Tundra's new power train will destroy the truck industry
Discussion in '3rd Gen Tundras (2022+)' started by BrakeDust, Jun 24, 2021.
  1. Jun 24, 2021 at 2:41 PM
    BrakeDust
    BrakeDust [OP] New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    =JSG=, JJtruckon and Darkness like this.
  2. Jun 24, 2021 at 2:42 PM
    Tundra TTH
    Tundra TTH New Member
    They don’t know any thing more then anyone else.
    GODZILLA, Ahab and Cpl_Punishment like this.
  3. Jun 24, 2021 at 2:44 PM
    Lifer
    Lifer New Member
    Vince
    2000 Ltd 4x4 2008 SR5 4x4 LB 2021 SR 4x4 LB
    Fab tech on the 2000
    Looks GMCish
  4. Jun 24, 2021 at 2:49 PM
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
  5. Jun 24, 2021 at 3:29 PM
    2mchfun
    They better pull a rabbit out of their hat on the engine because half of the audience just walked out over the appearance.
  6. Jun 24, 2021 at 3:33 PM
    SouthWestGA
    SouthWestGA New Member
    Big HP engine doesn’t mean diddly poo without a nice transmission and heavy duty frame to back it up
    otherwise it’s just a nice engine without the towing capacity
    snivilous and 2mchfun like this.
  7. Jun 24, 2021 at 3:54 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    On second thought I can get over the front end.
    Never mind, that guy is taking guesses based on hearsay for views. Its still an ugly truck.
  8. Jun 24, 2021 at 3:56 PM
    Tundra TTH
    Sort of agree. How how much hp and torque does one need in a truck with a 1/2 ton capability.
    baron, Tyrus001, 2mchfun and 2 others like this.
  9. Jun 24, 2021 at 3:58 PM
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    2021 White Tundra SR5
    As much as my right foot can handle!
  10. Jun 24, 2021 at 4:06 PM
    Booney
    Booney New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
    Nothing more than more of the same speculation that we have seen for the last two months.
    GODZILLA, Ahab, 2mchfun and 2 others like this.
  11. Jun 24, 2021 at 4:10 PM
    AggiePhil
    College Station, TX
    FIFY
  12. Jun 24, 2021 at 4:22 PM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Give me a V8 with those specs then ok, but a strung out TTV6 with battery assist electric motors and it's a solid meh.
  13. Jun 24, 2021 at 4:29 PM
    JJtruckon
    JJtruckon New Member
    JJ
    2018 Tundra
    Undercoating
    I’d bet a few that Toyota has spent some major money updating the frame, transmission, and rust proofing.
    Westerntowboss likes this.
  14. Jun 24, 2021 at 4:35 PM
    I'm a skeptic by nature. Even more skeptical as I age.....
    rons23, CMB, Booney and 5 others like this.
  15. Jun 24, 2021 at 4:40 PM
  16. Jun 24, 2021 at 4:48 PM
    Ahab
    Ahab New Member
    Ahab
    2021 Tundra SR5
    I hate the people that do this. I am looking for real information on the 2022 and there is at least one site that does articles every day and they are horrible gossips pimping speculation for profit. It got so bad that whenever I would see the name I would just not click because I knew it was garbage info from garbage people.
  17. Jun 24, 2021 at 5:33 PM
    One thing for sure....Cheezies will be the same this coming year.:thumbsup:
  18. Jun 24, 2021 at 5:48 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    As much as the tires and driveline can withstand.
    backlash and VanceLee like this.
  19. Jun 24, 2021 at 6:20 PM
    Coal Dragger
    Kung Fu Dick
    The source of the video has been fairly accurate thus far on his predictions. He used to be an engineer for Toyota and evidently may still have quite a few contacts within the company.
    Ad far as the predictions go, they’re not unrealistic for a vehicle from Toyota given their history with hybrid power trains. An electric motor in place of the torque converter in a transmission and frame designed from the start for a hybrid application can probably easily take a large powerful electric motor.
    So an additional 70hp and 163lb-ft are well within the realm of possibility, and those numbers track with typical electric motor power outputs in other hybrid systems.
