Show us your FRAC installation
Discussion in 'Audio & Video' started by TundraTex, Sep 30, 2017.
  1. Nov 17, 2017 at 2:28 PM
    TundraTex
    TundraTex [OP] FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    831Tun likes this.
  2. Dec 3, 2017 at 9:57 AM
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    4x4_Angel likes this.
  3. Dec 11, 2017 at 6:10 PM
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Not really an install thread, but @joonbug's FRAC-wheeling review is here.
    831Tun, 4x4_Angel and joonbug like this.
  4. Dec 29, 2017 at 8:46 AM
    coTony
    Tony
    Montrose, CO
    Got mine installed yesterday, 2018 Platinum
    Got the front camera installed, challenge finding a spot then trimming the long threaded area that stuck up so high.
    Then the interior
    The faston connectors would not work as the install directions stated and to avoid the soldering I removed the existing connectors and replaced them with right angle connectors which made a clean install of the job.
    I also had bed lights that I installed and I wanted something other than the very large toggle switches common with Jeeps so I put in my own micro switches I have used on my golf cart and it worked out well.
    4x4_Angel and TundraTex[OP] like this.
  5. Dec 29, 2017 at 8:55 AM
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Nice clean install, Tony. I like your camera location. Great work-around for the alternate switch connectors. And bonus points for reading the instructions!
  6. Dec 29, 2017 at 9:05 AM
    coTony
    Tony
    Montrose, CO
    Install instructions are always helpful! Thanks for making this a reality!!
  7. Dec 30, 2017 at 1:15 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
  8. Jan 16, 2018 at 2:41 PM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    Do you have a picture of image from the front camera? I have the same camera and will install just like you....curious if you can see the front bumper or how far out in front does the image begin. Thanks
  9. Jan 16, 2018 at 5:14 PM
    Rustynutz
    Rustynutz New Member
    Russell
    Louisiana
    2015 Tundra Limited 4X4
    6" Rough Country lift on 35" Toyo Open Country MT's on Moto Metal MO970's, 30 inch grille led bar, rear bumper mounted cube leds, rocklights, stereo upgrade, bed Backflip, dual exhaust
    Got my FRAC harness and front/rear camera switch in. Patiently waiting on my front camera to arrive. Hope to install this weekend.
    Thanks to goes out to TundraTex and Air On Board!!!
    TundraTex[OP] and 4x4_Angel like this.
  10. Jan 26, 2018 at 3:58 PM
    Rustynutz
    Russell
    Louisiana
    Ok. Got it all in. Here are a few pics. Several others posted detail pics, so won't go into every step. Only casualty was one of the yellow clips that holds the a.c. panel in place. Robbed one from lower drivers left panel for now so I could get the dash back together. Tundratex FRAC harness was easy to install. Split the camera switch wires to mate up to my front/rear camera switch which lights up when pressed for forward or rear camera activation. Installed VIM switch and bezel in lower console panel. Camera video/power cable was run through the psngr side firewall plug. Cut the tip off the grommet and ran the cable. Hint, shaved down the video plug and it slid through easily with a little lube. A little silicone sealed the hole. Grounded the camera in engine bay. Have not tried the VIM switch yet, but all is good otherwise!!
    Les7311 and TundraTex[OP] like this.
  11. Jan 26, 2018 at 4:06 PM
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Great job, @Rustynutz! Nice installation!
  12. Jan 26, 2018 at 4:14 PM
    Rustynutz
    Russell
    Louisiana
    Forgot pic of the camera. I purchased two different ones to try. The one I have installed now is attached with double sided tape and the lens is adjustable. The other is the stud mounted one. Still waiting on my TRD pro grille from the paint shop, so will see which camera works better for final install.
    TundraTex[OP] likes this.
  13. Jan 29, 2018 at 8:28 PM
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
  14. Feb 4, 2018 at 5:42 PM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    @Rustynutz can you take a zoomed-out pic of your front camera? I can't find one that fits the new 1794 grill yet... otherwise I'm just going to wait for a pro grill to do this too
  15. Feb 14, 2018 at 10:14 PM
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    I like where you put the VIM switch in the glove. May I ask how do you remove the glove to drill the hole and install the switch. I want to do the same on mine.
  16. Feb 15, 2018 at 2:40 AM
    Berettafan
    Berettafan New Member
    2017 CM
    Been a while but I’m pretty sure i just reached up behind it or maybe from the side when I had the radio section removed.
    Step drill is the ticket for nice round holes.
