Tundra's Voltmeter Reading Up and Down Intermittently
Discussion in '1st Gen Tundras (2000-2006)' started by speedtre, May 24, 2020.
  1. Mar 15, 2021 at 7:49 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    AGM batteries need a higher voltage than 13.8-14.0v for proper charging.
    You can do the Ford or GM diode replacement for the charging system fuse to bump it up .5v where the AGM battery will be happy.
    Fluctuations are either alternator, battery or possibly wiring (sense wire for voltage regulator).
    KNABORES likes this.
  2. Mar 20, 2021 at 3:56 PM
    No fix here. Been driving it like this since my post and so far nothing hinky or weird has happened yet. Still fluctuates periodically.
  3. Mar 20, 2021 at 4:01 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Your back!
  4. Mar 20, 2021 at 4:04 PM
    I mean, I technically never left. Just got really f'n busy and went off on a tangent.
    I thought about popping in during the holidays, mostly because I swear I saw @Professional Hand Model 's truck while driving thru rural AL on the way to see my folks.
    I won't be in posting a helluva lot in the next few weeks, plate is full. But since I actually did something to the truck, figured I'd pop back in. Sad I'll never know what 20 of the 21 notifications I had were. they must vaporize after a month or two :D
  5. Mar 20, 2021 at 4:08 PM
    Hand Protectors
    Might be? I did just obtain some custom made bed sheets with Alabama Cotton. :thumbsup:
    shifty`[QUOTED] likes this.
  6. Mar 20, 2021 at 4:11 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    You can come back to them.
    Glad things are well, but just busy. Busy is good. :)
  7. Mar 20, 2021 at 4:14 PM
    Thanks! Got 1st shot Friday before last. Next one April. Work won't let anyone come back until they get shot. I need to get back so I can be doing less work again. They work my ass off when I'm remote.
    And that's a big fat nope on the 'show all'.
    Tundra2[QUOTED] likes this.
  8. Mar 20, 2021 at 4:19 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    The grind always grinds.
    Oh...
  9. Mar 22, 2021 at 6:55 PM
    DavidWooderson21
    DavidWooderson21 New Member
    Well fella's...it looks like the AGM battery was the culprit...ive been driving my truck more frequently (usually am driving the work truck around) and voltage is staying right at 13.8 when driving and around 13.5 when idling...not seeing fluctuations on the dash voltmeter. Tundras really dont like those AGM batteries...never again!
  10. Mar 22, 2021 at 8:26 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Sort of chasing a similar issue and I believe it is another bad battery from CRAPA. I don’t think their batteries are what they used to be but I’m betting that’s my problem. Did the same tests as you and will try and get my alternator tested sometime this week through the battery tester.
  11. Mar 22, 2021 at 8:31 PM
    Pearl-snap
    Pearl-snap New Member
    At least you all are getting some reading. I just got my 2003 access cab delivered across state lines today and the battery was dead when trying to get it off the trailer. Ran to O'Reilly's and grabbed a new battery and the truck fired right up, but the gauge is "below" zero.
  12. Mar 22, 2021 at 9:35 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    13.8 is too low for AGM batteries. Look into the ford/chevy diode mod (.5v increase) or there is an Australian company that makes an adjustable option in .2v increments (can't recall the name at the moment).
  13. Mar 23, 2021 at 4:23 AM
    Hand Protectors
    Yeah. I used to see ‘group buys’ for these AGM all the time on this site a few years ago.
    One guy in particular didn’t even own a Tundra. Don’t see as many doing them now as the reality has set in for most who didn’t do their homework. Thank you for reporting back.
  14. Mar 23, 2021 at 4:24 AM
    Hand Protectors
    Maybe the condensation on your bezel has broken the gauge?
    Tundra2 likes this.
  15. Mar 23, 2021 at 4:25 AM
    Hand Protectors
    How many miles on your truck?
  16. Mar 23, 2021 at 4:52 AM
    Pearl-snap
    I was thinking it was just a dirty cover, but now that you mention it, I’ll wipe it down and take a closer look.
    The interior was pretty dirty when I got it yesterday. The entire cab smelled like that awful artificial “freshener.”
  17. Mar 23, 2021 at 10:16 AM
    DavidWooderson21
    Yeah I saw the “HKM” one or whatever from Aus, I did the GM diode but it was only giving me 14.2 max...honestly I’m over the AGM phase...thought it was suppose to be maintenance free lol, requires a lot more maintenance than a lead acid IMO
  18. Mar 23, 2021 at 10:18 AM
    DavidWooderson21
    Of course, we all need to help each other out, this is a wonderful source of knowledge. And I appreciate you for giving me the suggestion!
  19. Mar 23, 2021 at 10:57 AM
    #49
    SouthPaw
    2000 Limited 4x4 AC
    Almost 189K.
  20. Mar 23, 2021 at 11:16 AM
    #50
    1stgentundradriver
    1stgentundradriver Each sticker adds at least 5hp
    Josh
    Silverdale Washington
    2006 DC 4x4 Limited
    A few
    Not sure if what I’m about to say is still relevant, but I had the same thing happen as @speedtre where my battery meter was reading low. But to add, my battery light was on. Drove it home and the next day truck struggled firing up. Went inside to let it warm (pretty cold day) and came out after about 5 mins and it had shut off. Turned out being the alternator. It had shorted out internally.
    Pearl-snap and speedtre[OP] like this.
  21. Mar 23, 2021 at 3:10 PM
    #51
    Hand Protectors
    Yeah. Reaching the Alternator Useful Life around 200k miles. Mine (brushes) were out of spec at 171k. Still running well, but she could have gone any time by the looks of the brushes.
    Tundra2 likes this.
  22. Mar 23, 2021 at 3:31 PM
    #52
    growit
    growit New Member
    2006 Dbcb SR5
    293k mi, still original alternator. 2006 2wd dbcb. Bought a Denso reman., just waiting for the original to fail.
  23. Mar 23, 2021 at 3:38 PM
    #53
    Hand Protectors
    Whats your secret?
    Tundra2 likes this.
  24. Mar 23, 2021 at 5:54 PM
    #54
    growit
    growit New Member
    2006 Dbcb SR5
    Wish I knew, same 02 sensors also. Bought some new Denso 02 sensors and going to replace soon.
    I've soaking them with PB plaster hoping for a easy swap.
  25. Mar 23, 2021 at 6:24 PM
    #55
    Not uncommon for cars that smell musty due to water leak or, less often, rodents. If you find it's water/mildew, see here.
    Pearl-snap[QUOTED] likes this.
  26. Mar 24, 2021 at 2:08 PM
    #56
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    Are the alternator brushes replaceable? Without major pain.
  27. Mar 24, 2021 at 2:12 PM
    #57
    Hand Protectors
    I’d consider it Agony Level 7.5 out of 10 if doing it from the topside. I’ve read you can get it done from under and the side wheel well, but am not experienced in that method.
