@TundraTex 2016 CrewMax Audio Build
Discussion in 'Audio & Video' started by TundraTex, Sep 25, 2016.
  1. Mar 9, 2018 at 11:40 AM
    #91
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    There are plenty of 4/5 channel amps that have speaker level inputs.
  2. Mar 9, 2018 at 12:10 PM
    #92
    Young80i
    Young80i New Member
    Kyle
    Garden Grove CA
    2015 Platinum
    Nice work TundraTex!
    TundraTex[OP] likes this.
  3. Mar 10, 2018 at 12:26 PM
    #93
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    OEM wires are not RCA. That is the problem. Everything I have looked at has RCA outputs so you have to have a LOC.
  4. Mar 10, 2018 at 11:13 PM
    #94
    TundraTex
    TundraTex [OP] FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
  5. Mar 25, 2018 at 3:04 PM
    #95
    Heatonrx
    Heatonrx New Member
    MGMTundra251.....Hey just wondering if you used the factory wire from the harness w/ your 100RMS output amp out to your new speakers? Thinking of running new heavier wire but not thrilled to run it into the doors. Easier to use existing wire. Also worried about room in the doors since my crossovers are really big. If I run new wire I'll leave the crossovers near my amp.
  6. Apr 11, 2018 at 8:24 AM
    #96
    Cearex
    Cearex New Member
    2018 TRD off road DC
    First question. Is the the wiring the same for a 2018 double cab non jbl? And second, I would have to repin the connectors going to the factory amp in order to go to the lcq, correct?
    Ok, apparently I don't have to resin. But are the harnesses the same in my truck?
  7. Apr 11, 2018 at 12:33 PM
    #97
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Yes, the 3rd Gen. 2014-2018 Tundra Audio system wiring is the same for like models.
    So all JBLs are wired the same as each other and Non-JBLs are wired the same as each other.
    So my 2016 non-JBL wiring is the same as your 2018 non-JBL wiring.
    nopsFU and Pudge like this.
  8. Apr 11, 2018 at 2:28 PM
    #98
    Cearex
    Cearex New Member
    Thanks! Great thread. These new integrated systems are giving me headaches.
  9. Apr 11, 2018 at 4:28 PM
    #99
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Glad it’s helping you! By the way, welcome to the forum. Make sure to take some pics of your mod and post em’ up so your install can maybe help out the next guy.
    Then if you get a chance, introduce yourself to the forum group in the new members thread. There’s a great bunch of guys here and great mods including @Bob, @T-Rex266, and @csuviper. They can answer any questions you might have about the forum.
    Bob likes this.
  10. May 17, 2018 at 9:17 AM
    #100
    johnxmccoy
    johnxmccoy New Member
    Grove City, Ohio
    2019 Crew Max
  11. May 17, 2018 at 2:38 PM
    #101
    Beerdude77
    Beerdude77 New Member
    2018 Silver Sky Tundra Limited TRD CM
    Linex bed, "Toyota" Console Safe
    That doesn't look like the 2 harnesses he sent me to hook up my amp under the passenger seat.
  12. May 17, 2018 at 2:58 PM
    #102
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    The more i read this thread the dumber i felt....i had to stop. :( Guess when i do speaker/system upgrade in my truck I'll have to just pay someone to do it. I just don't get it:boom::facepalm:
  13. May 17, 2018 at 3:54 PM
    #103
    Beerdude77
    Some builds are more complicated than others, have you watched the ********* install videos on YouTube? They can really help explain what needs to be done. If you are super beginner there are lots of very basic videos online to show you what you need to know. If you have a JBL factory system, that does complicate things somewhat but it can be done...
    4x4_Angel[QUOTED] likes this.
  14. May 17, 2018 at 3:58 PM
    #104
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    Do you currently have a JBL system? If not, you need the non-JBL entune harness. It’s two connectors. One for speaker signals and the other for ground and power (constant and switched). Not sure if it’s on his site. You may need to send him an email or call.
