@TundraTex's FRAC harness (Front/Rear Anytime Camera) Install/Review
Discussion in 'Audio & Video' started by BlueBottle, Jul 3, 2017.
  1. Jul 3, 2017 at 10:40 PM
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    Ever have a hard time parking nose first and figuring out how far the car/wall is in front of you?
    Ever want to view your rear cam while in motion?
    Ever want to input navi address while driving?(of course your passenger would be doing this)
    What you want is @TundraTex FRAC Harness! - 2014+ Front/Rear Anytime Camera (FRAC) Harness
    It is completely PNP with the exception of wiring the front camera + wire. Requires you to crimp some connectors(which is provided in the kit!)
    This is installed on my 2016 Platinum
    The FRAC Harness:
    The Camera i chose for my PRO grill:
    https://www.amazon.com/gp/product/B06XNM7GNS?ie=UTF8
    Tools needed for the install:
    • 10mm socket wrench with extensions
    • 12mm box wrench for front camera nut
    • Panel removal tools(assortment)
    • Wire Stripper
    • Crimper
    • Hot Glue Gun(optional)
    • Soldering Iron(optional)
    Time it took me for install(Keep in mind I'm no professional) : ~2 Hours
    The Installation:
    • Remove grill to install front camera. I used Hot Glue Gun to secure the wire behind the grill.
    • Run front camera wiring into cab through passenger side. I prefer to solder the camera power wire to extend it into the cab.
      • Connecting the camera to the cable extension to get it into the cab
      • I cut both white & green jumper wires for my camera to disable parking lines and enable front view.(every camera is different so read your manual)
      • Here is were I grounded the camera(next to the airbox).
      • There is a grommet on the passenger side firewall that you can access through under the dash.
      • Pop out the passenger side panel to help fish the wire to the back of the radio
      • Pop out the trim under the AC controls. It is held in with 4 clips
      • Pop out the AC controls. Also held by 4 clips
      • Remove 4 10mm bolts under the Radio
        • Pull the radio straight back, there are 2 clips holding it in. Grab some extra clips from the dealer as I lost one of them in the dash.
      • Replace the two connectors with the FRAC harness
      • Connect the RCA for the front camera and the power wire. Make sure to tape the RCA connection to keep it from coming off.
      • This is where I installed my switches since I don't have any blanks available
        • I could not use the connectors because of clearance issues. I had to solder the wires on the switches to clear. Maybe lower profile switches might make this location better. I also put a dab of hot glue to keep them from moving.
    • Test everything before putting it back together!
    • All Done!
    One of my favorite mods to date! Looks OEM.
  2. Jul 3, 2017 at 10:53 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    Thanks for posting.
    BlueBottle[OP] likes this.
  3. Jul 3, 2017 at 10:55 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Hot glue is so useful and so overlooked.
    Ukalama, Inquiringone, 1UPPER and 3 others like this.
  4. Jul 3, 2017 at 10:58 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
  5. Jul 3, 2017 at 11:28 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Seriously!!! So Great!
  6. Jul 4, 2017 at 1:55 AM
    Berettafan
    Berettafan New Member
    2017 CM
    Can you show us a pic of front view when in a head on parking spot? Wondering if camera angle is adequate.
    Thanks!
  7. Jul 4, 2017 at 4:06 AM
    Scpringle
    Scpringle New Member
    Jackson MS
    2015 red Tundra double cab 4.6 L 4x2
    running boards , TRD sway bar and tundra 08 SR5 wheels. FRACmod, pop&lock and backup sensors installed .
    looks great !! Cant wait to get mine installed !
    TundraTex likes this.
  8. Jul 4, 2017 at 4:14 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    @Berettafan, here's the link to my parking spot "calibration". It'll be interesting to see how @BlueBottle's compares.
    blue16 and BlueBottle[OP] like this.
  9. Jul 4, 2017 at 4:43 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    @Scpringle, looking forward to your install/review.
    Scpringle[QUOTED] likes this.
  10. Jul 4, 2017 at 4:53 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    @BlueBottle - and everybody else - look at the picture where you showed the head unit connectors. If you look at the upper right tab position for the HU, you can see the yellow retention clip from your HU still in the dash tab slot. That has happened to me a couple times when pulling the HU. They tend to slide of the HU when you pull it out of the dash. But with a pair of needle nose pliers, you can retrieve the yellow retention clip and slide it back in place on the HU tab before reinstalling it.
    Didn't think about mentioning that until you made the comment.
    BlueBottle[OP] and Skippy like this.
