2014-2021 Front/Rear Anytime Camera Mod - FRAC Harness
Discussion in 'Audio & Video' started by TundraTex, Jun 1, 2017.
  1. Feb 9, 2018 at 6:14 PM
    #781
    Kripple
    Kripple New Member
    David
    2017 black tundra trd
  2. Feb 10, 2018 at 1:37 PM
    #782
    TundraTex
    TundraTex [OP] FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Mobile DVR is on the way. Forward camera record function will hopefully be installed next Weekend.
    slide187 likes this.
  3. Feb 10, 2018 at 2:12 PM
    #783
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Are you going to be offering a recording package for sale, Lou?
  4. Feb 10, 2018 at 2:25 PM
    #784
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Well, I'll probably just post instructions on how to do it if you already have a FRAC Harness installed. It'll be a pretty simple upgrade.
  5. Feb 10, 2018 at 2:32 PM
    #785
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    Another happy FRAC customer. No photos since I just did the same as others with no factory switch panels open. My switches are located just above the galls breakage sensor and used flag terminals for clearance. I did go with the the NOAUKA front camera and the video quality is great. Much better than the rear factory. Thanks for all the help Lou!
    TundraTex[OP] likes this.
  6. Feb 10, 2018 at 3:57 PM
    #786
    Oscar2
    Oscar2 New Member
    Oscar
    San Diego
    2017 Tundra Crewmax SR5 5.7L 2WD Barcelona Red
    What DVR did you choose? Is it possible to record 2 channels so record front and back?
  7. Feb 11, 2018 at 7:07 AM
    #787
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    I went with the one listed at the bottom of this thread. It’s a single channel recorder, but it would be relatively easy to record both cameras with a dual channel DVR
  8. Feb 11, 2018 at 12:18 PM
    #788
    Oscar2
    Oscar2 New Member
    Oscar
    San Diego
    The price on that one, at $24, looks really reasonable. I notice that 2ch on up are much more (like $90-300). Is there any downside to just putting in two single channel units vs a single 2 channel?
  9. Feb 12, 2018 at 2:12 AM
    #789
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    You could certainly do that. The downside would be taking up twice the volume where ever you decide to install them. I’m thinking of mounting my single channel in the glove box.
  10. Feb 12, 2018 at 4:42 AM
    #790
    bowhun2r
    bowhun2r New Member
    Scott
    Steeler Nation
    QQ... I've seen a lot of guys in this post leveraging the camera that goes into the front logo. My 18 is due to be delivered in March and with my tight clearance in my garage this is a must do mod. With front emblem now being an actual functioning piece of the TSS system...anyone use a different front camera and location that they would recommend?
    TIA
  11. Feb 12, 2018 at 8:34 AM
    #791
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Im looking forward to see this setup.
  12. Feb 12, 2018 at 4:31 PM
    #792
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Here’s what one of my 2018 customers (@azTony) did for his 2018 grill cam.
    WAtundra4x4 and bowhun2r[QUOTED] like this.
  13. Feb 13, 2018 at 4:27 AM
    #793
    bowhun2r
    bowhun2r New Member
    Scott
    Steeler Nation
    Thanks for the idea. My grill from Sparks (plat with cement surround) will be here tomorrow. Truck will be here in a few more weeks. That will give me some time to see how that spot would work out for me. Only issue I see is if you can see that bolt easily. I can see my OCD only looking at the threaded bolt every time I look at the truck. Hopefully not, as that's a very close up picture.
    Will be placing my order when I get my truck to make sure of button locations. Thanks again.
  14. Feb 13, 2018 at 6:42 AM
    #794
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Ha. Understand. If that ends up being a problem, a little flat black rattle can paint can go a long way towards hiding the threads. You could also possibly cut the threads to match the nut length so there's no extension. You'd have to be careful not to damage the cable if taking that approach though. Looking forward to seeing your solution!
  15. Feb 13, 2018 at 1:05 PM
    #795
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    Very nice! Can’t wait to get it install!:)
  16. Feb 19, 2018 at 4:57 PM
    #796
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    Anyone have the FRAC hooking up to a Switch Pros?
  17. Mar 10, 2018 at 12:38 PM
    #797
    2018 TRD Sport
    2018 TRD Sport New Member
    2018 TRD Sport
    Tundra Tex,
    Do you have an updated ETA for the next batch of FRACs? Have you had a chance to hook up your recorder? I was hoping to mount it in the glove box too. Thanks.
  18. Mar 10, 2018 at 1:11 PM
    #798
    nk1794
    San Jose, CA
    Same here. :)
  19. Mar 10, 2018 at 1:52 PM
    #799
    kcaustin66
    kcaustin66 New Member
    kevin
    Palestine Texas (East Texas)
    2015 Toyota Tundra CM 1794 4wd
    3” lift, black step bars, aftermarket wheels, LT305/55R20 was this way when I brought it.
    What is the advantage of having a front/rear anytime camera maybe the front to help park in tight places but other than that what would you use it for.
  20. Mar 10, 2018 at 2:18 PM
    #800
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    EDIT. FRAC Harness parts issues have been resolved and the FRAC harness is once again in production!
    As for the recorder, the first one I ordered was damaged in transit, then I was out of town with work and had to re-order. I have the new one now and just need to find the time to work on it.
  21. Mar 10, 2018 at 3:41 PM
    #801
    2018 TRD Sport
    2018 TRD Sport
    Thanks Tundra Tex, I'm glad you're checking for quality! I'm totally okay with waiting longer to keep your standards high.
  22. Mar 10, 2018 at 3:49 PM
    #802
    Nike21
    Nike21 New Member
    2018 SR5 CrewMax TSS 4X4 Black Beast
    How many have installed this on the 2018? Which camera did you mount? Pics?
  23. Mar 10, 2018 at 5:05 PM
    #803
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Going over a hill off road that you just can’t quite see over. It’s a nice little heads up.
  24. Mar 14, 2018 at 12:29 PM
    #804
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    Thanks TundraTex for helping me wiring up the Frac to work with the Switch Pros!
    Viper3G, nk1794, Skippy and 2 others like this.
  25. Mar 14, 2018 at 12:33 PM
    #805
    nk1794
    San Jose, CA
    Very nice!
  26. Mar 14, 2018 at 6:07 PM
    #806
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Very nice, @Young80i ! We need to see a video demo!!!
  27. Mar 15, 2018 at 5:08 AM
    #807
    JohnRuck1985
    JohnRuck1985 New Member
    Wish I had the ability to install this myself! I'm not very good with this kind of stuff. Anyone ever have a professional do this kind of work? I was thinking about a car audio shop maybe.
  28. Mar 15, 2018 at 5:48 AM
    #808
    nk1794
    San Jose, CA
    A stereo shop would definitely do it for you. I think this would be an easy job for them.
  29. Mar 15, 2018 at 6:41 AM
    #809
    nk1794
    San Jose, CA
    I forgot to mention. I have step by step video on how to install it. Its easy but it takes time.
    Skippy and PapaRoe like this.
  30. Mar 15, 2018 at 7:37 AM
    #810
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    I've had a few customers that used their local installers to put the front camera and FRAC in for them. It should cost no more than $150 for the total installation. It is a fairly simple plug and play installation - especially for the guys who do it for a living.
