2014-2021 Front/Rear Anytime Camera Mod - FRAC Harness
Discussion in 'Audio & Video' started by TundraTex, Jun 1, 2017.
  1. Aug 7, 2018 at 8:34 AM
    #901
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Agreed!
    TundraTex[OP] likes this.
  2. Aug 7, 2018 at 10:06 AM
    #902
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Thank you for the offer, I would love to take you up on it but I'm starting a new job next week so road trips a out of the question for a while. Maybe if there's a few other Canadians here who would be willing to chip in for gas and hotel I would consider it seeing as I can do it in 2 days (11 hours one way). Or maybe one of you guys in the Lethbridge/Medicine Hat region could make a run for us;):canada:
    FortSantiago and 4x4_Angel like this.
  3. Aug 9, 2018 at 10:44 AM
    #903
    silber
    silber New Member
    2016 Black Tundra 1794
    Dirty Deeds exhaust, 6 inch lift, Grind wheels, Amp Research steps, NSV light bar, TRD Pro front and rear sway bars, FRAC harness.
    @TundraTex sent you an email with my info so I can get one of your sweet inventions.
    4x4_Angel likes this.
  4. Aug 9, 2018 at 7:49 PM
    #904
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    @TundraTex Is there a way add left and right cameras to the FRAC?
  5. Aug 9, 2018 at 8:47 PM
    #905
    ktemple
    ktemple New Member
    2018 TRD Off-Road Tundra, Magnetic Grey
    Finally got around to installing my FRAC. Thanks TundraTex! Based on other's camera feedback, I went with the NOAUKA Waterproof IP68 Night Vision 170 Degree. I used a standard L bracket and multiple washers to attach it under the Toyota emblem. No holes were drilled in the grill. I used the side of the drill bit to slightly notch out about half the diameter of my bolt to have a place for the bolt to rest without moving in the grill. The L bracket was then tightened by large washers and a nut attached to the back of the Toyota emblem's bracket.
    The camera looks crooked or uneven in the pictures based on the angle I took the pictures. It is actually almost perfectly centered.
    Before picture:
  6. Aug 9, 2018 at 8:51 PM
    #906
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Looks good! great ingenuity. But it still looks crooked! :rofl:
  7. Aug 10, 2018 at 3:24 AM
    #907
    TundraTex
    TundraTex [OP] FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Nice job, @ktemple. Looks great!
  8. Aug 10, 2018 at 3:37 AM
    #908
    Very nice Kyle. Any pictures of the camera in operation. I just got that same camera and hopefully will be doing my install next week.
  9. Aug 10, 2018 at 10:46 AM
    #909
    ktemple
    ktemple New Member
    Here are a few pictures in different light settings. 20180810_115628.jpg 20180810_120717.jpg 20180810_122519.jpg
  10. Aug 10, 2018 at 1:47 PM
    #910
    Thanks, hopefully going to do this next week. Heading up to Mt Washington in New Hampshire for a long weekend.
  11. Aug 10, 2018 at 6:20 PM
    #911
    SDCementCrew
    SDCementCrew New Member
    2018 Cement Tundra Crewmax 4x4 SR5
    TRD Pro Black Badges, Ceramic Tinted Windows, TRD Front/Rear Swaybars, OEM Tow Mirrors, Black TRD T-Shifter, OEM All Weather Floor Mats, TRD Skid Plate, FRAC Harness, Front Camera
    Awesome, many thanks for the idea. I have the same camera and tried a couple other options that did not work as well. I did add some 3M double sided molding tape to the top of the camera that makes it even more solid because it sticks to the grill when bolted on. Was surprised how easy the grill assembly came off. Now it's time to pull apart the interior and get the harness installed...
    ktemple[QUOTED] likes this.
  12. Aug 14, 2018 at 5:18 PM
    #912
    Kyle,
    A few questions. Bought the same camera, instructions aren't to clear.
    See the picture below.
    On the left the red and black (power +&-) along with camera plug, yellow to yellow and red wire (?) Then long black wire with yellow and red (?) at other end to FRAC harness. My question is why 2 red wires next to the RCA plugs and do you connect 1, both or none to + 12V since there is + & - next to the the camera plug (left side of picture).