  11. Jul 4, 2017 at 5:59 AM
    Skippy
    Skippy Standing for the Flag
    San Antonio US of A
    2016 Tundra 1794
    @BlueBottle, great place for the switches. I was wondering where to put mine. Question, can the male ends be bent over? One thing I don't have is a solder gun, but may have to pick one up. Thx to both you, & @TundraTex for the GREAT write ups.
  12. Jul 4, 2017 at 6:11 AM
    Scpringle
    Jackson MS
    @TundraTex If this package gets returned to you let me know and I will send you an updated shipping address and pay for re shipping . The address on my PayPal account is my parents (used it as temp banking address as I was moving ) and mail sent there is being forwarded to Vermont for the summer . I will have my family ship it to me in Jackson MS. But if comes back let me know . The FRAC harness is getting a nice tour of the USA this summer !
  13. Jul 4, 2017 at 6:14 AM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    Still wanting that 4 camera system. Can you get us a pick of the nose close up to an object?
  14. Jul 4, 2017 at 6:37 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    @Skippy i would not recommend bending the switch terminals. The switch housing is plastic and I think the likelihood of damaging the switch is pretty high. A soldering iron is the much better choice.
  15. Jul 4, 2017 at 7:25 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    @Skippy just like Tundratex said, I wouldn't not recommend bending the tabs. Most likely will break. Find a friend with soldering iron and have him solder some 6" wires to the switches then just use connectors to connect them in your truck. I am planning to do that later so it can be serviceable.
    Skippy likes this.
  16. Jul 4, 2017 at 7:27 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I realized that after lol. They still easily drop when you pull out the head unit. One of mine dropped when i pulled mine out.
  17. Jul 4, 2017 at 7:27 AM
    payyourtoll
    payyourtoll New Member
    Tampa, FL
    thanks for linking the front cam for the pro grill. just ordered mine
  18. Jul 4, 2017 at 7:30 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    @Berettafan I actually did this "calibration" check on my truck last night. When the object is at the very bottom of the screen, it is 12" away from the front of my truck. Keep in mind there will be different variables in this. Camera selection, Grill kind, Lift kit etc.. but overall happy with my $12 camera.
    TundraTex[QUOTED] likes this.
  19. Jul 4, 2017 at 7:33 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Skippy, TundraTex and BlueBottle[OP] like this.
  20. Jul 4, 2017 at 7:51 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Same with mine. 1 foot away when the parking stripe is lined up with the bottom of the display screen. And in an angled parking spot the front stripe intersects the bottom middle of the screen when the drivers side bumper is at the line.
  21. Jul 4, 2017 at 7:54 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    @TundraTex i was thinking of getting these or something in the like. HKBAYI® 10Pair / 10sets 3 pin JST SM Male Female plug LED Connector Cable For WS2812B WS2812 WS2811 LED Strip Lamp with 15cm Long Wire https://www.amazon.com/dp/B00NBSF724/ref=cm_sw_r_cp_api_yP6wzbP3TYSZG
    My plan is to solder one side to the switches and solder the other connector on the harness side.
    This will fix the clearance issue with my switches but still make is serviceable if ever have to remove the panel. Maybe you can incorporate something like this on V2 for more flexibility :D
    Make sure you call it the BlueBottle mod lol jk.
    wyone and TundraTex like this.
  22. Jul 4, 2017 at 7:57 AM
    MikeyMTBs
    MikeyMTBs New Member
    Looking forward to receiving. I have also moved since ordering so I'm sure my mail forward option is taking some extra time. I'm about to start an audio build, too, so I'll do all of this at the same time. Great write-up.
  23. Jul 4, 2017 at 11:22 AM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Nice install AND write up Blue :thumbsup:
  24. Jul 4, 2017 at 11:41 AM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    I want one too. Please make more.
  25. Jul 4, 2017 at 12:36 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Damn @TundraTex looks like you'll be busy for the rest of the year lol.
  26. Jul 4, 2017 at 1:13 PM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    No kidding! I'm up to the challenge though!
  27. Jul 4, 2017 at 1:37 PM
    Berettafan
    2017 CM
    Thanks so much for the insight guys. Can't wait to do this on my own truck.
  28. Jul 4, 2017 at 3:43 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    When you doing it? Share with us which camera you went with if you went with a different cam. Only thing with my camera is I'm not 100% convinced its 170* view. Its wide but I think it can be wider still. Wish I had a giant protractor so I can measure my field of view...
    040Tundra likes this.
  29. Jul 4, 2017 at 4:32 PM
    Nice work by the way.
  30. Jul 4, 2017 at 6:08 PM
    Berettafan
    2017 CM
    Blue im signed up for round two so might be a little bit. Will certainly report to the board once done. Head on parking is just too darn tough to judge in the tundra. AND would be nice to be able to verify tailgate closed on the move without putting it in reverse.