    I find I never use that switch. One thing I may yet do is rig a spring type switch on the vertical part just below and in front of arm rest. This way I press the button for a second and can see the front camera and let go of button to turn off. You don’t need front camera but for a moment when parking.
  17. Feb 15, 2018 at 10:43 AM
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    Kool..thank you!
  18. Feb 24, 2018 at 4:58 PM
    Rustynutz
    Russell
    Louisiana
    Fellow FRACers. Finally got my Pro grille installed. Mounted the camera under the letters. Used the camera in pic below. Is very clear and has a great picture. The stud barely sticks over the top of the rail and barely noticeable. Hit the threads with a little black paint to darken it. Thanks to the Tundratex harness, all works like a charm!!
  19. Feb 24, 2018 at 7:51 PM
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Great job, @Rustynutz! Looks like a professional installation!
  20. Feb 27, 2018 at 6:28 PM
    #50
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    I finally installed my Front Rear Anytime Camera last Sunday. It's really cool. :thumbsup: Kudos to TundraTex for making such a great product. I'm really happy with it.
    The installation took about half a day. I was taking my time. I also made a detailed how-to video of the installation. Please give it a :thumbsup: up if you find it helpful.
    https://youtu.be/Im_8uAFETy4
  21. Feb 28, 2018 at 5:20 AM
    #51
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Nice job @nk1794! I like your switch location choice too.
  22. Feb 28, 2018 at 6:11 AM
    #52
    nk1794
    San Jose, CA
    Thanks, Tundratex. It was a fun mod to work on.
  23. Feb 28, 2018 at 7:01 AM
    #53
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Nice videos man! Do you have a build page? You should post all your videos on if you do. If not start one!
    @dcsleeper408 looks like I’m not the only frac installer in the BA now! Woot!
  24. Feb 28, 2018 at 7:19 AM
    #54
    nk1794
    San Jose, CA
    Thanks. Ill look into doing a build page.
  25. Mar 2, 2018 at 1:15 AM
    #55
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    Pro Comp Lift, towing mirrors, Fuel rims, Toyo A/T, Nav, Viper remote start
    Night shot, you can see the low level lighting outside. The camera is well lit.
    nk1794 likes this.
  26. May 7, 2018 at 6:06 AM
    #56
    Skippy
    Skippy Standing for the Flag
    San Antonio US of A
    2016 Tundra 1794
    @TundraTex, this is the summer that I finally get my FRAC I installed. Has anyone done something like this instead of cutting the boot? Overland_Mike installed a stereo using this method, and it looks like it may be a little easier. What are your thoughts?
    [QUOTE="Overland_Mike, post: 475955,
    I HATE butchering the OEM boots because they do a good job keeping all the crap out, so I instead butched the truck and drilled 3 giant holes. After I took these pics I did paint the exposed steel.
    I used proper water resistant bulkhead fittings.
    https://smile.amazon.com/gp/product/B01GJ03AUQ/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
    I then ran 4 gauge power and ground to the inside box and end up with the ground going to a factory ground spot that is just under the air cleaner box. Btw, I ran 2 PG11 fittings for the 4 gauge and then a PG9 for the relay control wires that will head out to the underhood panel.
    [/QUOTE]
    nk1794 likes this.
  27. May 7, 2018 at 6:10 AM
    #57
    nk1794
    San Jose, CA
    [/QUOTE]
    That looks clean. I like it.:thumbsup:
    Skippy[QUOTED] likes this.
  28. May 7, 2018 at 12:35 PM
    #58
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Either approach will work, but it was difficult enough for me just to reach in and access the boot nipple. I can’t see how drilling a hole while making sure not to hit anything important on the other side of the firewall would be easier.
    Toyota engineers designed the boot specifically to allow additional wiring to be routed. I’m going to accept their gracious offer every time! Sealing the boot afterwards is as easy as heating some shrink-tube or wrapping with a good PVC tape.
    So pick the approach that you like best, and go with it. However, I would recommend a dry run to fit check getting a drill in that area before making your final decision.
    Let me know which way you choose!
    Skippy[QUOTED] and nk1794 like this.
  29. May 7, 2018 at 12:42 PM
    #59
    nk1794
    San Jose, CA
    I used this tape to seal up the hole.
    https://www.amazon.com/gp/product/B001B1AP3O/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    Skippy and TundraTex[QUOTED][OP] like this.
  30. May 8, 2018 at 5:50 AM
    #60
    Skippy
    San Antonio US of A
    2016 Tundra 1794
    That looks clean. I like it.:thumbsup:[/QUOTE]
    Can you make me a video :woot::yay:
    nk1794[QUOTED] likes this.