    I just don't understand 3 red wires .
    Thanks.
  13. Aug 14, 2018 at 5:34 PM
    #913
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Jim,
    If you’ll check out the FRAC install video on Youtube, you’ll see how this all works.
    But the short version is:
    The red wires next to the RCA plugs are two ends of the same wire. That wire carries power to the camera from the FRAC Harness. On the camera harness end, the red wire connects to the red camera power wire. (The black cam ground wire is connected to ground in the engine bay). The HU end red wire is connected to the red camera power wire from the FRAC Harness using the spade connector provided in your kit.
    I really recommend you watch the installation video if this doesn’t make sense.
    ktemple likes this.
  14. Aug 14, 2018 at 5:38 PM
    #914
    Thanks Lou.
    I did watch it a while back, I was planning on watching it several times before and during the install. Guess I don't remember.
    I can't wait to do this mod......hopefully the rain will stop when I try do do this.
    TundraTex[OP], 4x4_Angel and ktemple like this.
  15. Aug 14, 2018 at 5:57 PM
    #915
    Just watched it again. All makes sense now.
    Thanks Lou.
    Now if the weather just cooperates.
    TundraTex[OP] and 4x4_Angel like this.
  16. Aug 14, 2018 at 6:14 PM
    #916
    4x4_Angel
    Bree
    Funky Town, Texas
    :popcorn:
  17. Aug 14, 2018 at 7:02 PM
    #917
    Can I have your autograph?
  18. Aug 14, 2018 at 7:31 PM
    #918
    shhernandez74
    shhernandez74 New Member
    Samuel
    2017 Barcelona Red Tundra 4x4 SR5
    FRAC Driver side handle TRD Sway Bar Pop Lock Led Lights Seat Warmers Katzkin Bumper Step
    Got a new cap for my truck and we are back in business! Just sent you an email for the invoice
  19. Aug 15, 2018 at 2:12 AM
    #919
    4x4_Angel
    Bree
    Funky Town, Texas
    For what?
  20. Aug 15, 2018 at 3:53 AM
    #920
    Movie star......FRAC video :rofl:
  21. Aug 15, 2018 at 5:47 AM
    #921
    4x4_Angel
    Bree
    Funky Town, Texas
    Lol i don't kniw about movie star
  22. Aug 15, 2018 at 5:51 AM
    #922
    4x4_Angel[QUOTED] likes this.
  23. Aug 18, 2018 at 11:21 AM
    #923
    bmcdds
    bmcdds New Member
    CA
    2019 Barcelona Platinum
    Skippy, is this the route you went? I live in Ca, where it’s mandatory, and it would much easier going this route.
  24. Aug 20, 2018 at 7:38 AM
    #924
    TacoTommy
    TacoTommy New Member
    Tom
    2018 Tundra TRD / SR5
    I have an 18 Tundra, this will be my first mod, can I order?
  25. Aug 20, 2018 at 2:15 PM
    #925
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Yes you can! Just refer to Post #1 of this thread for ordering instructions.
  26. Aug 20, 2018 at 2:18 PM
    #926
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    I just received the first FRAC Harness order for a 2019 Tundra. The Entune interface is the same as all previous 3rd Gen Tundras, so we're off to another model year!
  27. Aug 20, 2018 at 8:25 PM
    #927
    shhernandez74
    Samuel
    I didn’t like the way the logo camera looked on my grill. I bought the noauka camera and will mount it underneath the logo like the one showed below (picture from another member) . I thought this Set up looked a lot cleaner.
    aperezsh, 4x4_Angel and TundraTex[OP] like this.
  28. Aug 20, 2018 at 8:44 PM
    #928
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    So how do I send you money
  29. Aug 20, 2018 at 8:53 PM
    #929
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    @Alexstundra, Just refer to Post #1 of this thread for ordering instructions.
  30. Aug 20, 2018 at 8:57 PM
    #930
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Nice, clean install, Samuel!