    If peak torque numbers are in the same 2000-3600 RPM range that combination will be very impressive in most circumstances. An engine/motor combo making 642lb-ft at 2000RPM is making 244.5hp, and at 3600RPM will make 440hp. So at a mere 3600RPM the hybrid will make more power than the non hybrid at it’s peak power at 5200RPM.
    If peak power of 480hp is still at 5200RPM the combo is still making 484lb-ft at that point.
    Towing on fairly normally encountered undulating terrain like rolling hills an engine/motor combo like this is going to be a beast. Plus if they program for aggressive regenerative braking the effect will be similar to a diesel with an exhaust brake going down hills, and should keep batteries well charged for the next hill to power over.
    So if these numbers are accurate the 2022 Tundra is going to in fact be class leading and it won’t even be close.
    Saltyhero13 and kstateskier like this.
  20. Jun 24, 2021 at 6:28 PM
    Coal Dragger
    Kung Fu Dick
    Wait that video isn’t that he guy who used to work for Toyota.
    So take with a giant grain of salt.
    Black Wolf likes this.
  21. Jun 24, 2021 at 6:32 PM
    In my line of work, fairly accurate sucks, especially " if these numbers are accurate", let alone predictions. Anything else at this point is simply pie in the sky.
    GODZILLA, Ahab, Booney and 1 other person like this.
  22. Jun 24, 2021 at 6:37 PM
    Coal Dragger
    Kung Fu Dick
    Sure, we will know soon enough.
  23. Jun 24, 2021 at 6:39 PM
    Tyrus001
    Tyrus001 New Member
    Ty
    2021 Crewmax
    They better hope it’s putting that kind of power out! Shew…
  24. Jun 24, 2021 at 6:42 PM
    at this point in time..................
    GODZILLA, Saltyhero13 and Ahab like this.
  25. Jun 24, 2021 at 6:46 PM
    Coal Dragger
    Kung Fu Dick
    It would be nice.
    Those kind of numbers will have the 2021 owners howling with rage about how ugly the 2022 is.
    I am not sure how looks have any bearing on the quality and features of a truck, particularly any Toyota made after about 1990. The 2022 is ugly, and the 2007-2021 is even uglier. There hasn’t been a cosmetically appealing pickup made since the Chevrolet C10, so get over it…
    DZ_ and JR2382 like this.
  26. Jun 24, 2021 at 7:41 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    You're like a broken record. Can we see your Ugly truck? ;)
  27. Jun 24, 2021 at 8:02 PM
    Coal Dragger
    Kung Fu Dick
    I don’t have very many photos of the truck on my iPhone. Let me see… here you can see it on Christmas Day of 2016. I foolishly agreed to run an empty coal train in what turned out to be a whiteout blizzard. I took this photo when I got to the depot, and it only got worse once we managed to get to the train.
    You can see my ugly truck flanked by two even uglier Ford products.
  28. Jun 24, 2021 at 8:14 PM
    TILLY
    Massachusetts
    From the very little that we can see, it is indeed a hideous looking truck, not sure how you sleep at night knowing that you actually own it.
    Ahab, dpast88, Darkness and 2 others like this.
  29. Jun 24, 2021 at 8:27 PM
    Coal Dragger
    Kung Fu Dick
    Because I don’t care much about looks where trucks are concerned?
    At heart I’m not a truck guy, to me they’re tools. Like a locomotive, I care how it performs and how easy it makes getting the job at hand done. So power, ease of use, sensible control and gauge layout, and operator comfort are high on my list. Bonus points if visibility all around is decent, and the cab is quiet under full load.
    Subjectively I love how some of the old high speed passenger service steam engines look, but I can tell you unequivocally that I do not want to make my living every day firing or running one as a fireman or engineer. Give me that ugly but super functional diesel electric, preferably a newer GE ES44AC because they’re pretty quiet, the cab layout is about as good as it gets, and they pull like a dirty bastard. In fact give me about 4 or 5 of them in a distributed power configuration.
    AggiePhil likes this.
  30. Jun 24, 2021 at 9:34 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    When I see a white truck
