the same comment. It is already being factored into FRACv2. If you look at your picture, you can see the yellow clips for the HU still in the slots. They tend to slip off on HU removal, but you can pop them out of the sockets and re-attach them to the HU before re-install.
    PMG[QUOTED] likes this.
  16. Jul 9, 2017 at 2:10 PM
    PMG
    PMG New Member
    Yeah, those clips are sonsabitches...They were all there and good to go... I lost the first clip the 2nd time I had to remove the HU to better stuff the frac in and I lost the last one on the 3rd HU removal because the vim wires were a bit short ☺
  17. Jul 9, 2017 at 2:13 PM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Bummer. But thanks again for the constructive feedback. You and Blue are the first two customer installers and your comments will help future customers big time!.
    I'm excited to see some operational pics or videos when you get them! This is so COOL!!
    EDIT: Nevermind. I found your pictures!
  18. Jul 9, 2017 at 2:39 PM
    Tracker
    Tracker New Member
    Shane
  19. Jul 10, 2017 at 7:18 AM
    #49
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    @Tracker I took a quick look at this cam and it looks like it would work with the FRAC harness. I believe there is an additional switch/control that comes with the 320 cam to select between its various modes. To use it with the FRAC harness you would just need to select the Front cam video feed with the FRAC cam select switch and then select your desired view mode with the Kenwood control. Could be just what you were looking for.
  20. Jul 17, 2017 at 1:01 PM
    #50
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    I went on a mod binge this past weekend and I installed my FRAC harness yesterday...Thank you both @BlueBottle for the write up and @TundraTex for the harness. I'll take a picture and update later today.
    Btw, does anyone know the part number for the clips and where to get them...I was removing the clip and then it dropped in the dashboard abyss. As a quick fix, I took a clip from the cup holder to replace what dropped from the HU. I figured it would be easier to remove the cup holder and replace.
    ZPMAN, TundraTex and BlueBottle[OP] like this.
  21. Jul 17, 2017 at 2:52 PM
    #51
    BlueBottle
    '16 Platinum 4x4
    See fine print
  22. Jul 17, 2017 at 8:47 PM
    #52
    KrazieZ
    KrazieZ New Member
    Zachary
    2017 Toyota Tundra sr5
    K&n filter, leather seats, stubby antenna
    Cool
  23. Jul 18, 2017 at 12:22 PM
    #53
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
  24. Jul 18, 2017 at 12:23 PM
    #54
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
  25. Jul 18, 2017 at 12:27 PM
    #55
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    Another shot with the light bar from HIDextra. @dcsleeper408 Thanks for the light bar installation video
    BlueBottle[OP] and dcsleeper408 like this.
  26. Jul 18, 2017 at 12:40 PM
    #56
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Nice! are you getting glare from the bar ?
  27. Jul 18, 2017 at 12:44 PM
    #57
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    Yup...Any suggestions to fix that?
  28. Jul 18, 2017 at 1:04 PM
    #58
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Not so sure.. I think you would get a bunch of glare just bc the camera is right above it. maybe if u push the camera back a bit..? Or angle the the bar a bit down?
  29. Jul 18, 2017 at 1:26 PM
    #59
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Nice job @porkitt! Any problems with the FRAC installation? Any suggestions to make things easier are welcome.
    Let me know how you like it once you get to use it a bit.
    Tex
  30. Jul 18, 2017 at 2:31 PM
    #60
    BlueBottle
    '16 Platinum 4x4
    See fine print
    040Tundra likes this.