  15. May 17, 2018 at 4:00 PM
    #105
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    You could totally do it. If you keep it simple, it’s not difficult. The hard part is pulling apart the interior without breaking something. :anonymous: :cool:
  16. May 17, 2018 at 4:51 PM
    #106
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    Non JBL.
    The Dude I spoke with stated it will work. The switch is included in the harness,, I just need to run from the battery.
  17. May 17, 2018 at 5:25 PM
    #107
    4x4_Angel
    Bree
    Funky Town, Texas
    I habe the factory system. I am a hands on learner.... and i don't learn well by watching videos it needs to be in person with something like this or extremely detailed instructions. And i don't do well with electrical anything....i always get shocked.... unless jumping a vehicle or changing the battery
  18. May 17, 2018 at 6:27 PM
    #108
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    For just a speaker upgrade got Crutchfield. They supply PNP harness adapters and speaker mounting adapters. Install is easy. Even a dummy could do it. They even provide decent instructions to pull sail panels and door panels. You can get a cheap door panel tool kit on Amazon or buy a little better one from Crutchfield for about $6 more. I bought the Amazon one.
  19. May 17, 2018 at 6:28 PM
    #109
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Looks like a budget LOC to me.
  20. May 17, 2018 at 6:39 PM
    #110
    4x4_Angel
    Bree
    Funky Town, Texas
    A door panel kit? Ugh.......
  21. May 17, 2018 at 7:28 PM
    #111
    Beerdude77
    I got a door panel removal kit off Amazon for around $15, its basically a bunch of pry tools made out of abs plastic that are much less likely to scratch the super soft plastic on the interior...
  22. May 17, 2018 at 8:26 PM
    #112
    4x4_Angel
    Bree
    Funky Town, Texas
    I have something that sounds like that... I'll take pics tomorrow
  23. May 17, 2018 at 10:19 PM
    #113
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    Ditto this. Crutchfield gives great instructions and a human will answer the phone if you call. @4x4_Angel if you can change your taillights, you can totally do this.
    4x4_Angel likes this.
  24. May 18, 2018 at 3:06 AM
    #114
    4x4_Angel
    Bree
    Funky Town, Texas
    Fine.... ill try it..... if i die you both have to come to my funeral and explain to my mom and children why i died. :D
    smslavin[QUOTED] likes this.
  25. May 18, 2018 at 3:25 AM
    #115
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    You can actually get by with just fingers but the pry tools come in handy at times.
  26. May 18, 2018 at 3:25 AM
    #116
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    Is Scosche a budget line of aftermarket parts?
  27. May 18, 2018 at 4:52 AM
    #117
    4x4_Angel
    Bree
    Funky Town, Texas
    I got some
  28. May 19, 2018 at 3:55 AM
    #118
    Beerdude77
    Just remember to always disconnect your negative terminal before you start working so you don't accidentally set your air bag off or fry your amp or yourself for that matter lol
  29. May 19, 2018 at 4:43 AM
    #119
    4x4_Angel
    Bree
    Funky Town, Texas
    Of course! :D
  30. May 19, 2018 at 5:18 AM
    #120
    TundraTex
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Sheesh... Go on a business trip off the grid for a few days and all of the sudden there's a ton of thread activity!
    So back to the LOC question by @johnxmccoy... looking at the pictures in the link, they appear to be wiring in LOC adapters in series with the normal audio channels in their harness. The 12-pin and 10-pin amp connectors are shown, so this will tie into the two Non-JBL amp output connectors under the passenger seat. Should work great... as great as a simple LOC will work anyway. Worth a try, easy to install (though you will still have to install and separately wire your new amp), and a 90-day warranty.
    Keep in mind what their description says though...
    "Scosche's LOC80 line output converter allows you to connect a receiver with no preamp outputs to an amplifier without speaker-level inputs. The LOC80 handles a speaker-level signal up to 80 watts RMS per channel, and converts it to a line-level signal you can plug into your amp's input."
    The option is to by an amp that will accept speaker-level inputs, then you would just need to buy the adapter cables identified earlier in this post and connect it per Post 29.
    Keep us posted on your decision!
